sealing header bolts for water leaks? #1579211
02/15/14 12:38 PM
02/15/14 12:38 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
So far we've tried dry.. then teflon tape. Also tried bars leaks and a pellet type of stop leak. Still leaks on at least 3 of the bolts.
We're using the same size bolts we used in the past with no leaks, only difference is that maybe the threads were cleaned out while having a valve job done.
So, if an engine is in-car, with water in it, what is the best sealant method for header bolts? We cannot use studs
Re: sealing header bolts for water leaks? [Re: Exit1965] #1579212
02/15/14 12:45 PM
02/15/14 12:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Drain the water down... then use high temp silicone
and let it set up
EDIT
Also spray the bolt holes out with brake clean
Re: sealing header bolts for water leaks? [Re: MR_P_BODY] #1579213
02/15/14 01:17 PM
02/15/14 01:17 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
When I ran all bolts I used silver anti sieze.It didnt leak.We run studs now.Only place I have a bolt is where the studs wont work.Rocky
Chrysler Firepower
Re: sealing header bolts for water leaks? [Re: Exit1965] #1579214
02/15/14 03:11 PM
02/15/14 03:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Studs and silicone.................
Re: sealing header bolts for water leaks? [Re: Thumperdart] #1579215
02/15/14 03:28 PM
02/15/14 03:28 PM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
I use high temp red RTV. Like they said above, drain the water down first.
I usually goop a bit on the end, and along the threads, then let it squish out and wipe off the extra before it drys.
Works fine on two of my cars that use all bolts on the headers.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: sealing header bolts for water leaks? [Re: GTSDave] #1579216
02/15/14 03:48 PM
02/15/14 03:48 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Plumbers run into this problem all the time and for years have been using pipe/thread sealant.
Re: sealing header bolts for water leaks? [Re: Exit1965] #1579217
02/15/14 04:17 PM
02/15/14 04:17 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Permatex Hi-temp thread sealant on a stainless bolt...
Re: sealing header bolts for water leaks? [Re: Exit1965] #1579218
02/15/14 06:59 PM
02/15/14 06:59 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Pipe thread sealant with Teflon or Permatex Aviation sealant.
Nautilus Racing-
Re: sealing header bolts for water leaks? [Re: Exit1965] #1579219
02/15/14 09:41 PM
02/15/14 09:41 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Masters metallic thread sealant.
Re: sealing header bolts for water leaks? [Re: Chris2581] #1579220
02/15/14 10:37 PM
02/15/14 10:37 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I like this the best. The one in the jar with the brush. No leaks ever.
Re: sealing header bolts for water leaks? [Re: Sammy] #1579221
02/15/14 11:08 PM
02/15/14 11:08 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Which, the aviation sealant(brown stuff), or the pipe thread sealant with teflon?
Re: sealing header bolts for water leaks? [Re: Exit1965] #1579222
02/15/14 11:38 PM
02/15/14 11:38 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
The permatex pipe thread sealant with Teflon, the white paste. once it hardens,it won't leak.
Just let it set up over night.
Re: sealing header bolts for water leaks? [Re: Thumperdart] #1579223
02/16/14 12:03 AM
02/16/14 12:03 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: sealing header bolts for water leaks? [Re: Sammy] #1579224
02/16/14 12:35 AM
02/16/14 12:35 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
"The Green Stuff" pipe dope works even better. It's high temp. Get it at the hardware store.
Re: sealing header bolts for water leaks? [Re: drew72] #1579225
02/16/14 02:01 AM
02/16/14 02:01 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Guys, the whole purpose of Teflon is "high temp"! They don't make no-slip frying pans with Teflon because it's slippery, they make it with Teflon because it can take the heat!
Re: sealing header bolts for water leaks? [Re: Exit1965] #1579226
02/16/14 02:02 AM
02/16/14 02:02 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I usually use the teflon on the intake bolts and the Permatex Aviation on the header bolts,but I have used both either way with great results.
Nautilus Racing-
Re: sealing header bolts for water leaks? [Re: Stanton] #1579227
02/16/14 02:01 PM
02/16/14 02:01 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
You don't have a clue, do you. Of course teflon is used in frying pans because it's slippery. THATS WHAT IT DOES! I used to use white teflon on copper pipe threads, then sweat the fitting next to it. The teflon would sometimes melt and form a leak. When I switched to the "Green Stuff" I have never had a leak since. So I guess it works.
Re: sealing header bolts for water leaks? [Re: drew72] #1579228
02/16/14 05:36 PM
02/16/14 05:36 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I use GM teflon sealer available at the Dealer. Since I started using it 10 years ago, I've never had another leak.
Doug
Re: sealing header bolts for water leaks? [Re: dvw] #1579229
02/16/14 06:57 PM
02/16/14 06:57 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Actually, I have a VERY good clue. Teflon has a melting point of 621 degrees. So while it may have melted in your plumbing exercise, it will generally hold up on a frying pan and most certainly as a sealant on any engine.
Furthermore, just about every plastic has a low coefficient of friction and some even lower than teflon, UHMW being one of them. What they lack however, is the high continuous operating temperature and melting point of teflon. So the MAIN reason teflon is used in frying pans is because of its ability to stand up to heat. And as a matter of fact, teflon is VERY SELDOM used "because its slippery". The fact is, teflon is very soft and cannot withstand much force before deforming. When you want "slippery" you use a dense plastic, like UHMW.
Re: sealing header bolts for water leaks? [Re: Stanton] #1579230
02/16/14 07:05 PM
02/16/14 07:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being that he tried the teflon already I really doubt
he will try it a gain
