Rocker Arms to tight? #1576793
02/10/14 06:34 PM
02/10/14 06:34 PM
in
P
pgccp Offline OP
pgccp  Offline OP
P
in
Iam reassembling my 383 had heads plained ( not very much) rockers seem to be very tight on valves when valves are closed stock shaft and rockers, rockers are riding valve tips ok. push rods are tight on closed vales. Should I install shims and how much? Push rods should be able to turn on a closed valve? Thanks Bob
Re: Rocker Arms to tight? [Re: pgccp] #1576794
02/10/14 08:27 PM
02/10/14 08:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume your talking a hyd cam.... get one of the
valve on base and start pulling the shaft 1/4 turn
at a time on each bolt till the push rod turns freely
and count the 1/4 turns... then tell us.... if you
know how much you had the heads cut we can tell
Re: Rocker Arms to tight? [Re: MR_P_BODY] #1576795
02/10/14 10:23 PM
02/10/14 10:23 PM
in
P
pgccp Offline OP
pgccp  Offline OP
P
in
Thanks for getting back to me I will get the info tomorrow
can not remember the amount removed from the heads but it was not very much yes it is hyd lifters. Thanks again Bob
Re: Rocker Arms to tight? [Re: pgccp] #1576796
02/11/14 12:54 AM
02/11/14 12:54 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Did you also have a valve job? I have seen valves set so far into the seat that when the head assembly was put on the valves were open on the base circle, you might have the same problem.
Re: Rocker Arms to tight? [Re: pgccp] #1576797
02/11/14 01:43 PM
02/11/14 01:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , you do not install shims , shims are for correcting valve tip to rocker arm geometry , not making up for head/block milling.
It's a hyd. lifter not solid , the lifter should be compressed some and under that pressure the pushrod will not spin freely .
Re: Rocker Arms to tight? [Re: JohnRR] #1576798
02/11/14 01:50 PM
02/11/14 01:50 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
You didn't step up to a bigger cam did you?Best cure is to put adjustable rockers on it along with some lash caps.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Rocker Arms to tight? [Re: JohnRR] #1576799
02/11/14 01:53 PM
02/11/14 01:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
John is correct... no shims... IF it is compressed
to far then you need shorter push rods... does any
one know the dimension from the shaft center line
to the push rod center line(even a close spec)..
that will help also to figure out the compression
of the lifter... the reason I ask is I'm not home
to get any measurements or any books on hand
Re: Rocker Arms to tight? [Re: MRMOPAR622] #1576800
02/11/14 02:41 PM
02/11/14 02:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Exactly, no more bs guess work...............
Re: Rocker Arms to tight? [Re: Thumperdart] #1576801
02/11/14 02:56 PM
02/11/14 02:56 PM
dogdays Offline
dogdays  Offline
I keep thinking this: it's a hydraulic cam, right? There is supposed to be no lash in the system when the valve is closed, that's what the hydraulic lifters do.
There's a spring inside the lifter that pushes the cup up. If you had slop in the closed condition the pushrods would be too short.
The question is, what kind of preload are you getting on the lifters. In other words, how far down in the lifter is the pushrod pushing the cup?
R.
Re: Rocker Arms to tight? [Re: dogdays] #1576802
02/11/14 03:05 PM
02/11/14 03:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
R.
Correct..... the other guys are jumping the gun...
if its .010 to .015 farther down in the lifter it
wont matter... so why BUY rockers for no reason...
yes a adjustable push rod is the easy way but if he
doesnt have one then a little math works fine
Re: Rocker Arms to tight? [Re: pgccp] #1576803
02/11/14 03:16 PM
02/11/14 03:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Also.... NO the push rods should NOT turn... they
have pre-load on them pushing the lifter cup down in
which is what the hyd lifters need to make things
quiet
Re: Rocker Arms to tight? [Re: MR_P_BODY] #1576804
02/11/14 03:44 PM
02/11/14 03:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The reason for adjustable rockers Mike is to step up to the 20th century already.............
Re: Rocker Arms to tight? [Re: Thumperdart] #1576805
02/11/14 03:50 PM
02/11/14 03:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its STOCK.... I like spending others money also
Re: Rocker Arms to tight? [Re: MR_P_BODY] #1576806
02/11/14 03:52 PM
02/11/14 03:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I get it BUT Isky iron or a cheaper version takes the guess work out and you can even play w/preload like we used to at Pettis on the stockers.............
Re: Rocker Arms to tight? [Re: Thumperdart] #1576807
02/11/14 03:59 PM
02/11/14 03:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No I dont think you do get it... its STOCK... we dont
even know if he will EVER hit the track to see what
it might do..... I think you should buy a dana.. because
your 8 3/4 MIGHT blow up... get my point... we love
spending someone elses money
Re: Rocker Arms to tight? [Re: MR_P_BODY] #1576808
02/11/14 04:06 PM
02/11/14 04:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You`re stuck in your ways and me in mine. ANYTIME a head is milled or valves sunk from valve jobs, the pre load`s out of wack period and shimming makes the already sucky small block`s sweep worse so adjustable rockers are the only LOGICAL solution...........I`m gonna go work out now.............. One more thing; if the stem heights are all over like some I`ve seen at least you can even things out w/an adj. rocker.............
Re: Rocker Arms to tight? [Re: Thumperdart] #1576809
02/11/14 04:13 PM
02/11/14 04:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Never mind... I quit... you tell him what he needs
Re: Rocker Arms to tight? [Re: Thumperdart] #1576810
02/11/14 04:15 PM
02/11/14 04:15 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
Please invite me to the ensuing about which rockers to run and what rocker geometry is best
Re: Rocker Arms to tight? [Re: MR_P_BODY] #1576811
02/11/14 04:20 PM
02/11/14 04:20 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Not being able to turn them with preload isnt exactly true. The tension with lifter preload isnt all that strong, especially with a motor thats been off. You will be able to tell the difference though between free turn and preload turn.
Re: Rocker Arms to tight? [Re: GTX MATT] #1576812
02/11/14 04:20 PM
02/11/14 04:20 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
P Body & Thumperdart you bouth have a point but i lean more to P Body´s surgestion as i agree to help the guy out whitout spending more money then nessesary and i gues its not a top end race engine
