Re: Data Aquisition.......Q
[Re: Dragula]
#1576347
02/09/14 02:04 PM
02/09/14 02:04 PM
Posts: 1,019 Finland
mafo
Finland
I can recommend Rpm, customer service is absolutely superb ![](/ubbthreads/images/graemlins/thumbs.gif) I had problems with the oxygen sensor readings and Randy sent us a new "box" for free, after 5 years...talk about warranty http://www.rpmperf.com/
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: Dragula]
#1576348
02/09/14 02:17 PM
02/09/14 02:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you are watching the tune you need the A/F feature... one of the important things in data logging is the read rate.. the one your looking at reads at 100 times per second... thats pretty good.. also you need to know how many more channels can be put in(more reading points) and how many analog inputs it can read(just in case).. on the down load,, thats more of a personal thing.. I run a data logger that you can read on the display and down load via cable to a PC... amount of data is very important also...I'm not very good on how much those data cards can hold but I do know its a lot if its simple data(not video)... like that company said... you will need to get info from time to time on how something works or mounts... if they are a good company they will be around for years to come.. the unit I have is already out of business so I'm on my own... next and maybe one of the more important things is cost of any read outs, probes and sensors.. some places bend you over on them... I got lucky on mine since I had a pile of them from working.. also the type of read out... most are "K" type now days and 0-5 volts on sensors ![](/ubbthreads/images/graemlins/wave.gif)
[Re: boatracer572]
#1576350
02/09/14 03:39 PM
02/09/14 03:39 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I just picked up a used Innovate LM-2 http://www.innovatemotorsports.com/products/lm2.phpDoesn't have a ton of channels, but will accept 4 analog inputs, plus RPM and A/F. Will accept voltage signals from electric gauges. It's pricey new, especially if you need to get the additional transducers, but I got mine on the cheap.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: dizuster]
#1576353
02/09/14 05:32 PM
02/09/14 05:32 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
When I was deciding on a logger,Race pak kept to the top of the mud. I bought the dash with the logger in the dash. Been buying sensors a little at a time because they are pricey.I really like the harness set up,everything plugs in ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: hemi-itis]
#1576354
02/09/14 07:27 PM
02/09/14 07:27 PM
Posts: 12,417 Taxes & Virus's R-US, NY
Dragula
So how do you get the big connectors thru the fire wall?
[Re: Dyno1]
#1576357
02/09/14 11:19 PM
02/09/14 11:19 PM
Dragula
There are racers with Racepaks and people who wished they did. Never regret buying the best.
Been trying to figure out what the sportsman one is with a dash...Their website stinks.
Sportsman $825 Dash, not sure which one, $? What else do I need?....if I can't figure out what the heck I need, I can't even compare them. What options does the system have? Which dash works with the sportsman, do I even need the Sportman if the dash has a logger? Very confusing...
[Re: Dragula]
#1576359
02/10/14 12:04 AM
02/10/14 12:04 AM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
If I had to do it all over again i would have bought the IQ3 logger dash for $1400 has all the same fetures as a sportsman plus built in GPS and 32 user defined channels (compaired to the sportsmans 6user defined)
[Re: Dragula]
#1576363
02/10/14 02:33 PM
02/10/14 02:33 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Racepak, no question. You will be able to use a Sportsman Racepak will do all you are looking for.
[Re: Dragula]
#1576364
02/11/14 01:53 AM
02/11/14 01:53 AM
hemi-itis
I'm no expert,but if you get the sportsman,you can use the display dash if you want,but you don't have to.Just download the data to a laptop.If you get the logger dash,you don't use the sportsman because the logger is in the dash
