Re: How to do..assemble rear 8 3/4?
[Re: Cab_Burge]
#1578320
02/13/14 04:05 PM
02/13/14 04:05 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The factory spline ends were case hardened; more for wear than torsional strength.
[Re: Polarapete]
#1578322
02/13/14 04:46 PM
02/13/14 04:46 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
he told me that the Q&D method of testing for hardness on the recut splines is to take a file and run it across them, if it digs in it is too soft and will need a reheat. If the file skips across the splines it is good to go.
You don't learn that from a book. I gotta remember that one.
[Re: Commando1]
#1578326
02/14/14 10:55 AM
02/14/14 10:55 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Sounds like the gears are setup and ready to drop in.If thats the case assembley is pretty easy.Worst part would be installing the seals for the axles.Rocky
Chrysler Firepower
[Re: Supercuda]
#1578328
02/14/14 11:00 AM
02/14/14 11:00 AM
Commando1
What are some tips putting this thing together?
Buy the book linked above, buy the FSM, rear both till you understand it generally, then ask for tips. Right now you don't know enough to know what to ask.
Only tip you got that you can use right now is to pay someone else to do it.
Thank you........
