Crushed Glass for Blasting??? #157467
11/26/08 08:37 PM
11/26/08 08:37 PM
440charger70 Offline OP
super street
super street
Is crushed glass (dust) safe and efficient to use for blasting panels? I am wanting to strip the the body on my Charger down to bare metal. I know that sand blasting is too rough for the metal and have looked into Soda blasting and chemical too, just looking into glass dust.
Your thoughts are appreciated.
1970 Dodge Charger 440 (NOM) 1971 Plymouth Duster 340 (#'s Correct) 2008 Jeep Wrangler Sahara. Nice Home for sale near Tampa FL http://ruskinonline.com/docs/WimaumaHouse.htm
Re: Crushed Glass for Blasting??? [Re: 440charger70] #157468
11/26/08 09:11 PM
11/26/08 09:11 PM
There was a thread a day ago about blast cabinet selection that had some good info on media selection(best & dangerous) that might be of benefit to you.
Re: Crushed Glass for Blasting??? [Re: 440charger70] #157469
11/27/08 12:44 AM
11/27/08 12:44 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Glass beading / crushed glass, cost more, will generate more heat, and you may end up warping your panels if your not careful,......What I prefer to do is use "medium cut" Black beauty,....blast the panel on an angle, don't concentrate too long, move along allow any heat to disapait, then go back and hit any area you feel needs to be addressed,.....Black Beauty leaves a slightly rough texture to he metal, but I feel it helps promote a good adhesion for a coat of vari-prime, or epoxy coat rust prevenitive base, which you should do immediately after blasting/blowing the car down
Re: Crushed Glass for Blasting??? [Re: DAYCLONA] #157470
11/27/08 01:52 AM
11/27/08 01:52 AM
Ontario, Canada
8
84Stepside Offline
84Stepside  Offline
Ontario, Canada
i had my truck box done with crushed glass(not glass beads) and it turned out really nice
Re: Crushed Glass for Blasting??? [Re: 440charger70] #157471
11/27/08 09:08 AM
11/27/08 09:08 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Use urea plastic media for the outside body panels, 20/40 coal slage for the inner panels.
Re: Crushed Glass for Blasting??? [Re: Challenger 1] #157472
11/27/08 11:53 AM
11/27/08 11:53 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Plastic blasting is the safest method.
Look for a repuatable shop as you can do more harm than good if the operator is inexperienced.
Re: Crushed Glass for Blasting??? [Re: SSAAHemiFan] #157473
11/27/08 01:07 PM
11/27/08 01:07 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
