Braided fuel line questions..........
#1579329
02/15/14 06:05 PM
02/15/14 06:05 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am upgrading my whole fuel system and I do not have any experience with any kind of braided line. Do the stainless and nylon braided line use the same kind of fittings on the end of the hoses. I may end up using stainless and nylon. I like the look of the black line better than the stainless and I already have some fittings but I will need to get more. I am going to a 1050 carb and I already have a MagnaFuel pump and a Holley billet regulator, I just got to plumb everything.Thanks for any help or suggestions.....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Braided fuel questions..........
[Re: Quicksilver440]
#1579332
02/15/14 07:02 PM
02/15/14 07:02 PM
D-50
North, Alabama
I have the magnafuel 500 pump and it is for -12 fittings. I want to run -10 from the pump to the regulator. Would you run -12 or -10 from the fuel cell to the pump.
[Re: D-50]
#1579333
02/15/14 07:07 PM
02/15/14 07:07 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
-12an from cell to inlet of the pump and then -10an from outlet of pump to inlet of fuel regulator.
[Re: PLUM BAD]
#1579335
02/15/14 07:48 PM
02/15/14 07:48 PM
D-50
North, Alabama
I was looking at the -12 Summit brand Braided Nylon hose and all the fittings for the end of the hose say -12 AN hose to male NPT. Why do they not have -12 an to female -12 an. I do not need the npt end unless that what goes into the fuel pump. I am totally lost with the braided hose.
[Re: D-50]
#1579336
02/15/14 07:58 PM
02/15/14 07:58 PM
Sammy
Wind Gap,Pa.
inlet and outlet from the pump are -12AN MALE you'll need a -12an to -10an O ring male reducer for pump.
[Re: Sammy]
#1579337
02/15/14 08:08 PM
02/15/14 08:08 PM
D-50
North, Alabama
That is what I thought but for the braided nylon hose it only shows the fittings with the NPT on one end. Are the fittings for the stainless and nylon braided hoses different?
[Re: D-50]
#1579338
02/15/14 08:49 PM
02/15/14 08:49 PM
Sammy
Wind Gap,Pa.
No get the Russell black hose with blue tracer and get the Summit fittings. They work great in combination with each other.
[Re: D-50]
#1579341
02/15/14 09:18 PM
02/15/14 09:18 PM
Sammy
Wind Gap,Pa.
Thanks I just put the fittings you showed me in my summit cart. Will the summit hose ends work with the Russell black hose?
yes they are the easiest to use. just spray wd40 into the hose prior to tightening down on the threaded part of the fitting and make sure you blow out the hose prior to attaching everything to the regulator and carbs. \
[Re: Sammy]
#1579343
02/15/14 09:26 PM
02/15/14 09:26 PM
D-50
North, Alabama
Thanks for the help ... T&T starts in 2 weeks and I would like to get most of this done. I might run like it is now first then upgrade fuel system to see if it makes any difference. I am running a mechanical pump on the motor now with 3/8 rubber hose and Autozone $2 fuel filter.
[Re: Sammy]
#1579345
02/16/14 09:48 PM
02/16/14 09:48 PM
D-50
North, Alabama
Does anyone know if any of the nylon braided hose use this type of fitting? I noticed some of them use a crimp on fitting and I rather not use that kind.I was wanting to go nylon braided instead of stainless. I already have some of the fittings in this picture. Thanks..
[Re: D-50]
#1579348
02/17/14 10:53 PM
02/17/14 10:53 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Each line has specific fittings for them, they are mostly 37* with others types being JIS and SAE 45*. You need to find the right fittings per the hose. Aeroquip and stratoflex have interchangeable ends, but most others are not made to the same standard. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1579350
02/17/14 11:54 PM
02/17/14 11:54 PM
D-50
North, Alabama
Will the Summit brand fittings that I have work on any other braided line besides Summit hose? I guess I will have to start over with new hose ends. Do all the hose ends for the Nylon braided line crimp on or do they look like the pic. I posted above? On the Summit web sight they do not say which ends go with each hose..
[Re: D-50]
#1579351
02/18/14 01:37 AM
02/18/14 01:37 AM
Posts: 298 mt. pleasant, PA
Diplomat440
mt. pleasant, PA
I just put some lines together with Aeroquip startlite black hose with Summit ends It was my first time using braided hose of any kind, was very easy to work with and seemed like the hose and ends were compatible [image]http:// [/image]
[Re: Thumperdart]
#1579353
02/18/14 09:35 PM
02/18/14 09:35 PM
D-50
North, Alabama
Thanks for all the help maybe I can get figured out. I guess I will order some of the parts tonight.
[Re: hemi-itis]
#1579355
02/19/14 02:30 AM
02/19/14 02:30 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I use pvc cutters............... Just saw "bleeding" ya, no more stainless braided for me and of course the pvc cutters don`t work on that stuff but it`s excellent and quick on the nylon.
