904 to 727? #158017
11/28/08 12:55 PM
11/28/08 12:55 PM
North Central Texas
dusterforever Offline OP
North Central Texas
I have a 904 behind my 408 that has problems. My question is if I change to the 727 will my column shifter linkage and kickdown work the same? Also is the crossmember and tranny mount the same distance? I realize I will have to change the length of the driveshaft. Any comments would be appreciated.
Re: 904 to 727? [Re: dusterforever] #158018
11/28/08 01:00 PM
11/28/08 01:00 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Trans mount is the same.
Most of the kickdown linkage is different, at least on an a-body it is. I don't know about the other body styles.
