Re: Question for the 9 second small-block NA guys [Re: Guitar Jones] #1580289
02/21/14 06:30 PM
02/21/14 06:30 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I think you will be fine. I went 9.72 136 mph at 3000 lbs with 16X32's and a 4.88 at 7200. Keep in mind that your converter affects the finish line rpm as well. percentage of slip etc. I have since picked up a few mph in the 1/8th so Im expecting it to go 140ish and be around 7400
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Question for the 9 second small-block NA guys [Re: Irun5snd8th] #1580290
02/22/14 08:14 PM
02/22/14 08:14 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
I run a 428Sb with a 28x10 and 4.56 gears running high 9s.Shifting at 7500 and going though the traps at 8000. The car seems like its running out of steam. I was told by my engine builder to set the car up to run 7400 out the back door. That's where is made peak hp. I think i'm going to try a set of 4.10s
Re: Question for the 9 second small-block NA guys [Re: Otherlane] #1580291
02/22/14 09:27 PM
02/22/14 09:27 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
i would. It would last a lot longer.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Question for the 9 second small-block NA guys [Re: Otherlane] #1580292
02/23/14 12:02 AM
02/23/14 12:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Set up your gear to run thru the traps at 10% above
max HP rpm
Re: Question for the 9 second small-block NA guys [Re: MR_P_BODY] #1580293
02/23/14 11:29 AM
02/23/14 11:29 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
max HP rpm
So he should be going thru at 8100? Seems a little higher than necessary isn't it?
Re: Question for the 9 second small-block NA guys [Re: moparguy7074] #1580294
02/23/14 12:17 PM
02/23/14 12:17 PM
PA.
"Little"John
"Little"John
PA.
max HP rpm
I don't know why guys think this is necessary. I'm not going to say there aren't engines out there that NEED high rpm but come-on now. Test your combo at the track shifting at a lower rpm and you may really be pleased with the results. I know I was and I only changed from 6800 to 6400. I was young once and I too put a few rods out thru the side of some engine blocks.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Question for the 9 second small-block NA guys [Re: pittsburghracer] #1580295
02/23/14 12:47 PM
02/23/14 12:47 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I don't spin the mine like that either.
Re: Question for the 9 second small-block NA guys [Re: pittsburghracer] #1580296
02/23/14 12:48 PM
02/23/14 12:48 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
I was thinking 8000 was a lot of rpm. if I get the rpm down I think the car should go faster
Re: Question for the 9 second small-block NA guys [Re: Otherlane] #1580297
02/23/14 12:59 PM
02/23/14 12:59 PM
Q
Quicktree Offline
Quicktree  Offline
Q
check your converter/trans also.
Re: Question for the 9 second small-block NA guys [Re: moparguy7074] #1580298
02/23/14 01:07 PM
02/23/14 01:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
max HP rpm
There are plenty of pros that say 10% higher.. if
you dont want to.. dont... but rpm is HP.. if your
set up for it
Re: Question for the 9 second small-block NA guys [Re: pittsburghracer] #1580299
02/23/14 02:14 PM
02/23/14 02:14 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
max HP rpm
Maybe it's cause you run .550 lift street cams
Re: Question for the 9 second small-block NA guys [Re: pittsburghracer] #1580300
02/23/14 07:14 PM
02/23/14 07:14 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I had mine geared for street use,but it worked great at the track to.8.75 w 3.91 and 5500 stall on 28x10.5. Hit 1/4 traps at 7000 rpm and 140mph also had 727 tf at the time.
Re: Question for the 9 second small-block NA guys [Re: fishy340] #1580301
02/23/14 10:19 PM
02/23/14 10:19 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
456 904
Re: Question for the 9 second small-block NA guys [Re: one bad fish] #1580302
02/23/14 10:20 PM
02/23/14 10:20 PM
bronx n.y
O
O
bronx n.y
to much info lol
Re: Question for the 9 second small-block NA guys [Re: fishy340] #1580303
02/24/14 10:48 AM
02/24/14 10:48 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
140 mph wow
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Question for the 9 second small-block NA guys [Re: 10 o to go] #1580304
02/24/14 02:48 PM
02/24/14 02:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
140 mph wow
pretty sure he is boosted, mine runs 140+ at 7000 NA, but it's a whole lot lighter
