I am upgrading my whole fuel system and I do not have any experience with any kind of braided line. Do the stainless and nylon braided line use the same kind of fittings on the end of the hoses. I may end up using stainless and nylon. I like the look of the black line better than the stainless and I already have some fittings but I will need to get more. I am going to a 1050 carb and I already have a MagnaFuel pump and a Holley billet regulator, I just got to plumb everything.Thanks for any help or suggestions.....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
