Question for the 9 second small-block NA guys #1580269
02/17/14 01:01 PM
02/17/14 01:01 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
I ran some 10.00's in my 408 Duster last year and my combo was running out of steam at about the 1000 ft line. Several issues going on as I was under cammed (550 lift solid), under carbed (750), the heads were only flowing about 270cfm, and I was running pump gas. There is a 4:88 gear in the car now and a 14-32 Micky Thompson slick.
This years engine will a roller cam and app 670 lift, 850 alcohol or 1050 dominator, 40 plus more cfm, 2 points higher compression, and either race gas or alcohol.
Now for the question aimed for guys running in the 9's NA. Do you think a 4:30 gear would work better with this combo. If and when I go big block in this car I will probably install 4:30's in the dana but would like keep costs down a little right now. What gear are you guys running and if possible what are you shifting at and what is your trap RPM. Only other thing to add is the car weights 2850 and has a powerglide in it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Question for the 9 second small-block NA guys [Re: pittsburghracer] #1580270
02/17/14 01:26 PM
02/17/14 01:26 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I run a dana with 4.56 gears and I shift at 6800 and trap at 7200 my slick size is 14X31X15 and my car weight is similar to yours, I do run a 904 behind my 408.
Re: Question for the 9 second small-block NA guys [Re: dartman366] #1580271
02/17/14 01:34 PM
02/17/14 01:34 PM
PA.
"Little"John
"Little"John
PA.
So we are probably geared pretty close with the tire size difference. I try not to beat the heck out of stuff but 7200-7500 shouldn't be a real issue. Powerglide may help to keep the RPM's down a little too. Thanks for the info.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Question for the 9 second small-block NA guys [Re: dartman366] #1580272
02/17/14 01:43 PM
02/17/14 01:43 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
John I don't mean to hijack your post. I was just wondering what width rim you and Bill are running those tires on? Jim
Re: Question for the 9 second small-block NA guys [Re: rt66jim] #1580273
02/17/14 01:48 PM
02/17/14 01:48 PM
PA.
"Little"John
"Little"John
PA.
Jim I bought new rims last year and I talked to the guy from Micky Thompson before ordering them as I had 12 inch wheels and 14-32 slicks on the car when I bought it. He said go 14 inch wide to improve the foot-print contact so I went with the 14 inch wide wheels.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Question for the 9 second small-block NA guys [Re: pittsburghracer] #1580274
02/17/14 01:56 PM
02/17/14 01:56 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I went 14" also as I intend to go to a 14X32 later, and yes it seems to give a better footprint.
Re: Question for the 9 second small-block NA guys [Re: pittsburghracer] #1580275
02/17/14 08:08 PM
02/17/14 08:08 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have to believe 32" tire, a glide, and a 4.30 would be weak down low. How fast do you anticipate? 140? less? How many rpm do want to run it in the traps? My bet is 4.56
Doug
Re: Question for the 9 second small-block NA guys [Re: dvw] #1580276
02/17/14 08:23 PM
02/17/14 08:23 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
John I put my combo thru the Wallace calculators. It tells me with a 4.30 gear and wanting to turn the motor 7000. I need a 31" tire.
Re: Question for the 9 second small-block NA guys [Re: dvw] #1580277
02/17/14 08:29 PM
02/17/14 08:29 PM
PA.
"Little"John
"Little"John
PA.
Doug
Doug its only trapping at 130mph now but like I said its running out of get up and go. I was only shifting this combo at 6400 and really slowed up even at 6800. I know more cam, more head, and the bigger carb will help but how much I don't know. This car only weighed 2550 when my son was driving it. Between my lard azz, removing the fiberglass doors, alternator, racepak, and a few other goodies we fattened her up some. 140 mph would really make me happy with this combo but I don't see it happening but time will tell. I won't install 4:56 because I really like a 4:30 gear with a big block and its coming sooner or later. If it was a Ford 9 inch I could use my spare 4:30 carrier from the Daytona.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Question for the 9 second small-block NA guys [Re: rt66jim] #1580278
02/17/14 08:32 PM
02/17/14 08:32 PM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
i run a 29" tall tire with a 4.30 gear. i shift at 7500 and cross the line at 7800. best et thus far 9.79 @ 138.71 with A 60' of 1.42. my best 60' ever was a 1.34 its kinda my weak area that i'm still working on
Re: Question for the 9 second small-block NA guys [Re: rt66jim] #1580279
02/17/14 08:40 PM
02/17/14 08:40 PM
PA.
"Little"John
"Little"John
PA.
Ya but your talking big block right? I went down that road before in my 74 Duster (4.56 gear 14-31 tire) and a 4.88 gear 14-32 tire in my old 69 Dart. Both big block cars, higher torque, relatively lite cars. (2600 and 2800). My fear was what Doug was saying about smallblock powerglide combos and the lack of big block torque. I really didn't want to buy gears for this years combo and SLOW UP. I hate that.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Question for the 9 second small-block NA guys [Re: w2stroker] #1580280
02/17/14 08:44 PM
02/17/14 08:44 PM
PA.
"Little"John
"Little"John
PA.
My average 60 foot last year with the glide was 1.37 and usually around 6.36@106mph in the 1/8.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Question for the 9 second small-block NA guys [Re: pittsburghracer] #1580281
02/17/14 09:28 PM
02/17/14 09:28 PM
PA
R5P7 Bantam Offline
R5P7 Bantam  Offline
PA
We're running 9.20's in the heat of the summer (90's w/50+ RH) in eastern PA and 9.0's in the spring and fall months. 410 sb with a 1.80 first gear in the glide and 60' is 1.22-1.25 all year long. Dana with 5.14 or 4.88 (no gain or loss in et either way, just rpm) and a 14-32 tire on a 12" rim. This is waaaaaay tooooooooo much tire, but it hooks on ice and we're bracket racing so AOK for me. The narrow rim allows the tire to grow to roughly 35.5" at the finish line, thus giving me the numeric gear ratio on the hit and lower numeric gear on the top end.
Oh, and I shift at 7000-7500 (depending on the look of the race) and cross under 7500 (w/4.88). Now, the other year we had great air and it was going 8500 w/ the 5.14 at 150 mph.
My motto, let them eat and run them HOT!!!! I twist all my motors up and still get hundreds of runs before freshening.
Mike
Re: Question for the 9 second small-block NA guys [Re: R5P7 Bantam] #1580282
02/17/14 11:12 PM
02/17/14 11:12 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
D-60 with 4.30 gears and 29.5 tire is what's in our Duster. Worked great with our 4" W5 mill that was 9.8 capable. Believe it trapped around 6800. Unfortunately that same combo didn't work well this weekend with our 440hp iron head 360! We're leaving it be as we believe it will adapt well in/when the W8 mill finally gets fitted.
Re: Question for the 9 second small-block NA guys [Re: pittsburghracer] #1580283
02/17/14 11:19 PM
02/17/14 11:19 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
My demon runs the same with 4.88 or 4.56 gears. With the 4.56 gear finish line RPM is 7200 +/- and with 4.88 its getting close to 7800RPM in good air. The quickest pass ever was with the 4.56 gears, but in mine shaft air. 13"x31" Goodyears
Re: Question for the 9 second small-block NA guys [Re: qwkmopardan] #1580284
02/17/14 11:32 PM
02/17/14 11:32 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
I have a 440 W8 motor with a 1.80 glide 4.56 gear 29.5 11.5W tire I shift at 7800rpm. best 60ft is 1.29 with an avg 1.32 with a tight converter.going to a 4.88 gear this year. Best 1/8 mile is 5.79@ 120 at 3085 lbs.
http://youtu.be/RTDkU8WCjLo
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Question for the 9 second small-block NA guys [Re: pittsburghracer] #1580285
02/17/14 11:35 PM
02/17/14 11:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With my 395" and 14 X 31 and a 4.88 I was running a
9.56 with a 1.27 60'... rpm through was 7600... that
was on a 12" rim... I wouldnt drop to the 4.30 unless
you cant turn the revs.. due to cam
Re: Question for the 9 second small-block NA guys [Re: MR_P_BODY] #1580286
02/17/14 11:41 PM
02/17/14 11:41 PM
PA.
"Little"John
"Little"John
PA.
Well I placed my Summit order today for my new wheels and some roller lifter for the new higher compression build and I passed on the 4.30 gears for now. Had a 10% off coupon I had to use up. I know it will still be head and cam limited but back to big blocks soon so no sense in buying a good after market block. Thanks guys for sharing some info.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Question for the 9 second small-block NA guys [Re: 440W8 Duster] #1580287
02/18/14 02:03 AM
02/18/14 02:03 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
This example shows how my engine in the Demon is head limited. The cars weigh within 5lbs of each other and mine only went 6.09 at 111mph versus 5.79 at 120 mph, however my 60 ft has been as quick as 1.261 and avg 1.29/1.30 if it don't trip the beams with the rear wheels. 3 speed trans in mine helps the 60ft a lot though.
I watched the video also and nice job munching the chevy.
Re: Question for the 9 second small-block NA guys [Re: qwkmopardan] #1580288
02/18/14 10:29 AM
02/18/14 10:29 AM
Guitar Jones Offline
I have an 8.75 rear and the only pro gear available is the 4.86 so that is what I run with a 14.5/32 tire on a 15" rim, traps about 7200. 2750 with me in it, 4 link rear the car would hook in a mud slide.
