Holley calibration information needed
#1579892
02/16/14 07:36 PM
02/16/14 07:36 PM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Went to the track the 1st time with my my Pro Systems 750 Holley. Currently its running a 50cc front shooter and 30cc rear shooter - both new diaphrams. The car hooked fine..but my 60ft was still about 1/10th under where I think it should be...(Best was 1.84) It feels "soggy" at launch..and there was no difference between a launch at 800rpm and at 2500 So here's my questions - What is the recommended set up for dual pump shooters? - should they be the same size..or should the primary be smaller than the sec? What effect does it have swapping the small one and the big one from primary side to secondary side? Can I run a 30cc diaphragm on a 50cc cam? What effect would this have? Please bear with me - I'm not seeking "tuning" advice for this motor - its not far off being jetted correctly....but I don't understand how the twin pump shooter configuration is supposed to be set up.....
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Holley calibration information needed
[Re: Moparmal]
#1579894
02/16/14 10:46 PM
02/16/14 10:46 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
I never been a fan of the 50 CC pumps on any Holley carb., no matter what size I have changed the rear 50 CC pump to a 30 CC pump and ended up with better 60 ft times on a bracket 440 motor with a Holley 800 D.P. carb. I did the same thing on a SS style Hemi motor with a stock crossram that had dual 750 D.P. carbs with 50 CC pumps on the rear, we changed them to 30 CC pumps(you have to change the pump arm also ) and put in 31 squirters to get the best 60 ft. times that day at that track I would adjust the accelerator pump arms like Holley says to and go from there You can slow the 60 ft. times down with to much accerator pump shot is what I'm trying to say
[Re: Moparmal]
#1579897
02/16/14 11:47 PM
02/16/14 11:47 PM
Moparmal
What you guys are suggesting makes sense compared to what Im feeling thru the seat of the pants.. Seems like Ive gone from not having enough pump shot with the Eddie Thunder to having too much. Ill change the front shooter to 30cc and see if it improves at the track Thx for your help
[Re: Moparmal]
#1579904
02/18/14 01:27 AM
02/18/14 01:27 AM
Cab_Burge
So changing squirter size is not the same as changing the diaghram?
So which should I change...the 50cc diaphram and cam......or the shooter?
When you change the squirters you end up changing how long the fuel squirts through them, not how much by volume, just the time it squirts out If you enlarge the squiter isze it will stop squirting sooner than when it has smaller squirters in it. If you want to reduce the volume used per stroke on the accelerator pump circuit change from the larger pump,50 CC, to the smaller 30 CC pump Holley, for what ever reasons, uses ten stroke on each pump to distingish(SP?) the differences between the 30 CC and the 50 cc pumps, it is not pumping 30 CC or 50 CC per pump shot
[Re: Cab_Burge]
#1579905
02/18/14 07:21 AM
02/18/14 07:21 AM
Moparmal
Cheers Cab This thing has 40th front and rear squirters...which is probably a little large for my purposes? My main question is that b4 I change anything...would I have more luck with the 50cc pump on the primaries or secondaries? Or do I just swap them over and suck it and see?
[Re: Moparmal]
#1579906
02/18/14 11:23 AM
02/18/14 11:23 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Cheers Cab
wow 40 seems like too much unless you have a 500 inch motor. If you are running the 5.7 in your sig I'd try 31's and go up from there.
[Re: Moparmal]
#1579907
02/18/14 01:35 PM
02/18/14 01:35 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Larger than needed jets can also bring the 60 foot numbers down!. and with big cams like my timing all in by 1200?
[Re: Moparmal]
#1579911
02/18/14 08:24 PM
02/18/14 08:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Cheers Cab
The largest squirters I have ever used was a 36 and that was too much... I have a 850 with dual 50cc pumps on it.. the pumps just have the volume.. the squirters tell it how much to shoot but with 50cc it will go much longer if needed
