Wheels and tires on my R/T broadcast sheet #1580498
02/17/14 10:56 PM
02/17/14 10:56 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
The sheet on my 69 Coronet R/T broadcast sheet has a 30 in the first box then an unknown and 9 in the second box (unknown is missing due to seat spring), in the wheel cover box is a 61. What wheels and tires did it come with?
Also what steering wheel and horn pad? Looks like 12 unknown and 8.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Wheels and tires on my R/T broadcast sheet [Re: AZ_A12_BEE] #1580499
02/17/14 11:15 PM
02/17/14 11:15 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Both of those are the PN. the Options code should be at the bottom.
The missing character is an X (x9) indicating a black spare tire rim.
Wheel cover 61 = W21=Chrome road wheel. The 61 is the PN for the trim ring.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Wheels and tires on my R/T broadcast sheet [Re: AZ_A12_BEE] #1580500
02/17/14 11:17 PM
02/17/14 11:17 PM
Wisconsin
MoparDave440 Offline
super street
super street
Wisconsin
The missing wheel character is probably an X.
Re: Wheels and tires on my R/T broadcast sheet [Re: MoparDave440] #1580501
02/17/14 11:20 PM
02/17/14 11:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
X9 - TX9 paint on your spare wheel rim.
Tire codes are higher up on line 2.
Re: Wheels and tires on my R/T broadcast sheet [Re: Alaskan_TA] #1580502
02/17/14 11:37 PM
02/17/14 11:37 PM
Dreaming of the 808
Dreaming of the 808
Looks like tire code is T unknown 2, does this help?
Re: Wheels and tires on my R/T broadcast sheet [Re: 69CoronetRT] #1580503
02/17/14 11:41 PM
02/17/14 11:41 PM
Dreaming of the 808
Dreaming of the 808
g.
In the WH/COV box, if so in the Wheels 2- box is a 1
Re: Wheels and tires on my R/T broadcast sheet [Re: AZ_A12_BEE] #1580504
02/17/14 11:49 PM
02/17/14 11:49 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
W21 - Road Wheels (Magnum 500)
Re: Wheels and tires on my R/T broadcast sheet [Re: AZ_A12_BEE] #1580505
02/17/14 11:52 PM
02/17/14 11:52 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Multiple possibilities, get a closeup of that area if you can?
Re: Wheels and tires on my R/T broadcast sheet [Re: Alaskan_TA] #1580506
02/17/14 11:55 PM
02/17/14 11:55 PM
Dreaming of the 808
Dreaming of the 808
Won't help, middle is rubbed away? How about my steering wheel/horn pad?
Re: Wheels and tires on my R/T broadcast sheet [Re: AZ_A12_BEE] #1580507
02/18/14 12:05 AM
02/18/14 12:05 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
T8 is tan I think? Does the car have a tan interior?
Re: Wheels and tires on my R/T broadcast sheet [Re: AZ_A12_BEE] #1580508
02/18/14 12:32 AM
02/18/14 12:32 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Do you have any markings under your trunk lid. Red line side walls were standard.
Re: Wheels and tires on my R/T broadcast sheet [Re: Alaskan_TA] #1580509
02/18/14 01:02 AM
02/18/14 01:02 AM
Dreaming of the 808
Dreaming of the 808
Yes tan interior
Re: Wheels and tires on my R/T broadcast sheet [Re: RoadRunnerJD] #1580510
02/18/14 01:03 AM
02/18/14 01:03 AM
Dreaming of the 808
Dreaming of the 808
John, trunk lid was changed out due to damage so I can't reference it
Re: Wheels and tires on my R/T broadcast sheet [Re: AZ_A12_BEE] #1580511
02/18/14 01:17 AM
02/18/14 01:17 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Have you checked all the other normal locations for broadcast sheets yet?
If not, you may find one or more in better condition with the missing data still intact.
Re: Wheels and tires on my R/T broadcast sheet [Re: Alaskan_TA] #1580512
02/18/14 01:24 AM
02/18/14 01:24 AM
Dreaming of the 808
Dreaming of the 808
If not, you may find one or more in better condition with the missing data still intact. [/quote
I checked, I'm lucky to have this one
Re: Wheels and tires on my R/T broadcast sheet [Re: AZ_A12_BEE] #1580513
02/18/14 01:31 AM
02/18/14 01:31 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
steering wheel is half ring style with T8 (tan) pad. Check under the S codes for S79.
Two options on tires T83= F70 RSW or T82 F70 WSW
Seeking:
Re: Wheels and tires on my R/T broadcast sheet [Re: 69CoronetRT] #1580514
02/18/14 01:34 AM
02/18/14 01:34 AM
Dreaming of the 808
Dreaming of the 808
Has to be T82 F70 WSW
Re: Wheels and tires on my R/T broadcast sheet [Re: AZ_A12_BEE] #1580515
02/18/14 01:43 AM
02/18/14 01:43 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Did you confirm the S code or is that part of the sheet gone?
Here's something similar to yours.
Seeking:
Re: Wheels and tires on my R/T broadcast sheet [Re: 69CoronetRT] #1580516
02/18/14 01:49 AM
02/18/14 01:49 AM
Dreaming of the 808
Dreaming of the 808
Maybe you can pick it out, here it is
Re: Wheels and tires on my R/T broadcast sheet [Re: AZ_A12_BEE] #1580517
02/18/14 01:52 AM
02/18/14 01:52 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Yep S79 partial horn ring and W21-Chrome Road Wheels.
Seeking:
