Performance advantage 8" rim to 9" rim #1579732
02/16/14 02:01 PM
02/16/14 02:01 PM
ont,canada
mopartuner Offline OP
ont,canada
I am trying to get the most grip out of a 9" slick and I have fitted a 8" rim on the car with no problem but a 9" may be too close to the quarter.Is the risk worth the reward here?Will there be a big advantage going from a 8 to a 9 inch rim?
410 pump gas solis flat tappet cam 10.95 so far
Re: Performance advantage 8" rim to 9" rim [Re: mopartuner] #1579733
02/16/14 02:06 PM
02/16/14 02:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
BIG advantage... no.. but it will have some
Re: Performance advantage 8" rim to 9" rim [Re: MR_P_BODY] #1579734
02/16/14 02:11 PM
02/16/14 02:11 PM
ont,canada
ont,canada
Here is a pic with the 8" wheels......a new look
Re: Performance advantage 8" rim to 9" rim [Re: MR_P_BODY] #1579735
02/16/14 02:13 PM
02/16/14 02:13 PM
ont,canada
ont,canada
Not as much as going from a 7" to an 8" ?
Re: Performance advantage 8" rim to 9" rim [Re: mopartuner] #1579736
02/16/14 02:19 PM
02/16/14 02:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 7" would be the minimum rim for a 9" slick so the
percentage of increase would be greater from going
from the 7" to 8" over the 8" to 9"... but it might
still be small
Re: Performance advantage 8" rim to 9" rim [Re: MR_P_BODY] #1579737
02/16/14 08:58 PM
02/16/14 08:58 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I gained about .75 of section width when I went from 10" wide to 12" wide rims with the same size tires.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Performance advantage 8" rim to 9" rim [Re: 6PKRTSE] #1579738
02/16/14 09:36 PM
02/16/14 09:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a 9" tire also and I switched from a 7 to 8" rim and to be honest I did not pick up any et as it hooked good with the 7" wheel and 9" tire. Ron
