Another valve cover question #1579043
02/14/14 07:51 PM
02/14/14 07:51 PM
central ohio
mopar rookie Offline OP
central ohio
I am starting to gather parts for my engine build. I am doing the Max wedge clone thing for my 64. I was planning on using the hughes roller rockers but not sure if a stock valve cover will work. Will a stock cover work with rollers? thanks for any info
Re: Another valve cover question [Re: mopar rookie] #1579044
02/14/14 09:26 PM
02/14/14 09:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
These are not stock but look a little close to them. They are an old Eddy chrome cover I painted and I use Hughes roller rockers. No problems as nothing hits with about .630 lift. Ron
Re: Another valve cover question [Re: mopar rookie] #1579045
02/14/14 11:36 PM
02/14/14 11:36 PM
Truckville, the capital of NY
85_Ram_4speed Offline
"Usually", if you remove the stock baffling shield from the valve cover, they will fit most roller rockers. But it is definatly a try it and see deal.
Outcast Dodge guy.
Re: Another valve cover question [Re: mopar rookie] #1579046
02/15/14 12:46 AM
02/15/14 12:46 AM
If you have a set of the real 426 M.W. OEM covers the Hughes rolleer rockera will probally work If you have a set of the stock hydraulic lifter motor valve covers they probally will have the adjusters hit the baffles I have stacked two thick cork valve cover gaskets together to help with this issue Try that first before bending or drilling holes in the baffles
