S & W a body roll cage #1576877
02/10/14 09:59 PM
02/10/14 09:59 PM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
Just curious if anyone has any pics of an s & w 8 point cage installed in an a body. Mine is a 71 dart swinger, but im mostly just curious about the bars that they offer to save the back seat. Or the ones that don't. either way, would love to see some pics. Cant find much on people who have actually installed them, but from what I have read they are supposed to be one of the better fitting bars. Was also considering the autoweld kit, but cant find anyone who has put one in. Im thinking the jegs kit is out from what I have read. Anyways, thanks for the time and any help in advance.
Re: S & W a body roll cage [Re: skj283] #1576878
02/10/14 11:27 PM
02/10/14 11:27 PM
Eastern Shore of Maryland
N
nasty68 Offline
nasty68  Offline
N
I have a S&W 10 pt cage in my dart. I don't have any pics on this computer so i can't help you there. The cage went in nice. Bars are longer than needed to get the fit you want and are notched. I got the bars that allow you to keep your back seat. They follow the roof line and drop down thru the speaker holes in the back deck.
68 dart, 383, 727
2013 Jeep JKU Sahara
Re: S & W a body roll cage [Re: nasty68] #1576879
02/11/14 12:19 AM
02/11/14 12:19 AM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
that's kinda what im lookin for. I may wanna use those bars for my upper shock mounts and im wanting them to make a bend and go basically straight down where they meet the frame. it's like impossible to find pics of cars that have had them put in. mostly all I can find is people debating which brand to buy, and someone saying take it to a chassis builder. thanks for the input!
Re: S & W a body roll cage [Re: skj283] #1576880
02/11/14 10:24 AM
02/11/14 10:24 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I had a eight point s&w kit in my car. Fit nice but you will need to get rear bars custom bent to use for mount braces. I don't have any pics as I have cut that one out and have 12 point cage in car.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: S & W a body roll cage [Re: 1967dartgt] #1576881
02/11/14 11:19 AM
02/11/14 11:19 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I have a 10 point in my Dart. But I don't have the rear bars that saved the rear seat. I don't have pics on this computer. I can post some when I get home tonight.
Re: S & W a body roll cage [Re: 70HemiGTX] #1576882
02/12/14 08:53 PM
02/12/14 08:53 PM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
ya I would like to see how close the bar fits to the sides of the car. according to the dimensions that they gave me it looks like it would have at least 2 inches on each side of the bar. I'd kinda like a little tighter fit than that. also at the top id like to see how it follows the roof line. again the measurements make it look quite a bit narrower than it could be
Re: S & W a body roll cage [Re: skj283] #1576883
02/12/14 10:24 PM
02/12/14 10:24 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have the s&w bar in my car pm your email I send pics . I did the rear seat save option.
Re: S & W a body roll cage [Re: skj283] #1576884
02/12/14 11:09 PM
02/12/14 11:09 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have one in my Dart.
Re: S & W a body roll cage [Re: justinp61] #1576885
02/12/14 11:35 PM
02/12/14 11:35 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
2
Re: S & W a body roll cage [Re: justinp61] #1576886
02/12/14 11:44 PM
02/12/14 11:44 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
3
Re: S & W a body roll cage [Re: justinp61] #1576887
02/12/14 11:48 PM
02/12/14 11:48 PM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
thanks! two questions, is that how they wanted the bars in the trunk to attach, i.e. staggered like that, and how much room is there between the bar and the door jam. according to the measurements its almost 3 inches on each side, but urs looks pretty close.
Re: S & W a body roll cage [Re: skj283] #1576888
02/13/14 12:04 AM
02/13/14 12:04 AM
Pound, Va
Chris Vanover Offline
Pound, Va
May also check into a competition engineering, i put on of them in a nova and it fit really good for a kit.
Have used a sw and jegs kit before as well and like the C/E better.
Re: S & W a body roll cage [Re: Chris Vanover] #1576889
02/13/14 02:00 AM
02/13/14 02:00 AM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
pm sent scamp.
Re: S & W a body roll cage [Re: skj283] #1576890
02/13/14 08:16 AM
02/13/14 08:16 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I don't have mine staggered like that but we did increase the bend to the deg that the comp eng had the s&w was less. I don't know if this is true or not but I was told you are only allowed to have one bend on rear bar .
Re: S & W a body roll cage [Re: Scamp408] #1576891
02/13/14 09:27 AM
02/13/14 09:27 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
If I can get pictures up on here I will, but I used a jegs kit for a B-body I have an 1in between the sides and the bar ! It's very tight ! But I used the down bars for the halo for the back bars and had my chassie guy do one piece to get ride of the halo ( I don't like halos) then I went and bought a couple more bars to be able to do 7.50 cert ! Got the sfi book, it was worth it for the. Bars I would have had to move or fix from what I thought was legal and what was legal !
Re: S & W a body roll cage [Re: 70dusterjohn] #1576892
02/13/14 11:04 AM
02/13/14 11:04 AM
Deerfield, Ohio
Deerfield, Ohio
Re: S & W a body roll cage [Re: 70dusterjohn] #1576893
02/13/14 12:28 PM
02/13/14 12:28 PM
Tucson AZ,
MadMopars Online content
MadMopars  Online Content
Tucson AZ,
How low are you allowed to put the cross bar on the main hoop? I ask because there really doesn't seem to be a good way to get to the back seat once a cage has been installed. I'm guessing a removable cross bar won't fly. The pic above looks alot more friendly.
Re: S & W a body roll cage [Re: skj283] #1576894
02/13/14 12:56 PM
02/13/14 12:56 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I bent the bar in the trunk, it was going to hit the filler neck otherwise. The main hoop is a lot closer than 3", IIRC it's just over an inch.
No one rides in the back of my car, the bars are more dangerous than a crash would be IMO.
Re: S & W a body roll cage [Re: MadMopars] #1576895
02/13/14 12:56 PM
02/13/14 12:56 PM
Deerfield, Ohio
Deerfield, Ohio
It would depend if your using a FC cage like I am ! If that's the case it can be pretty low ! My sfi book is at home so I wouldn't be able to tell you for sure right now ! I know the nhra says that iirc it can't be low than 4 or 6 in where the belts come out the the seat ? As far as removable I'm not sure it would fly but I never tried so not sure ! I just figured only people getting in the back seat will be my kids, and they love to climb all over in there now. So it's not a big deal to me of them !
Re: S & W a body roll cage [Re: 70dusterjohn] #1576896
02/13/14 01:13 PM
02/13/14 01:13 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A normal 8.50 cage needs the cross bar with-in 6" of the top of your shoulders. It can not be removable. The kids love crawling over it, Heck I can crawl over it.
Doug
