426 Hemi auto trans dipstick mounting location #1577656
02/11/14 10:04 PM
02/11/14 10:04 PM
tennessee,usa
mattsmopars Offline OP
tennessee,usa
I have been working on replacing the exhaust gasketson my 68 super bee. It is a 426 hemi 727 automatic. It has been a few weeks in between removing them and installing them so my mind is a little faded.
I am wondering about the upper mounting point on the trans dipstick. I think it would go against the exhaust manifold and use the rear manifold bolt to attach it. As best I remember when I pulled it off it had a spacer behind it and was using the upper rear hole in the head above the rear manifold bolt. To me the bracket on the tube appears to have been bent upward to use that hole in the head. So I need to know what is correct so I can finsih the install. If anyone can help or mighthave a picture I would apprecaite it alot.
Thanks, Matt
Re: 426 Hemi auto trans dipstick mounting location [Re: mattsmopars] #1577657
02/11/14 10:39 PM
02/11/14 10:39 PM
tennessee,usa
tennessee,usa
I also guess there is the fact that some one might have modified my dipstick tube. Here is a picture.
Matt
Re: 426 Hemi auto trans dipstick mounting location [Re: mattsmopars] #1577658
02/11/14 10:47 PM
02/11/14 10:47 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
1971 HEMI E BODY REGISTRY
Re: 426 Hemi auto trans dipstick mounting location [Re: hemicar1971] #1577659
02/11/14 10:50 PM
02/11/14 10:50 PM
tennessee,usa
tennessee,usa
I am thinking mine has been modified. I saw that one on ebay and that was what I figured. Thank you.
Matt
Re: 426 Hemi auto trans dipstick mounting location [Re: mattsmopars] #1577660
02/11/14 10:51 PM
02/11/14 10:51 PM
tennessee,usa
tennessee,usa
another
Re: 426 Hemi auto trans dipstick mounting location [Re: mattsmopars] #1577661
02/11/14 11:02 PM
02/11/14 11:02 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Re: 426 Hemi auto trans dipstick mounting location [Re: hemicar1971] #1577662
02/11/14 11:39 PM
02/11/14 11:39 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
The automatic dipstick tube and dipstick are hemi specific. The tube mounted to the manifold; the rear stud that fastens the heat tube to the manifold. Also the dip stick is 2 pieces and riveted together.
Re: 426 Hemi auto trans dipstick mounting location [Re: JRepucci] #1577663
02/12/14 02:09 AM
02/12/14 02:09 AM
I don't rememeber any of the stock street Hemi dipstick tubes mounting to the exhaust, the ones I remember where attached to the passenger side trans bellhousing bolts or had a small tab on the botom of the dipstick that was held into the trans case by a 5/16 bolt Maybe not I only worked on a few of the originals, not all years either
Re: 426 Hemi auto trans dipstick mounting location [Re: Cab_Burge] #1577664
02/12/14 06:47 PM
02/12/14 06:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '64-'65 Race Hemi tubes mounted to a bellhousing bolt, the Street Hemi mounts to the exhaust manifold.
Re: 426 Hemi auto trans dipstick mounting location [Re: John_Kunkel] #1577665
02/12/14 10:25 PM
02/12/14 10:25 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Street hemi
Re: 426 Hemi auto trans dipstick mounting location [Re: mattsmopars] #1577666
02/13/14 01:05 AM
02/13/14 01:05 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
I hope not to hijack the thread, but when one has headers inlew of exhaust manifolds and intake heat tubes on their 426 Hemi, can one use a regular B/RB auto dipstick/tube?
Thanks in advance...
Troy
Houston Mopar Connection Club
Re: 426 Hemi auto trans dipstick mounting location [Re: hemi68charger] #1577667
02/13/14 10:24 PM
02/13/14 10:24 PM
tennessee,usa
tennessee,usa
I would say if you had headers and no intake heat tubes or choke tubes then you should be fine with the B/RB regular 727 dipstick.
But that would just be my guess. It is pretty crowded with all of the heat tubes, dip stick , and choke tubes.
Thanks for the pictures! I got the one on my car back on how they had it but it has been modified.
Matt
Re: 426 Hemi auto trans dipstick mounting location [Re: hemi68charger] #1577668
02/14/14 02:34 AM
02/14/14 02:34 AM
I don't think so, but maybe with the right year B body B/RB motor 727 dipstick application it wil clear the Hemi heads and firewall
