power steering hose; '69 426 Hemi B-body #1580363
02/17/14 01:38 PM
02/17/14 01:38 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Sorry for the numerous questions; but looking around doing my research and can't find explicitly the proper hose for my Daytona. I am getting a proper Federal power steering pump, but need to find a proper high pressure hose. Sooooooo, any of you guys out there who have put together a 426 Hemi with power steering, what hose did you get if you needed to replace/find one? These puppies are rather expensive, so I want to get it right the 1st time.....
Thanks..
Troy
Troy
Houston Mopar Connection Club
Re: power steering hose; '69 426 Hemi B-body [Re: hemi68charger] #1580364
02/17/14 03:21 PM
02/17/14 03:21 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Check with Roger Gibson or Frank Badalson, also you need the 90 degree fitting that goes on the box.
Re: power steering hose; '69 426 Hemi B-body [Re: 71birdJ68] #1580365
02/17/14 03:38 PM
02/17/14 03:38 PM
Houston, Tx
Houston, Tx
fitting is on my check list
I am curious on if there's a BIG difference between the '69 and '70/'71? I see Jaime at MegaParts sells the '70/'71 Ebody version for a 426H... Don't see why it wouldn't work for my Charger. I am not looking for 100% OEM correctness.....
Troy
Re: power steering hose; '69 426 Hemi B-body [Re: hemi68charger] #1580366
02/17/14 06:09 PM
02/17/14 06:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '66-'68 90° Hemi fitting (the same as used on some early A-bodies) has a different hose flare size than the '69-'71. One is 1/4" flare the other is 5/16". (can't remember which is which)
