Clutch Safety Switch? #1579798
02/16/14 03:25 PM
02/16/14 03:25 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
70 RR... mone is broke.. ( spring). Looks like Brewers is out of stock.. does anyone else have them? Can you just ground it..?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Clutch Safety Switch? [Re: JMCFAN] #1579799
02/16/14 03:27 PM
02/16/14 03:27 PM
Kirkland, Washington
Pacnorthcuda Offline
Yes you can just ground it. Car will start in gear so be careful.
Re: Clutch Safety Switch? [Re: JMCFAN] #1579800
02/16/14 03:33 PM
02/16/14 03:33 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i believe Jim at js restorations can rebuild them..
http://www.jsrestorations.com/
Re: Clutch Safety Switch? [Re: flypaper] #1579801
02/16/14 03:44 PM
02/16/14 03:44 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
told me not if the spring is damaged....and it is...
Re: Clutch Safety Switch? [Re: JMCFAN] #1579802
02/16/14 03:52 PM
02/16/14 03:52 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Roseville has it on their site. Does not say "out of stock" so perhaps they have it.
http://www.rosevillemoparts.com/product_...cdb65b98ed6e9f3
EDIT; Also one on ebay, but says "as is".
http://www.ebay.com/itm/Superbird-Roadru...19d&vxp=mtr
Re: Clutch Safety Switch? [Re: moparfan53] #1579803
02/16/14 03:55 PM
02/16/14 03:55 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Core must have good spring... mine is toast..
Restored/rebuilt clutch pedal safety switch for 1970 B-body models. This switch grounds the starter relay when the clutch pedal is depressed, allowing car to start. Includes rebuilt switch, secondary wire, activation wire loop/push pin, and attatchment screw. As available. 2947857 CORE SWITCH MUST HAVE UNBROKEN CLOCK SPRING! $139.95 plus core charge.
Re: Clutch Safety Switch? [Re: JMCFAN] #1579804
02/16/14 04:03 PM
02/16/14 04:03 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Yes, I read that but since the first price shown is $269.95 I think you can buy it for that and not return your core.
Note; I posted one on ebay above.
Re: Clutch Safety Switch? [Re: moparfan53] #1579805
02/16/14 04:13 PM
02/16/14 04:13 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I see there is one on Kijiji (our version of Craigslist) in Ontario.
http://toronto.kijiji.ca/c-cars-vehicles...QAdIdZ434426316
Re: Clutch Safety Switch? [Re: JMCFAN] #1579806
02/16/14 07:09 PM
02/16/14 07:09 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I can fix you up with a good one if you don't mine the missing wire end connector,just PM me.
Re: Clutch Safety Switch? [Re: JMCFAN] #1579807
02/16/14 08:20 PM
02/16/14 08:20 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
For over 70 years people started stick shift cars without any safety switch.
Lay the switch on the lawn and see how far you can drive it with a golf club, your crankshaft will love you for it.
Re: Clutch Safety Switch? [Re: John_Kunkel] #1579808
02/16/14 08:42 PM
02/16/14 08:42 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I agree with John.I made a ground at the starter relay.Just make sure the car is out of gear,which in reality should be done irregardless on any car with a stick.
Nautilus Racing-
Re: Clutch Safety Switch? [Re: Chris2581] #1579809
02/16/14 10:09 PM
02/16/14 10:09 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thanks folks for the dose of reality... ground the damn thing... better places to spend $250....
