Re: Need input on wideband o2 sensor kits
[Re: aspenrt360]
#1580776
02/18/14 02:13 PM
02/18/14 02:13 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
You will get a few different ideas with the mountable gauge. They are usually in the $170-$210 range. I run the FAST #170634 kit.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Azzkikrcuda]
#1580786
02/18/14 11:15 PM
02/18/14 11:15 PM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I run a Innovate LC-1 kit in my car, and my brother runs an AEM kit. Both work good.
I use the LC1 to run the closed loop on my EFI.
It can also run a gauge plus you can hook it to a lap top and data log too. Best bang for the buck IMHO.
Kevin
[Re: Twostick]
#1580787
02/18/14 11:33 PM
02/18/14 11:33 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Daytona Sensors WEGO IV, best there is. Innovate is a crap shoot. Lot's of bad reviews out there, google both, you'll see. http://www.daytona-sensors.com/WEGO4.htmlI had a Dynojet wideband, it was OK, not real accurate. With any 02 sensor, any exhaust leaks will make it read lean so seal your exhaust prior to the sensor location. Also, I prefer to read a numerical print out, Daytona Sensors allows that option...Graphs sucks. RPMs is a must, and really cool to see where your shift points are, Throttle postion not so much.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Thumperdart]
#1580789
02/19/14 12:01 AM
02/19/14 12:01 AM
Adobedude
New Mexico
I verify my WB on the dyno.
[Re: Thumperdart]
#1580792
02/19/14 01:57 AM
02/19/14 01:57 AM
Posts: 3,908 Oregon
hooziewhatsit
I watched flebay for a while and got my LM1 box cheap (like $10). Then got the sensor and cables new from innovate. Then watched ebay again, and got the logging add-on thing pretty cheap. Then to make it really useful, I built my own manifold vacuum gauge and ran that into the logging port. Now it logs AFR/RPM/Manifold vacuum, so you can actually see how the AFR changes with changes in throttle position. Then I converted to electronic ignition and fixed all of the driveability issues I thought were fuel related
