can an auto trans shift "too hard", causing damage?
#1579739
02/16/14 02:07 PM
02/16/14 02:07 PM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
Just curious.. with the stuff I've got in my 904, it shifts REALLY hard.. almost violently .. Griner reverse manual VB with low band apply Red clutches with Kolene Steels Low 1st gear Kevlar bands mild torque converter (I think around 2800 rpm)
The engine is a mild 360 ..
When it shifts, it knocks you back in your seat.. depending on RPMs and throttle, it has no problem breaking the tires loose going from 1-2 and will sometimes do it going from 2-3 ...
So my question is, .. "is there any risk of causing damage to other components of the drivetrain by having a shift that is this 'hard'?"
Rear end is recently completely rebuilt .. new Eaton True-Track, new ring/pinion, bearings, etc.. What would any potential 'weak point' be that I should consider beefing up for the way this thing shifts?
Re: can an auto trans shift "too hard", causing damage?
[Re: cal_gecko]
#1579740
02/16/14 03:39 PM
02/16/14 03:39 PM
Posts: 22,728 Bitopia
jcc
Bitopia
Weak point my guess in your case would be DS/U joints, but the hard shifting in a street car would get old fast for me.
[Re: Cab_Burge]
#1579743
02/16/14 05:45 PM
02/16/14 05:45 PM
cal_gecko
Sacramento, CA
Harsh shifts like your having are usually caused by two gears being engaged, overap, at the same time Check your shifter adjustment I make sure the button on the shifter cable will slide easily into the shifter arm in nuetral, 1st, 2nd and 3rd gear with no visible movement of the shifter arm or button If either moves adjust the parts until they don't
I recently double checked my adjustments and the trans doesn't shift any different, so I'm guessing they're where they should have been.. but I'll double check the cable going to the shift linkage to ensure that when it goes into gear, it's not close to another gear.. I'm using a B&M Quicksilver shifter, if that matters.. I doubt it though.
[Re: 340SHORTY]
#1579745
02/16/14 06:11 PM
02/16/14 06:11 PM
cal_gecko
Sacramento, CA
race tranny in a street car..
That's what I get for asking John Cope for transmission advice, LOL!!
[Re: cal_gecko]
#1579746
02/16/14 07:45 PM
02/16/14 07:45 PM
Posts: 1,012 indiana
mcmopars
indiana
awsome 360 theat will bust em loose on 2-3 shift.my cope built mvb trans shifts very hard at cruising,to the point i dont like it ,never broke anything yet,full throttle is very firm.its street driven,if i had to do it again i would have him build a auto shifting trans.just make sure you have the good u-joints,which im sure you do.
[Re: cal_gecko]
#1579747
02/16/14 08:25 PM
02/16/14 08:25 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
RMVB's run the line pressure wide open all the time, this results in WOT shifts even at low speeds.
The lighter the car, the lower the axle ratio and the tighter the converter, the more you will feel it in the "buttmeter"....and, yes, it's hard on parts.
[Re: John_Kunkel]
#1579748
02/16/14 08:54 PM
02/16/14 08:54 PM
cal_gecko
Sacramento, CA
So, being that the Dart is not a super-heavy car, I have 3.55 gears, and a moderate torque converter.. those are some of the reasons it's so noticeable.. makes sense!
[Re: 340SHORTY]
#1579751
02/18/14 10:31 AM
02/18/14 10:31 AM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
I had a lowered 2WD stepside chevy with a 454/ turbo 400 that shifted like that.. Kinda fun but grew old fast... or maybe I just got old
[Re: Cab_Burge]
#1579752
02/18/14 10:45 AM
02/18/14 10:45 AM
Posts: 16 Orlando, FL
98 SNAKE EATER
Orlando, FL
Won't make a difference in his case running a MVB
There's full line pressure for each shift, so it will shift hard regardless.
My 69 RR with a Cheetah RMVB shifts is the same way and breaks the tires loose very easily in any gear, so I usually up shift at a low RPM and just let the torque of the motor take care of things while cruising
Big soft sticky tires makes a huge difference though.
https://www.youtube.com/watch?v=rT5f2z7PTQc
It's almost buttery smooth when I run my MT Sportsman Pros
As for damage, U-Joints and seat backs come to mind
[Re: cal_gecko]
#1579753
02/18/14 11:44 AM
02/18/14 11:44 AM
Posts: 1,767 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I have a home built 727 here, the line pressure is adjusted to the MAX, pretty much too high, no doubt about it...the result is nearly what you describe, although I have often wondered if I get a slight bind between the 1st and 2nd gear because the shift is extremely harsh. 2nd to 3rd is softer...
[Re: bonefish]
#1579755
02/18/14 02:49 PM
02/18/14 02:49 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
It's easy to tell a hard shift from overlap. If you have overlap the car will drop the nose on the shift, a clean shift will keep it up. You can have overlap no matter what valve body you have.
[Re: Diplomat360]
#1579756
02/18/14 06:30 PM
02/18/14 06:30 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
1st is the rear clutch engaged, it is engaged in ALL forward gears. There is no way to have a BIND between 1st and second because all that is happening on the 1-2 shift is the front band is stopping the front drum from spinning...
unless you have a manual shift only valve body that has low band apply and the front band is stopping the front drum completely before the rear band releases ...
[Re: JohnRR]
#1579757
02/18/14 06:45 PM
02/18/14 06:45 PM
Diplomat360
Windsor, ON, Canada
Ahh...very good information...well, this is a regular automatic valve body, the trans has been rebuilt with a SMR rebuild kit, fitted with a shift-kit, your typical 'shift improver' stuff and a few parts/add-ons that were suggested to me at that time like the 5.0 lever, accumulator blocker rod (keep in mind, this is a good 15 yrs ago...at least...). The car only has 1k miles since I finally got that thing on the road last year...LOL!
Specifically, the MP P4349469 kit (727 Accumulator and Piston Blocker Rod kit) states the following (which is where I got my MAX line pressure setup from):
=== START === Step3: Adjust line pressure to maximum with Allen head adjustment screw. Rotate counterclockwise to compress the spring until almost all available threads are used. Allow enough threads to completely egage adjustment bracket. === STOP ===
Other then the harsh but very quick gear shift (which I do not mind, even though it's jolting) I am happy with the trans. The 2nd to 3rd gear shift is much softer though...I think this is something that can be tuned though...need to do a little more research/reading.
