Re: Rocker Arms to tight? [Re: Mopar Guy] #1576813
02/11/14 04:25 PM
02/11/14 04:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not trying to be right but "been there done that" many, many times and I stand behind my "opinion" %100000000................I don`t EVER guess on ANYTHING car related but also understand I`m a nobody and that`s cool by me...........
Re: Rocker Arms to tight? [Re: Thumperdart] #1576814
02/11/14 04:31 PM
02/11/14 04:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well your guessing right now.... we have very little
facts about the build... no one said valve job was
done... was it .002 taken off the heads or .020..
it he measures first he will have a idea.. instead
of just throwing dollars at it
Re: Rocker Arms to tight? [Re: Thumperdart] #1576815
02/11/14 04:34 PM
02/11/14 04:34 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Thumper im no expert of any kind and im not trashing anybody just have an opinion and im still learning from my mistakes like i always have and guy´s like Smokie in his best D garage is the guy´s i try to learn from
Re: Rocker Arms to tight? [Re: Mopar Guy] #1576816
02/11/14 07:55 PM
02/11/14 07:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Why not remove the intake and measure the preload? Bend a couple pieces of thin wire 90* at the end, various thickness. Use them as a go/no go gauge between the retaining ring and lifter piston. For what its worth I've shimmed plenty of shafts due to milling. Have 3 cars running around right now. Big block with a small .460" hydraulic a 7000 rpm small block with a .540"/.570" @ 245* solid. For that matter my rocker stands for my T&Ds are shimmed .125" cause I was to cheap to buy another $400 set of pushrods. No issue with that one either. I actually mapped out the geometry change, we're talking about .010" difference in sweep across the valve at .800" lift.
Doug
Re: Rocker Arms to tight? [Re: dvw] #1576817
02/11/14 09:29 PM
02/11/14 09:29 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I dont think the OP has alot of wire with various thicknesses hanging around.
I myself am still waiting to hear how much the heads were shaved.
If its .010 bolt it up and go , if there was no valve job.
If its alot more then that, different pushrods or shims as you suggest. Shims with Stock steel heads have had some pedestal breakage issues.
The OP is supposed to respond back tonight, Im going to wait to see, he responded last night at 7.30 or so.
Re: Rocker Arms to tight? [Re: dvw] #1576818
02/12/14 12:33 AM
02/12/14 12:33 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Doug
Shimming rocker stands is one thing, shimming shafts is another. The rocker shaft is made to fit into the shaft mount, putting shims under the shaft will make the bottom of the shaft bigger therefore upon tightening spreads the shaft mount and splitting it.
Re: Rocker Arms to tight? [Re: pgccp] #1576819
02/12/14 01:20 AM
02/12/14 01:20 AM
After waiting several days to see where this post was going to end up at I suggest you take the intake manifold and intake valley pan off and remove the passenger side rocker shaft and rocker arms, also remove all the pushrods on the drivers side except for #1 cylinder, once that is done remove all the spark plugs and rotate the motor over so you get the motor stopped at Top Dead Center on the firing stroke on #1 cylinder(verify that location based off of the distributor rotor pointing at the #1 spark plug wire and the tinming mark on the crankshaft balancer ) once you get that done then put the drivers side rocker arm shaft and rocker arms with the two pushrods in place for that cylinder, torque them down to no more than 23 Ft. LBs Then you can look at the lifter to see how much the pushrod seat is down from the top of the retaining ring or clip. See if you can use a small paper clip and a large paper clip to make a L gauge out of to see if one of them will fit betwenn the pushrod cup in the lifter and the retainer, snap ring , keeper or what ever you want to call it . If a small paper clip will fit and large one won't your golden, if a large fits real loosely in between them you may need help in resolving the issue Maybe not If the large one fits you can try using different diameters of gas welding rod to measure with to find out exactly how much preload you have on those two lifters Don't you love working on motors that have been modified I do Good luck, let us know what you do and find out please
Re: Rocker Arms to tight? [Re: rowin4] #1576820
02/12/14 01:44 AM
02/12/14 01:44 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
I've used these for builds over the last 25 years.
http://chucker54.stores.yahoo.net/rocshafshim.html
Have never had a shaft crack or split. There is as much sectional area of the shim as there is of the pedestal. Therefore the load would be supported the same. Is the rocker geometry perfect,no. However availible small block rocker arms don't have perfect geometry either. Ideally with more lift the shaft should be lowered with a shorter pushrod. We're not talking Pro Stock. Will shimming work if the pushrod is a little long from milling or valve job, absolutely. Cab has the right idea to check it. Go from there.
Doug
Re: Rocker Arms to tight? [Re: dvw] #1576821
02/12/14 02:05 AM
02/12/14 02:05 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
In the past when I have had the problem with too much lifter preload with a hyd. cam in a mopar with all factory valve train components (solid pushrods),I have had great success with simply grinding the one end of the pushrod down a little to get the desired preload. Then sand it smooth and install the ground end in to the hardened cup of the lifter. A little time consuming, but works FINE. I have done this on several engines with NO problems. Its an old trick my dad showed me from back in the day when there were no rocker shaft shims. All you will be out is your time.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Rocker Arms to tight? [Re: 71yelladustr] #1576822
02/12/14 02:07 PM
02/12/14 02:07 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
If he is on this Site in the Race forums his engine/car means more to him than just a Daily driver and although it may never hit the Track I am sure he wants his "Pride & Joy" to be right.Adjustable Rocker arms is the only way to make it 100%right.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Rocker Arms to tight? [Re: MRMOPAR622] #1576823
02/12/14 02:30 PM
02/12/14 02:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You are wrong sir(read above post`s).............. That would be a horrible waste of money to know EXACTLY where each and every valve is lashed and to have the ability to tighten or loosen to your liking. Plus it sucks to put a nice new roller rocker(another waste of money)w/perfect geometry and less guide wear..............I mean why would anyone want to "step up" into the 20th century when you can guess and wonder................
Re: Rocker Arms to tight? [Re: MR_P_BODY] #1576824
02/12/14 11:02 PM
02/12/14 11:02 PM
in
P
pgccp Offline OP
pgccp  Offline OP
P
in
I want to thank everybody for the info. I jump the gun on this
I finally got back to the engine, I was going to try the paper-
clip and I notice that the cups are not into the body the intake is
not on the engine yet so I rotated engine again and re-check the
valves they are not to deep, adjustment seems good so everything
should be good. Thanks again for all the help to everybody. Bob
Re: Rocker Arms to tight? [Re: pgccp] #1576825
02/13/14 12:58 AM
02/13/14 12:58 AM
Do you know the name "Mr Murphy"? As in Murphy law You've met him now
Re: Rocker Arms to tight? [Re: pgccp] #1576826
02/13/14 01:57 AM
02/13/14 01:57 AM
Tucson AZ,
MadMopars Online content
MadMopars  Online Content
Tucson AZ,
At least now we can stop and start. .
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Rocker Arms to tight? [Re: MadMopars] #1576827
02/13/14 03:02 AM
02/13/14 03:02 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Hopefully everything works out for ya...............
