Page 4 of 8 1 2 3 4 5 6 7 8
Re: why the hatred for the eddy 750 carb [Re: gdonovan] #1577842
02/15/14 04:30 PM
02/15/14 04:30 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I find it amusing that people will spend vast amounts of time on Holley carbs "drilling this circuit" or "swapping out this air bleed" or "trying this modification" but won't spend some time learning how AFB's work which are the simplest of devices.
BAM...
Re: why the hatred for the eddy 750 carb [Re: RSNOMO] #1577843
02/15/14 04:47 PM
02/15/14 04:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
BAM...
I've never drilled this or swaped air bleeds, as a matter of fact Most of the holleys I've run haven't even had air bleeds. I've swaped out Eddy 750's twice for 750 DP's, and a carter 625 comp series for a 750 and evey time the car dropped et w/ no other mods. Mild 440 w/ brand new Eddy 750 (tuned) went from 13.11 (at best) to 12.90 w/ a 20+y/o holley and a rebuild kit. 383 went from 12.89 to 12.68 with a 750DP tuned for a 360, and a 340 went from 14.20 to 13.82 w/ a 750HP.
Go to any car show and look under the hood and you'l find lots of Eddy/Carters, go to the track and look under the hood and you'll see lots of Holleys. Just how it is.
Re: why the hatred for the eddy 750 carb [Re: Mr.Yuck] #1577844
02/15/14 05:33 PM
02/15/14 05:33 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Your three examples trump everything that's been listed here???
I don't know how long gdonovan has been doing carbs, but I suspect a while...
I've been playing with Carter's for 35 years...
It's all been for naught???
Tell you what, come over here and walk through the pits at the Pure Stock Drags...
I'm sure you'll get any pertinent info you might need regarding Carter's if you don't like what you see here...
Re: why the hatred for the eddy 750 carb [Re: RSNOMO] #1577845
02/15/14 05:50 PM
02/15/14 05:50 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
A long time, hell I'm even factory Mopar trained for Thermoquads, Carter BBD's and Mikuni carburetors.
A lost art now, clearly some folks just want "bolt on and go" pieces that work "most of the time" fat and safe which is fine by me.
Gives me the advantage in a race.
Perhaps you could give these guys some advice, there seems to be some issues with an "out of the box" Holley.
https://board.moparts.org/ubbthreads/show...e=0#Post8038080
"I think its got a hemi"
Re: why the hatred for the eddy 750 carb [Re: Mr.Yuck] #1577846
02/15/14 06:00 PM
02/15/14 06:00 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I have a stock 1407 edelbrock carb on a street hemi with an m1 (crate engine intake)
It starts great, runs great, and is fast.
It has run 12.82 @ 107 mph 4120#
I suppose a holley would get me in the 11's!!!!
no but I bet it'd run 12.55 or better.
I run 12.50's @ 105 MPH
Re: why the hatred for the eddy 750 carb [Re: gdonovan] #1577847
02/15/14 06:07 PM
02/15/14 06:07 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Oh no...
I avoid Holleys like the plague...
Last one I messed with was after it caused an engine fire(imagine that)...
BBD's...
Memories...
(One of the first was on a 'Super-Six' many years ago...
In a '78 Fury...
That car would walk on a whole buncha' 318's)...
Re: why the hatred for the eddy 750 carb [Re: RSNOMO] #1577848
02/15/14 06:33 PM
02/15/14 06:33 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You are funny, sure any carb can be tuned. Seems like the only people here that can get them working are "experts". I'm no expert. I have used both (still have a Strip kit in the garage), the Holley works better for me and for MOST. Sure you can make anything run, how much time and labor? It's called pure stock for a reason, walk thru a any other line and you'll see mostly Holleys or Holley based carbs. And what examples do you have? One artical that used a 100 different combos? Or the guy that has two carters? Have you ever raced a car one weekend w/ one carb and another the next? I took an old beat up Holley I bought for $30 rebuilt it almost to stock and ran better et and MPH than an Eddy I (and a master mechanic friend) spent many track hours tuning. I was very happy when the car went 13.11. But even happier when it went 12.90.
Re: why the hatred for the eddy 750 carb [Re: gdonovan] #1577849
02/15/14 06:35 PM
02/15/14 06:35 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The problem is there are more people that think they are sealed units than don't.
Then they are very much in the wrong hobby and are in the vast minority, perhaps its just were you live.
Gary, I will say, even in these parts there are a lot of people with older cars who don't work on them, and certainly many who won't open up a carb. Some of them are my friends, and no matter how much I try I just can't get them to open up their carbs, recurve their distributors, etc.
I had a friend with the 750 Eddy on his Road Runner. It ran OK, but generally felt flat and lacked sharp response, no matter what was done to it.
Another buddy who HATES Holleys used to have an 800 and 850 Double Pumper on his high 11 second dart. He swapped to an Eddy 800 when they came out and said that the difference in throttle response was insane. He had played with the Holleys alot and the Eddy killed it OOTB. In fact, he refuses to touch anything on the 800 because he doesn't want to screw up what he has. I myself prefer Holleys, but I value his opinion. And I've been in the car, it hits like a MFer when you snap the throttle open from a roll.
My first friend swapped his 750 for an 800 AVS on his Road Runner and it ran much better right OOTB and even better with tuning. It is MUCH thirstier though, but who cares about MPG.
I generally like Holleys but if given a Carter/Edelbrock I don't really care, they all need fine tuning and all can work well. I think the issues with the 750 stem from the calibrations internal to the carb. But one thing is for sure it seems much more troublesome than most other carbs.
Re: why the hatred for the eddy 750 carb [Re: RSNOMO] #1577850
02/15/14 06:37 PM
02/15/14 06:37 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Oh no...
Sorry, I meant folks like Mr.Yuck.
I have three Holley's I fool about here (an early street avenger 670, a race 950 and a tricked out discontinued 4010) and try to keep an open mind, you never know when a better mousetrap will come along.
Anything can be made to make a car run and run well, just need to understand what the trade offs are and how they work of course.
Re: why the hatred for the eddy 750 carb [Re: GTX MATT] #1577851
02/15/14 06:45 PM
02/15/14 06:45 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
This isn't limited to carburetors as you noted, when I was running Relentless Performance there was a sizable number of people who would just throw a car together and declare it done.
Tweaking the cam timing, distributor timing, fuel pressure, injector size, etc, etc was a concept they could or would not embrace.
In my experience that's where the real gains are, honing the car till it runs its best. At the other end of the spectrum, I attended a dyno event in Ohio where I worked on a guys calibration and made over 30 pulls!
There was literately nothing left on the table when we were done.
Re: why the hatred for the eddy 750 carb [Re: Mr.Yuck] #1577852
02/15/14 07:59 PM
02/15/14 07:59 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
There are multiple examples of Carter 'performance' on this thread from a wide range of different outlooks...
One more ain't gonna change your mind...
So, I'll leave you with this...
ONE example(like I alluded to above)...
Me...
20 years of 'test and tune'...
Actually, very little tune, but lotsa' test...
In a much wider range of circumstances than a car making passes at WOT and going home...
Cold-Idle;fast-idle;curb-idle,off-idle transition;low-speed cruise;high-speed cruise;WOT...
Together with extreme time in traffic in very hot temps...Extended high-speed cruise...A little street runnin'...And even some passes at the strip...
20,000 miles worth...
All with a 750 over a 440 with a 484/284 hydraulic...
Some minor playtime with the rods and springs...
Very little with jetting...
Beyond that, just a check of specs and adjustments...
It's performed above and beyond expectation...
In harsh conditions, and a cocktail to contend with today's sh%#&y 'fuel'...
It's been there 20+ years...
It's staying right there...
Re: why the hatred for the eddy 750 carb [Re: dustergirl340] #1577853
02/15/14 08:01 PM
02/15/14 08:01 PM
Onalaska, Wi
sixtyninefuchs Offline
Onalaska, Wi
You win the race.......but I got ya by exactly 100hp
3200# duster 105mph = 293hp........4120# charger 107mph = 393hp
750 edelbrock can support decent power if you can actually tune your car.
Re: why the hatred for the eddy 750 carb [Re: sixtyninefuchs] #1577854
02/15/14 08:22 PM
02/15/14 08:22 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
AFBs are for street rods and cruisers, holleys are if you want performance. You will ALWAYS leave something on the table with an AFB.
Re: why the hatred for the eddy 750 carb [Re: sixtyninefuchs] #1577855
02/15/14 08:28 PM
02/15/14 08:28 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Sounds about right. I don't really care about horsepower numbers, just ET and MPH, and mine's a pretty fat Duster at 3,450 pounds, but yeah, still 670 pounds lighter than yours.
Re: why the hatred for the eddy 750 carb [Re: dustergirl340] #1577856
02/15/14 08:33 PM
02/15/14 08:33 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
My A-body was 3150 with me behind the wheel...
A little 'weight ' in the boot???
Re: why the hatred for the eddy 750 carb [Re: CokeBottleKid] #1577857
02/15/14 08:49 PM
02/15/14 08:49 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I'll repeat, ahem.
http://www.moparts.org/Tech/Archive/bb/25.html
The difference between the best Holley and the best Carter was 6 hp and the best Carter number beat out several of the Holley carburetors. And from the looks of things aside from a rejetted AVS the Carters had no tuning done while a few of the Holleys were modded.
Its a poor musician who blames the instrument.
Re: why the hatred for the eddy 750 carb [Re: RSNOMO] #1577858
02/15/14 09:09 PM
02/15/14 09:09 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Our '76 Dart weighs 3,400 pounds. Our '72 Challenger weighs 3,340 pounds. lol...the later A-bodies are pretty heavy. But our '65 Dart should weigh in at 2,900 race weight.
Re: why the hatred for the eddy 750 carb [Re: dustergirl340] #1577859
02/15/14 10:52 PM
02/15/14 10:52 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
My 70 duster 383 auto 8 3/4 all steel one car seat and roll bar weighted 2980. What you got lead floor mats?
Re: why the hatred for the eddy 750 carb [Re: cudaman1969] #1577860
02/15/14 11:00 PM
02/15/14 11:00 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
lol! No lead floor mats or roll bar. And it's a small block! No Jimmy Hoffa in the trunk either. I actually thought maybe the first scale was wrong but I weighed it again at Norwalk and it was within 10 pounds of the first scale... :/
Re: why the hatred for the eddy 750 carb [Re: dustergirl340] #1577861
02/15/14 11:23 PM
02/15/14 11:23 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
My '74 Duster is 3600 lbs with me on board, they are a tad on the porky side and that is with aluminum rims.
