Re: 2004 Dodge 3500 Trailer turn signal
[Re: toomanymopars]
#1577692
02/12/14 12:50 AM
02/12/14 12:50 AM
Posts: 43,607 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
My 04 has been like that for 8 years now. I was told it was the FCM (forward control module) under the drivers side battery box, but finally changed it out this year with no change. It is probably a wiring issue but I haven't found it yet, I am just more careful when turning right. Now I see that it might be the TIPM? Let me know if it fixes your problem...
JB Rhinehart, Realist
A-Body's RULE!
[Re: toomanymopars]
#1577694
02/12/14 09:33 PM
02/12/14 09:33 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I know that there are separate fuses for the trailer...#46 and 47 I believe. Both are 15 amp fuses...have power on both sides of the fuse, so they are for sure good.
I am pretty sure that it is the TIPM, too, but looks like used ones are around $200 and up...fine if it fixes it.
Yes it is fuse #47. The front control module pin 34 ends a ground signal to the TIPM right turn relay #86 which causes the right turn relay to latch. Fused power From #47 fuse powers the relay #30 terminal and once latched sends power to #87 which is the right turn wire and it is light green[no tracer] in color. If I remember correctly the relay is incorporated into the TIPM module and is not service able.
