can an auto trans shift "too hard", causing damage? #1579739
02/16/14 02:07 PM
02/16/14 02:07 PM
Sacramento, CA
cal_gecko Offline OP
Sacramento, CA
Just curious.. with the stuff I've got in my 904, it shifts REALLY hard.. almost violently ..
Griner reverse manual VB with low band apply
Red clutches with Kolene Steels
Low 1st gear
Kevlar bands
mild torque converter (I think around 2800 rpm)
The engine is a mild 360 ..
When it shifts, it knocks you back in your seat.. depending on RPMs and throttle, it has no problem breaking the tires loose going from 1-2 and will sometimes do it going from 2-3 ...
So my question is, .. "is there any risk of causing damage to other components of the drivetrain by having a shift that is this 'hard'?"
Rear end is recently completely rebuilt .. new Eaton True-Track, new ring/pinion, bearings, etc..
What would any potential 'weak point' be that I should consider beefing up for the way this thing shifts?
Re: can an auto trans shift "too hard", causing damage? [Re: cal_gecko] #1579740
02/16/14 03:39 PM
02/16/14 03:39 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Weak point my guess in your case would be DS/U joints, but the hard shifting in a street car would get old fast for me.
Re: can an auto trans shift "too hard", causing damage? [Re: jcc] #1579741
02/16/14 04:28 PM
02/16/14 04:28 PM
Sacramento, CA
Sacramento, CA
it's not bad if I want to cruise, I can start in 2nd gear and quickly shift to 3rd before RPM's get up too high, it's not too bad.. however, that doesn't seem to happen too often, LOL..
could be a contributing factor to me getting 8mpg.. just a guess..
Re: can an auto trans shift "too hard", causing damage? [Re: cal_gecko] #1579742
02/16/14 05:24 PM
02/16/14 05:24 PM
Harsh shifts like your having are usually caused by two gears being engaged, overap, at the same time Check your shifter adjustment I make sure the button on the shifter cable will slide easily into the shifter arm in nuetral, 1st, 2nd and 3rd gear with no visible movement of the shifter arm or button If either moves adjust the parts until they don't
Re: can an auto trans shift "too hard", causing damage? [Re: Cab_Burge] #1579743
02/16/14 05:45 PM
02/16/14 05:45 PM
Sacramento, CA
Sacramento, CA
I recently double checked my adjustments and the trans doesn't shift any different, so I'm guessing they're where they should have been.. but I'll double check the cable going to the shift linkage to ensure that when it goes into gear, it's not close to another gear.. I'm using a B&M Quicksilver shifter, if that matters.. I doubt it though.
Re: can an auto trans shift "too hard", causing damage? [Re: Cab_Burge] #1579744
02/16/14 06:09 PM
02/16/14 06:09 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
race tranny in a street car..
I am truckless..
Re: can an auto trans shift "too hard", causing damage? [Re: 340SHORTY] #1579745
02/16/14 06:11 PM
02/16/14 06:11 PM
Sacramento, CA
Sacramento, CA
That's what I get for asking John Cope for transmission advice, LOL!!
Re: can an auto trans shift "too hard", causing damage? [Re: cal_gecko] #1579746
02/16/14 07:45 PM
02/16/14 07:45 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
Low 1st gear
Kevlar bands
awsome 360 theat will bust em loose on 2-3 shift.my cope built mvb trans shifts very hard at cruising,to the point i dont like it ,never broke anything yet,full throttle is very firm.its street driven,if i had to do it again i would have him build a auto shifting trans.just make sure you have the good u-joints,which im sure you do.
Re: can an auto trans shift "too hard", causing damage? [Re: cal_gecko] #1579747
02/16/14 08:25 PM
02/16/14 08:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
RMVB's run the line pressure wide open all the time, this results in WOT shifts even at low speeds.
The lighter the car, the lower the axle ratio and the tighter the converter, the more you will feel it in the "buttmeter"....and, yes, it's hard on parts.
Re: can an auto trans shift "too hard", causing damage? [Re: John_Kunkel] #1579748
02/16/14 08:54 PM
02/16/14 08:54 PM
Sacramento, CA
Sacramento, CA
So, being that the Dart is not a super-heavy car, I have 3.55 gears, and a moderate torque converter.. those are some of the reasons it's so noticeable.. makes sense!
Re: can an auto trans shift "too hard", causing damage? [Re: John_Kunkel] #1579749
02/16/14 09:10 PM
02/16/14 09:10 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
John, is the line pressure adjustable on the Griner? Wondering if a pressure check / lowering & possibly loosening the front band a little would make a difference without significant wear increase on the band/clutches.
Re: can an auto trans shift "too hard", causing damage? [Re: cal_gecko] #1579750
02/18/14 01:24 AM
02/18/14 01:24 AM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
Make sure your rear lug nuts are tight. Don't ask me why or I will be forced to tell you.
Re: can an auto trans shift "too hard", causing damage? [Re: 340SHORTY] #1579751
02/18/14 10:31 AM
02/18/14 10:31 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
I had a lowered 2WD stepside chevy with a 454/ turbo 400 that shifted like that.. Kinda fun but grew old fast... or maybe I just got old
Re: can an auto trans shift "too hard", causing damage? [Re: Cab_Burge] #1579752
02/18/14 10:45 AM
02/18/14 10:45 AM
Orlando, FL
9
98 SNAKE EATER Offline
Orlando, FL
Won't make a difference in his case running a MVB
There's full line pressure for each shift, so it will shift hard regardless.
My 69 RR with a Cheetah RMVB shifts is the same way and breaks the tires loose very easily in any gear, so I usually up shift at a low RPM and just let the torque of the motor take care of things while cruising
Big soft sticky tires makes a huge difference though.
https://www.youtube.com/watch?v=rT5f2z7PTQc
It's almost buttery smooth when I run my MT Sportsman Pros
As for damage, U-Joints and seat backs come to mind
Re: can an auto trans shift "too hard", causing damage? [Re: cal_gecko] #1579753
02/18/14 11:44 AM
02/18/14 11:44 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I have a home built 727 here, the line pressure is adjusted to the MAX, pretty much too high, no doubt about it...the result is nearly what you describe, although I have often wondered if I get a slight bind between the 1st and 2nd gear because the shift is extremely harsh. 2nd to 3rd is softer...
Re: can an auto trans shift "too hard", causing damage? [Re: Diplomat360] #1579754
02/18/14 12:03 PM
02/18/14 12:03 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i,ve been running my Cope tranny in my street car for the last 8,000 miles the only damage so far is my back teeth are startin come loose.
Re: can an auto trans shift "too hard", causing damage? [Re: bonefish] #1579755
02/18/14 02:49 PM
02/18/14 02:49 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
It's easy to tell a hard shift from overlap. If you have overlap the car will drop the nose on the shift, a clean shift will keep it up.
You can have overlap no matter what valve body you have.
Re: can an auto trans shift "too hard", causing damage? [Re: Diplomat360] #1579756
02/18/14 06:30 PM
02/18/14 06:30 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
1st is the rear clutch engaged, it is engaged in ALL forward gears.
There is no way to have a BIND between 1st and second because all that is happening on the 1-2 shift is the front band is stopping the front drum from spinning...
unless you have a manual shift only valve body that has low band apply and the front band is stopping the front drum completely before the rear band releases ...
Re: can an auto trans shift "too hard", causing damage? [Re: JohnRR] #1579757
02/18/14 06:45 PM
02/18/14 06:45 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Ahh...very good information...well, this is a regular automatic valve body, the trans has been rebuilt with a SMR rebuild kit, fitted with a shift-kit, your typical 'shift improver' stuff and a few parts/add-ons that were suggested to me at that time like the 5.0 lever, accumulator blocker rod (keep in mind, this is a good 15 yrs ago...at least...). The car only has 1k miles since I finally got that thing on the road last year...LOL!
Specifically, the MP P4349469 kit (727 Accumulator and Piston Blocker Rod kit) states the following (which is where I got my MAX line pressure setup from):
=== START ===
Step3: Adjust line pressure to maximum with Allen head adjustment screw. Rotate counterclockwise to compress the spring until almost all available threads are used. Allow enough threads to completely egage adjustment bracket.
=== STOP ===
Other then the harsh but very quick gear shift (which I do not mind, even though it's jolting) I am happy with the trans. The 2nd to 3rd gear shift is much softer though...I think this is something that can be tuned though...need to do a little more research/reading.
Re: can an auto trans shift "too hard", causing damage? [Re: cal_gecko] #1579758
02/18/14 06:51 PM
02/18/14 06:51 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
That trans is WAY too radical for what you're doing...
And it's gonna find the weakest point...
Zing..
