Wheels and tires on my R/T broadcast sheet
#1580498
02/17/14 10:56 PM
02/17/14 10:56 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
The sheet on my 69 Coronet R/T broadcast sheet has a 30 in the first box then an unknown and 9 in the second box (unknown is missing due to seat spring), in the wheel cover box is a 61. What wheels and tires did it come with?
Also what steering wheel and horn pad? Looks like 12 unknown and 8.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Wheels and tires on my R/T broadcast sheet
[Re: AZ_A12_BEE]
#1580499
02/17/14 11:15 PM
02/17/14 11:15 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Both of those are the PN. the Options code should be at the bottom.
The missing character is an X (x9) indicating a black spare tire rim.
Wheel cover 61 = W21=Chrome road wheel. The 61 is the PN for the trim ring.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: AZ_A12_BEE]
#1580500
02/17/14 11:17 PM
02/17/14 11:17 PM
Posts: 183 Wisconsin
MoparDave440
super street
super street
Wisconsin
The missing wheel character is probably an X.
[Re: AZ_A12_BEE]
#1580505
02/17/14 11:52 PM
02/17/14 11:52 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
X9 - TX9 paint on your spare wheel rim.
Tire codes are higher up on line 2.
Looks like tire code is T unknown 2, does this help?
Multiple possibilities, get a closeup of that area if you can?
[Re: AZ_A12_BEE]
#1580513
02/18/14 01:31 AM
02/18/14 01:31 AM
69CoronetRT
Harlan, Iowa
Won't help, middle is rubbed away? How about my steering wheel/horn pad?
steering wheel is half ring style with T8 (tan) pad. Check under the S codes for S79.
Two options on tires T83= F70 RSW or T82 F70 WSW
Seeking:
[Re: AZ_A12_BEE]
#1580515
02/18/14 01:43 AM
02/18/14 01:43 AM
69CoronetRT
Harlan, Iowa
Did you confirm the S code or is that part of the sheet gone?
Here's something similar to yours.
Seeking:
[Re: AZ_A12_BEE]
#1580517
02/18/14 01:52 AM
02/18/14 01:52 AM
69CoronetRT
Harlan, Iowa
Yep S79 partial horn ring and W21-Chrome Road Wheels.
Seeking:
