Page 1 of 8 1 2 3 4 5 6 7 8
why the hatred for the eddy 750 carb #1577782
02/12/14 03:06 AM
02/12/14 03:06 AM
minnesota
P
president61 Offline OP
P
minnesota
over the last few years been seeing some negative comments about the eddy 750 carb. whats wrong with them? was thinking of getting one for my fury
Re: why the hatred for the eddy 750 carb [Re: president61] #1577783
02/12/14 03:13 AM
02/12/14 03:13 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I've been running one for over 20 years with no issues...
Some on here claim there's a porosity issue with the newer castings...
Re: why the hatred for the eddy 750 carb [Re: president61] #1577784
02/12/14 03:43 AM
02/12/14 03:43 AM
Yes there's been alot of neg reports on them. Enough that I thought there was a problem on the 750 assembly line at edelbrock (wrong sized drilled passages or?). I just bought one for $25 that the guy said was running OK in the past. I went ahead & bought a kit & a strip kit for it. I'll know soon.
Re: why the hatred for the eddy 750 carb [Re: RapidRobert] #1577785
02/12/14 03:51 AM
02/12/14 03:51 AM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
It seems its not well designed to give a good AFR curve on most engines
Re: why the hatred for the eddy 750 carb [Re: GTX MATT] #1577786
02/12/14 04:00 AM
02/12/14 04:00 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I've had a couple and they ran great. Seems like they may not like the vacuum signal from some engines. It's not really a race carb as much as it's a good street carb for a mild big block...I paid $50 for one that would not run right on the previous owner's car. Ran great on mine...
Re: why the hatred for the eddy 750 carb [Re: Jim_Lusk] #1577787
02/12/14 10:53 AM
02/12/14 10:53 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Bought my first one in 88 or so for exactly this application, still works fine.
Don't be the exception.
Re: why the hatred for the eddy 750 carb [Re: Supercuda] #1577788
02/12/14 11:58 AM
02/12/14 11:58 AM
Minnesota
peabodyracing Offline
Minnesota
I second that emotion. Have had two in recent years; one on a reasonably warmed over 440. Could not get it to quit a slight surging when driving at highway speeds. I tried everything I could think of. Finally put a 750 Holley on the car.
Second one I had was on a warmed over 350 Chevy. That carb worked perfectly, everytime, all the time, no matter what. My son had the car for a couple years and would always forget to put fuel stabilizer in when storing for the winter and it still worked perfectly.
Lead, follow or get the hell out of the way
Re: why the hatred for the eddy 750 carb [Re: Supercuda] #1577789
02/12/14 11:59 AM
02/12/14 11:59 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
They aren't bad, just not the best for most Big Block applications (at least not for anything other than a mild one) They work well for SB's and driver BB's.
Coming soon!!!!
Re: why the hatred for the eddy 750 carb [Re: president61] #1577790
02/12/14 12:05 PM
02/12/14 12:05 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Had one on my Duster's original 340 and hated it...car never ran right no matter the tuning we did. Bolted on a 650 Holley and it was like night and day, throttle response was better and the car picked up 4 tenths with the (untuned) Holley. Never looked back.
As mentioned, for a mild street driver they can be decent. Had a 360 with one on it and it ran fine. I think there are better choices out there though.
Re: why the hatred for the eddy 750 carb [Re: Mr.Yuck] #1577791
02/12/14 12:08 PM
02/12/14 12:08 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I had a friend that bought one for a resto on a 68 charger. It had a bad stumble off idle that I could not resolve. I did not get to work on it enough to give up but he decided to replace it and the new carb worked fine. I don't know what he put on it but it satisfied him.
Re: why the hatred for the eddy 750 carb [Re: fastmark] #1577792
02/12/14 12:15 PM
02/12/14 12:15 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
So the Edelbrock option here is either 650 or 800??
Re: why the hatred for the eddy 750 carb [Re: dustergirl340] #1577793
02/12/14 12:17 PM
02/12/14 12:17 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Same here.
Installed a shiny new Edelbrock 750 on a street/strip 440 4 speed and it NEVER ran right.
Constant stumble off idle, surging under load, TERRIBLE performance compared to my previous Holley 750 DP.
Called Edelbrock tech countless times changed rods, jets and springs over and over and in the end was drilling out emulsion tubes....
Edelbrock techs tried their best and actually sent me parts for free to try with no luck.
They finally admitted the carb was best suited for a stock to very mild small block.
Took the Edelbrock carb off and sold it to buddy who put it on his stock 350 powered truck.
Put the old Holley 750 DP back on and had it tuned and running perfect in 20 minutes....night and day difference in performance and drivability.
Live and learn....NO shiny Edelbrock carbs for me.
Re: why the hatred for the eddy 750 carb [Re: president61] #1577794
02/12/14 12:19 PM
02/12/14 12:19 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Which one are you talking about? The performer, or Thunder series?
Re: why the hatred for the eddy 750 carb [Re: floridian] #1577795
02/12/14 12:23 PM
02/12/14 12:23 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..i was told that the internal design only responds well to a strong
vacuumm signal.
... not for long duration cams
Re: why the hatred for the eddy 750 carb [Re: 71birdJ68] #1577796
02/12/14 12:24 PM
02/12/14 12:24 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
The one I tried was #1407.....probably around 10 years ago.
Cam was Mopars's .509 hydraulic
Re: why the hatred for the eddy 750 carb [Re: president61] #1577797
02/12/14 12:50 PM
02/12/14 12:50 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Recently, success with the CarterBrocks has been hit and miss. When they work right, they are very dependable. But when they don't, they can be a pain to get right. And tuning parts are more difficult to come by for a lot of guys.
The two things that I have had to do to most of the CarterBrocks that I have messed with are; changing to stiffer step-up springs and adding weight to the counterweights on the secondary air valve.
If you can find a clean used one for a good price, it might be worth it to try one. But if I were going to spend the coin for a new street carb, it would be the new Street Demon.
Master, again and still
Re: why the hatred for the eddy 750 carb [Re: can.al] #1577798
02/12/14 01:10 PM
02/12/14 01:10 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
vacuumm signal.
Ran one on my 440 with a .590, worked great (I do my own jetting though). Its now on my Duster with a 5.9 magnum.
"I think its got a hemi"
Re: why the hatred for the eddy 750 carb [Re: gdonovan] #1577799
02/12/14 01:51 PM
02/12/14 01:51 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
vacuumm signal.
I run a pair of them on my 572. Cam is 285@.050". They idle great with the stock primary calibration and 2 steps up in the secondarys. Power? It's been 9.25@147, 3340lbs.
Doug
Re: why the hatred for the eddy 750 carb [Re: gdonovan] #1577800
02/12/14 01:51 PM
02/12/14 01:51 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
WOW ----
Look under the hood of just about any Mopar NSS car and you will find the 750's or the 800's. I'm talking cars that can run an index anywhere from a 12.50 et in 1/4 mile to an 8.75 et in the 1/4 mile
They work fine on my car and I run 9.60's and the most I have done with them is maybe change the jet size and the rods to be used. I also know of a few that have changed to a Holley from the 750 and actually went back to the eddy's. I also run one on my 70 Challenger 440 street car with no issues.
Russ
Re: why the hatred for the eddy 750 carb [Re: max_maniac] #1577801
02/12/14 01:55 PM
02/12/14 01:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
WOW ----
Russ
yes that's because you run TWO and you HAVE to use them. If you were able to run two holleys in NSS you would and your times would be better.
