proper water pump housing plug #1575311
02/07/14 10:28 AM
02/07/14 10:28 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Looking for a source for the proper plug that goes into the water pump housing on a '69 big block ( my case 426 Hemi, but it should be the same on any housing in that year, if not more years ). This is the plug that people usually take out if they are going to put a mechanical temperature gauge in, in between the two heater hose nipples. I believe the style was flush with the housing with an allen stock recessed hole for tightening.
Thanks.
Troy
Houston Mopar Connection Club
Re: proper water pump housing plug [Re: hemi68charger] #1575312
02/07/14 02:02 PM
02/07/14 02:02 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Might have been a 1/2" square head if my memory is still functioning??
Joe
Re: proper water pump housing plug [Re: jlatessa] #1575313
02/07/14 02:42 PM
02/07/14 02:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Joe
correct , SQUARE head , not an Allen head
Re: proper water pump housing plug [Re: JohnRR] #1575314
02/07/14 03:29 PM
02/07/14 03:29 PM
68gtx Offline
68gtx  Offline
Not to rob your thread but I am looking for the same plug. I think mine measures 3/4 ? Anyone have pics of an original for reference? Thanks larry J
Re: proper water pump housing plug [Re: 68gtx] #1575315
02/07/14 09:31 PM
02/07/14 09:31 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Its 1/2" NPT...Female square drive...Ill see if I have a pic..
MB
Re: proper water pump housing plug [Re: HPMike] #1575316
02/07/14 09:40 PM
02/07/14 09:40 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
It is basically this plug, BUT there is no concave on the top around the square opening. To be correct this plug could be machined flat and the top thread edges tapered down, then I believe plated zinc, and painted with the housing orange.
Re: proper water pump housing plug [Re: srt] #1575317
02/07/14 09:52 PM
02/07/14 09:52 PM
Houston, Tx
Houston, Tx
Would this be like it?
I notice it isn't concaved.....
Troy
Re: proper water pump housing plug [Re: hemi68charger] #1575318
02/07/14 10:04 PM
02/07/14 10:04 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
that'd be the one.
wouldn't know if the plug or socket depth is the same, but could compare notes if you source one.
Re: proper water pump housing plug [Re: hemi68charger] #1575319
02/07/14 10:54 PM
02/07/14 10:54 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
A local parts store carries the correct looking plugs in aluminum and steel from 1/8 to 1/2" pipe thread. I believe it's Parts Plus
