Page 2 of 8 1 2 3 4 5 6 7 8
Re: why the hatred for the eddy 750 carb [Re: Mr.Yuck] #1577802
02/12/14 02:05 PM
02/12/14 02:05 PM
Aurora, Oh.
max_maniac Online happy
max_maniac  Online Happy
Aurora, Oh.
WOW ----
Look under the hood of just about any Mopar NSS car and you will find the 750's or the 800's. I'm talking cars that can run an index anywhere from a 12.50 et in 1/4 mile to an 8.75 et in the 1/4 mile
They work fine on my car and I run 9.60's and the most I have done with them is maybe change the jet size and the rods to be used. I also know of a few that have changed to a Holley from the 750 and actually went back to the eddy's. I also run one on my 70 Challenger 440 street car with no issues.
Russ
yes that's because you run TWO and you HAVE to use them. If you were able to run two holleys in NSS you would and your times would be better.
I can run 2 Holley's in AFX which is the 9.75 and quicker classes. No need to change them though as the eddy's are doing just fine - like I said even on cars going 8.75 and quicker!! There may be some gain in the Holley's but I don't think it would be significant enough to change an index by .25 et unless you were very close to start with.
Russ
Re: why the hatred for the eddy 750 carb [Re: max_maniac] #1577803
02/12/14 02:15 PM
02/12/14 02:15 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Anybody who has been to a Herb McCandless seminar at Carlisle should be able to cure that off idle stumble in about 10 minutes. He had the procedure printed out and available with the rest of the literature that he has available.
Kevin
Re: why the hatred for the eddy 750 carb [Re: Twostick] #1577804
02/12/14 02:35 PM
02/12/14 02:35 PM
I'm sure Eddy still makes two different version with two different part numbers for there 500 CFM to the 750 CFM Carter type replacement carbs., performance with manual chokes and smoggers with electric chokes
Re: why the hatred for the eddy 750 carb [Re: Cab_Burge] #1577805
02/12/14 02:38 PM
02/12/14 02:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They do, but my understanding is that the only differences are the chokes and the jets/rods/springs. Castings are the same.
I like these carbs I have 4, two 650's and two 750's, one of each type (race and smog).
Don't be the exception.
Re: why the hatred for the eddy 750 carb [Re: Supercuda] #1577806
02/12/14 04:21 PM
02/12/14 04:21 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Performer 750 -
Thunder series
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: why the hatred for the eddy 750 carb [Re: MOPARMIKE69] #1577807
02/12/14 05:05 PM
02/12/14 05:05 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
He never did say which series he had.
Re: why the hatred for the eddy 750 carb [Re: Mr.Yuck] #1577808
02/12/14 05:47 PM
02/12/14 05:47 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
WOW ----
Russ
Not true, we can run Holleys. They aren't any faster. Guys that use Holley's claim better 60 ft. The difference isn't much .02-.03. In my experience the Eddys out MPH the Holleys. Either way they're very close.
Doug
Re: why the hatred for the eddy 750 carb [Re: dvw] #1577809
02/12/14 05:52 PM
02/12/14 05:52 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Doug
I know a few NSS racers and they cannot run Holleys, at least not on a wedge mopar.
Re: why the hatred for the eddy 750 carb [Re: president61] #1577810
02/12/14 06:18 PM
02/12/14 06:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My dislike of all the Carter AFB based carbs is the lazy accelerator pump, way too much throttle travel before you get a healthy
Holley pump shots are more positive.
Re: why the hatred for the eddy 750 carb [Re: John_Kunkel] #1577811
02/12/14 06:43 PM
02/12/14 06:43 PM
P
Paul_Fancsali Offline
P
I have used the AFB series and they are best suited for putting around I will not even think about running one any more. I own and have Carter AVS {good carb} TQ good when worked on Q jet Good when worked on. Holleys in 600DP -650DP 750DP and 800DP and 650 DP spread bore. 600-650-750 vac secondary. I have run them all and settled into the 650DP and 750 DP and for winter the street avenger 750. The AFB is one of all tested and used to never run as good as holley or the other's for that matter
Re: why the hatred for the eddy 750 carb [Re: Paul_Fancsali] #1577812
02/12/14 08:11 PM
02/12/14 08:11 PM
Central NC
gch Offline
gch  Offline
Central NC
My only experience with them is 20 years ago I bought a manual choke 750 and tuned it death.It seemed to run well enough but I tried a 750 holley vacuum secondary and went .2 quicker in the 1/8 mile on a warmed up 440.
I think they are well suited to milder engines and for the crown that likes an electric choke on a cruiser.Never considered them a max performance carb after that.
I still have that same holley and it is currently on a stroked 351 windsor in a mustang of a buddies.The edelbrock is long gone.
Re: why the hatred for the eddy 750 carb [Re: gch] #1577813
02/13/14 12:19 AM
02/13/14 12:19 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Man has always been afraid of the unknown. Learn how a carb works then you know what to change for your app.
Re: why the hatred for the eddy 750 carb [Re: president61] #1577814
02/13/14 03:52 AM
02/13/14 03:52 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
over the last few years been seeing some negative comments about the eddy 750 carb. whats wrong with them? was thinking of getting one for my fury
The few that I have used were OK. The float level adjustment is really important on those carbs, and the only way to adjust it is by removing the top.
When tuning them, it is really tempting to just throw different rods at it, which is more likely to get the carb out of tune, then changing the jets.
Re: why the hatred for the eddy 750 carb [Re: 451Mopar] #1577815
02/13/14 04:04 AM
02/13/14 04:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The few 750's I delt with were all lean the way they came. I did some tunning and they worked fine after that. Here is what my brother says about them as he runs 2 of them on his 64 Fury wedge NSS car. He is not crazy about running just one on a car but he loves running two of them on his car. Ron
Re: why the hatred for the eddy 750 carb [Re: 383man] #1577816
02/13/14 04:16 AM
02/13/14 04:16 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My Carter Comp AFB that I had on my 383 would alaways run lean no matter what pump, nozzles, jets or rods, then I adjusted the float level higher than spec so the bowls would have more fuel in them, and it finally went rich. After fixing the float level issue, I ended up back to almost the stock jetting.
Re: why the hatred for the eddy 750 carb [Re: 451Mopar] #1577817
02/13/14 12:21 PM
02/13/14 12:21 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I also have a pair of Carter Comp 750s on a blown small block. After purchasing a O2 I found that to get them to 11.8-1 F/A all that was required was stock jetting with only a metering piston spring change.
Doug
Re: why the hatred for the eddy 750 carb [Re: dvw] #1577818
02/13/14 05:22 PM
02/13/14 05:22 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I've tuned and had good luck with other Eddys, AVS, TQ, and Holley offerings. The 750 Eddy was trouble on any number of engines. They just don't seem to respond to changes like other carbs. You can get them to run better after some work out of the box, but not a easy as virtually any other carb. Then you might even be lucky enough to get one that has mystery problems with signal. I would rather put a carb that works right on it and be done. No reason to fumble around tuning a carb when you could be driving the car.
I want my fair share
Re: why the hatred for the eddy 750 carb [Re: president61] #1577819
02/14/14 02:33 AM
02/14/14 02:33 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
Used a 1407 Eddy on my built 360 1970 Duster and it ran great. Ran it with a 1" 4 hole spacer on a Weiand dual plane high rise intake. Motor had a 280H CompCam and I bumped the intial timing up to 20 degrees. No hesitation at all at any throttle position. Gas mileage wasn't great but who cares.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: why the hatred for the eddy 750 carb [Re: MY340] #1577820
02/14/14 08:46 AM
02/14/14 08:46 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I used to be all about Holley...had a 2bbl 500, a 4bbl 390, an 800...They started stumbling over each other...the 500 and the 390 were in different stages of a Mod Slant 6. I couldn't get the curve correct but an OOTB Eddy 500 took care of it and then some fine tuning down the road.
70 Charger with the 800 Holley, Choke horn milled off, left me stranded one too many time to the point where I had it professionally rebuilt to no avail. I had to get that Charger to a car show...removed the 500 from the slant, bolted it to the 440 and it was NIGHT AND DAY and I was under carb'd.
When we were finishing up the 69's restoration, we opted for the 750 Eddy. It ran and performed, always turnkey, never had to tinker with it. The thing most people forget when installing a carb is A/F ratio...Drill your exhaust people, pay the money for the Wideband. You'll save time and money in the long run.
the 750 is now on a friends car and it woke up his 58 Plymouth from the Holley that was on there. my 69' 440 has Dual 500s now and running sweet....I can press the pedal so far and go for a nice drive....and if I wanna get stupid I can go sideways with all 8 dumping fuel in )
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: why the hatred for the eddy 750 carb [Re: Pyper70] #1577821
02/14/14 10:37 AM
02/14/14 10:37 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Don't even need that, I have been tuning cars with "narrow band" sensors since 1992. (still have the K&N 02 gauge in the GTX where is has been for the last 22 years)
Even on the turbo cars running 30+ psi been using the narrow band with great success and if you screw up at 30 psi you end up with ashtrays.
"I think its got a hemi"
