Re: S & W a body roll cage
[Re: skj283]
#1576878
02/10/14 11:27 PM
02/10/14 11:27 PM
Posts: 116 Eastern Shore of Maryland
nasty68
I have a S&W 10 pt cage in my dart. I don't have any pics on this computer so i can't help you there. The cage went in nice. Bars are longer than needed to get the fit you want and are notched. I got the bars that allow you to keep your back seat. They follow the roof line and drop down thru the speaker holes in the back deck.
68 dart, 383, 727 2013 Jeep JKU Sahara
[Re: skj283]
#1576880
02/11/14 10:24 AM
02/11/14 10:24 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I had a eight point s&w kit in my car. Fit nice but you will need to get rear bars custom bent to use for mount braces. I don't have any pics as I have cut that one out and have 12 point cage in car.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 70dusterjohn]
#1576893
02/13/14 12:28 PM
02/13/14 12:28 PM
Posts: 1,291 Tucson AZ,
MadMopars
Tucson AZ,
How low are you allowed to put the cross bar on the main hoop? I ask because there really doesn't seem to be a good way to get to the back seat once a cage has been installed. I'm guessing a removable cross bar won't fly. The pic above looks alot more friendly.
[Re: skj283]
#1576894
02/13/14 12:56 PM
02/13/14 12:56 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
thanks! two questions, is that how they wanted the bars in the trunk to attach, i.e. staggered like that, and how much room is there between the bar and the door jam. according to the measurements its almost 3 inches on each side, but urs looks pretty close.
I bent the bar in the trunk, it was going to hit the filler neck otherwise. The main hoop is a lot closer than 3", IIRC it's just over an inch.
No one rides in the back of my car, the bars are more dangerous than a crash would be IMO.
