MSD timing on OEM spec'd 440
#1580686
02/18/14 10:52 AM
02/18/14 10:52 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang.. Got the MSD up and running. I noticed that the timing characteristics if it versus OEM points is different. I both ran the MSD with the points dist. as a trigger ( with condensor out ) and last night ran it with my Chrysler electronic distributor. Didn't get to take her out last night due to son's football game. But, I did drive it Sunday with the points as a trigger. The idle seems rougher than with the OEM points distributor, but man oh man, the performance enhancement when driving and getting on it is like night and day. I was curious for those running the MSD on their somewhat stock 440's, what are you doing for timing?
1. Are you setting the timing to OEM spec ( about 10 degrees BTC at curb idle without vacuum advance ) or
2. Setting it at total degree advance ( say about 32-35 at 3000rpm ) and letting it be?
This will eventually be used on the 426 HEMI when I install it in the next couple of months
Thanks in advance...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: MSD timing on OEM spec'd 440
[Re: hemi68charger]
#1580687
02/18/14 11:13 AM
02/18/14 11:13 AM
Posts: 5,163 CT
GTX MATT
CT
Timing should be the same no matter what the ignition system is, and that's whatever works best. It's possible that it may like a degree or so less timing with a hotter ignition system.
Set the base where it idles best and the total where it makes the most power. If you're looking for an idea of where to start I'd start with 32 total and work my way up, and expect the engine to idle best with 14+ initial.
[Re: GTX MATT]
#1580688
02/18/14 11:29 AM
02/18/14 11:29 AM
hemi68charger
Houston, Tx
Thanks... That's what I thought on the theory.... I was setting my points at 10 initial, so I'll bump it up to 14-15 with the electronic distributor I have in it now.. I'll see where that gets me with the vacuum/centrifical advance ( hopefully around the 32 area )....
[Re: GTX MATT]
#1580690
02/18/14 12:05 PM
02/18/14 12:05 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
At idle is plays with the lights.At say 2200 it clears up.I set mine at 35 total but I have a complete MSD.Rocky
Chrysler Firepower
[Re: hemi68charger]
#1580691
02/18/14 12:17 PM
02/18/14 12:17 PM
RapidRobert
As said use a light that is compatible. Just me I'd set the initial with the vacuum gauge method then shorten the slots to get 36 total (initial+slots) (with vac adv capped) then springs then plug in/adj the vac adv just like I would on a non MSD equipped 440. Staying just under the pinging point at WOT (springs) will give good power & I'd want the springs to not start advancing any less than 200 RPM above the hot idle speed in gear which is what the eng is at at the stoplight & if the vac gauge "initial" timing on the dampener makes the starter cranky then reduce the initial (not the vac) 1 degree or more (as needed). EDIT I would see if the initial is the same with the MSD as it is with points without moving the dist housing & if there is a change then set it back to where it was with points & see if that clears up the rough(er) idling which'll tell you if it was from the initial change amount or something to do with the MSD multi spark characteristics
[Re: hemi68charger]
#1580692
02/18/14 03:15 PM
02/18/14 03:15 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
[Re: hemi68charger]
#1580693
02/18/14 03:25 PM
02/18/14 03:25 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Choice #2 is a horrible method to set timing. I can give you two different distributors, tell you set total at 34* and one will be clean and responsive off idle, the other will be a total POS!
Find the initial timing the engine wants. Starter kickback, vacuum gauge, there are a couple methods. Then tailor the rest to hit your total timing number.
If you have an MSD Pro Billet, put the black bushing on it and see how it runs. If you need a bushing that gives less mechanical advance, I have them in 10 and 14* for $10 ea.
Having the idle/initial timing setting right makes a world of difference in how an engine will run and perform.
[Re: RobX4406]
#1580694
02/24/14 11:29 AM
02/24/14 11:29 AM
hemi68charger
Houston, Tx
Thanks again guys.... I have her set at 15 BTC and now, with the electronic Chysler distributor, the cars run freakin' great !!! With the MSD, she's like a completely different car. I can't wait to see what that 426 Hemi with the MSD's going to run like once the engine's installed..
[Re: hemi68charger]
#1580698
02/25/14 01:45 PM
02/25/14 01:45 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Which distributor do you have ... or non adjustable mech advance unit or the new adjustable ... and what is your TOTAL timing ?
