Holley calibration information needed #1579892
02/16/14 07:36 PM
02/16/14 07:36 PM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
Went to the track the 1st time with my my Pro Systems 750 Holley.
Currently its running a 50cc front shooter and 30cc rear shooter - both new diaphrams.
The car hooked fine..but my 60ft was still about 1/10th under where I think it should be...(Best was 1.84)
It feels "soggy" at launch..and there was no difference between a launch at 800rpm and at 2500
So here's my questions -
What is the recommended set up for dual pump shooters?
- should they be the same size..or should the primary be smaller than the sec?
What effect does it have swapping the small one and the big one from primary side to secondary side?
Can I run a 30cc diaphragm on a 50cc cam? What effect would this have?
Please bear with me - I'm not seeking "tuning" advice for this motor - its not far off being jetted correctly....but I don't understand how the twin pump shooter configuration is supposed to be set up.....
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Holley calibration information needed [Re: Moparmal] #1579893
02/16/14 08:43 PM
02/16/14 08:43 PM
SoCal
Brian Hafliger Offline
SoCal
I'm not a fan of ProSystems...that said I think the larger pump should be on the secondary side as that's the side that most times has to cover the "hole" made by going to WOT.
I start my holleys with Blue cams, and then go up on the squirters until there is no hesitation or your 60ft. is at it's best.
With 4 corner idle, you need to make sure the secondaries are cracked open some so there is a signal to the idle circuit and the Main circuit once it starts to move.
Also, make sure the idle mixture screws aren't set too lean...they will have an affect on going to WOT and the "hole" that's created by that sudden change in depression.
Brian
Brian Hafliger
Re: Holley calibration information needed [Re: Moparmal] #1579894
02/16/14 10:46 PM
02/16/14 10:46 PM
I never been a fan of the 50 CC pumps on any Holley carb., no matter what size I have changed the rear 50 CC pump to a 30 CC pump and ended up with better 60 ft times on a bracket 440 motor with a Holley 800 D.P. carb. I did the same thing on a SS style Hemi motor with a stock crossram that had dual 750 D.P. carbs with 50 CC pumps on the rear, we changed them to 30 CC pumps(you have to change the pump arm also ) and put in 31 squirters to get the best 60 ft. times that day at that track I would adjust the accelerator pump arms like Holley says to and go from there You can slow the 60 ft. times down with to much accerator pump shot is what I'm trying to say
Re: Holley calibration information needed [Re: Cab_Burge] #1579895
02/16/14 10:53 PM
02/16/14 10:53 PM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
Like cab said......Run 30s front and rear......would be nice to get some light pump springs for under the 30cc diaphrams as they do a nice job of getting the complete 30cc spray.....I would say 33-35 squirters square and all should be good....Jesse
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
Re: Holley calibration information needed [Re: Cab_Burge] #1579896
02/16/14 11:28 PM
02/16/14 11:28 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Properly sized discharge nozzles and discharge timing, won't care what size supply diaphragm supplies it. That's been my experience.
Re: Holley calibration information needed [Re: Moparmal] #1579897
02/16/14 11:47 PM
02/16/14 11:47 PM
Moparmal Offline OP
Moparmal  Offline OP
What you guys are suggesting makes sense compared to what Im feeling thru the seat of the pants..
Seems like Ive gone from not having enough pump shot with the Eddie Thunder to having too much.
Ill change the front shooter to 30cc and see if it improves at the track
Thx for your help
Re: Holley calibration information needed [Re: Moparmal] #1579898
02/17/14 12:59 AM
02/17/14 12:59 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Just curious as does the car seem to hesitate or bog ? Or just kinda a down on power feeling ? Ron
Re: Holley calibration information needed [Re: 383man] #1579899
02/17/14 03:32 AM
02/17/14 03:32 AM
Moparmal Offline OP
Moparmal  Offline OP
Just a "down on power" felling over the first 30 yards or so...Once its winding out it pulls well...
Re: Holley calibration information needed [Re: 383man] #1579900
02/17/14 12:24 PM
02/17/14 12:24 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what is the engine specs? Did you change anything else in the carb?
Coming soon!!!!
Re: Holley calibration information needed [Re: Brian Hafliger] #1579901
02/17/14 02:34 PM
02/17/14 02:34 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
A Holley tech at a Nat'l event told me to increase squirter size. Until the sixty foot slowed down. Then back-up to the previous size. I.E. 33 to 35 and 60' slowed. Go back to 33.
I have had success using this method. Jim
Re: Holley calibration information needed [Re: rt66jim] #1579902
02/17/14 07:07 PM
02/17/14 07:07 PM
Moparmal Offline OP
Moparmal  Offline OP
So changing squirter size is not the same as changing the diaghram?
So which should I change...the 50cc diaphram and cam......or the shooter?
Re: Holley calibration information needed [Re: Moparmal] #1579903
02/17/14 08:29 PM
02/17/14 08:29 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I would try different size squirters first if you have or can borrow them.
Re: Holley calibration information needed [Re: Moparmal] #1579904
02/18/14 01:27 AM
02/18/14 01:27 AM
When you change the squirters you end up changing how long the fuel squirts through them, not how much by volume, just the time it squirts out If you enlarge the squiter isze it will stop squirting sooner than when it has smaller squirters in it. If you want to reduce the volume used per stroke on the accelerator pump circuit change from the larger pump,50 CC, to the smaller 30 CC pump Holley, for what ever reasons, uses ten stroke on each pump to distingish(SP?) the differences between the 30 CC and the 50 cc pumps, it is not pumping 30 CC or 50 CC per pump shot
Re: Holley calibration information needed [Re: Cab_Burge] #1579905
02/18/14 07:21 AM
02/18/14 07:21 AM
Moparmal Offline OP
Moparmal  Offline OP
Cheers Cab
This thing has 40th front and rear squirters...which is probably a little large for my purposes?
My main question is that b4 I change anything...would I have more luck with the 50cc pump on the primaries or secondaries?
Or do I just swap them over and suck it and see?
Re: Holley calibration information needed [Re: Moparmal] #1579906
02/18/14 11:23 AM
02/18/14 11:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Cheers Cab
wow 40 seems like too much unless you have a 500 inch motor. If you are running the 5.7 in your sig I'd try 31's and go up from there.
Re: Holley calibration information needed [Re: Moparmal] #1579907
02/18/14 01:35 PM
02/18/14 01:35 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Larger than needed jets can also bring the 60 foot numbers down!.
and with big cams like my timing all in by 1200?
Re: Holley calibration information needed [Re: Dodgem] #1579908
02/18/14 01:54 PM
02/18/14 01:54 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
My experience with Pro-Systems, is that every one I have ever seen was extremely RICH down low. That coupled with big squirters, explains the "soft" feeling down low. It's just rich
Monte
Re: Holley calibration information needed [Re: Monte_Smith] #1579909
02/18/14 02:05 PM
02/18/14 02:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
A lot of holleys in general are fat from what I`ve seen and my car runs cleaner and faster w/28 squirters and jetted/set up leaner on the idle and cruise circuit. If you can`t read plugs a wide band is your friend. Years ago Cab told me this; there`s 3-circuits on a carb(2-circuit) idle, cruise and wot so we`d set up the idle circuit first and read the plug idle only then make necessary changes. Then we`d work on the cruise circuit driving on primaries only and read the plugs then finally wot. Took a lot of work but w/out a wide band I don`t see any other way and although it`s not perfect, it`s a great reference tool and now my plugs look like the wide band indicated. Slightly rich at idle and cruise and nice at wot..........
Re: Holley calibration information needed [Re: Thumperdart] #1579910
02/18/14 07:23 PM
02/18/14 07:23 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Just curious as you said it really doesn't stumble so I was wondering about the converter you are using. Not to tight is it ? Ron
Re: Holley calibration information needed [Re: Moparmal] #1579911
02/18/14 08:24 PM
02/18/14 08:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cheers Cab
The largest squirters I have ever used was a 36 and
that was too much... I have a 850 with dual 50cc
pumps on it.. the pumps just have the volume.. the
squirters tell it how much to shoot but with 50cc
it will go much longer if needed
