cruise control servo diap, looking forward to repro it #1574424
02/05/14 12:43 PM
02/05/14 12:43 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
Does somebody knows where to find a replacement? two servo units in hands, both with broken diaphragm
Re: cruise control servo diaphragm [Re: NachoRT74] #1574425
02/06/14 12:13 PM
02/06/14 12:13 PM
Valencia, España
Valencia, España
it seems, nobody here is interested on fix their CC if broken LOL, just power and tracks LOL
Re: cruise control servo diaphragm [Re: NachoRT74] #1574426
02/06/14 12:31 PM
02/06/14 12:31 PM
foristell mo
serano Offline
serano  Offline
foristell mo
Car-truck-year???
Re: cruise control servo diaphragm [Re: NachoRT74] #1574427
02/06/14 02:18 PM
02/06/14 02:18 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Re: cruise control servo diaphragm [Re: moparfan53] #1574428
02/06/14 03:36 PM
02/06/14 03:36 PM
Nevada
Darter6 Offline
Darter6  Offline
Nevada
70's thru early 90's are all much the same. I replaced mine on a 88 Dodge Truck with one from a 85 Chrysler Newyorker found in a wrecking yard. Brackets may be different but unit is the same.
Re: cruise control servo diaphragm [Re: moparfan53] #1574429
02/06/14 07:02 PM
02/06/14 07:02 PM
Valencia, España
Valencia, España
nice thread but these ones can't be fixed, need a new diaphragm
and on thread says NOS and used are easy to come by? tell me where and AFFORDABLE!
last ones NOS came out on ebay over $200
Re: cruise control servo diaphragm [Re: NachoRT74] #1574430
02/06/14 07:04 PM
02/06/14 07:04 PM
Valencia, España
Valencia, España
Re: cruise control servo diaphragm [Re: NachoRT74] #1574431
02/06/14 11:11 PM
02/06/14 11:11 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
I have several of the servos, is there a way to test the diaphragm?
Tom
68 Charger
70 Cuda
Re: cruise control servo diaphragm [Re: NachoRT74] #1574432
02/07/14 12:19 AM
02/07/14 12:19 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Servo parts were never serviced as components, it's find NOS or good used only.
$285 is not terribily out of line for true nos
I've had/sold a couple of them in the past few years and not had a lot of difficulty getting $200 ea
Re: cruise control servo diaphragm [Re: FC7cuda] #1574433
02/07/14 11:45 AM
02/07/14 11:45 AM
Valencia, España
Valencia, España
Tom
I guess sucking throught the hose and checking the diaphragm moving... or not
Re: cruise control servo diaphragm [Re: gtx6970] #1574434
02/07/14 11:50 AM
02/07/14 11:50 AM
Valencia, España
Valencia, España
while I'm agree they could never got serviceable parts, I guess must be around some ppl/shops who rebuilds diaphragms, because servo control is not the only part of the car what it works with vacuum.
i.e.: 68/69 headlight doors actuators, A/C actuators, Big truck brakes systems, Mercedes 116 door lock actuators ( is my case too LOL ), and lot of etcs...
then add to these, lot of medical tools or devices
Re: cruise control servo diaphragm [Re: NachoRT74] #1574435
02/07/14 04:12 PM
02/07/14 04:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Service parts must have been available at one time because rebuilts were available from NAPA years ago. (NAPA # ECHCCR6085)
Re: cruise control servo diaphragm [Re: John_Kunkel] #1574436
02/07/14 05:02 PM
02/07/14 05:02 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I have always added the factory cruise unit to anything I got, that did not have cruise . . . kept going through the wrecking yards for the components : Servo, Servo bracket, lost motion link on the carburator, wiring - including brake switch and turn signal stalk switch . . .
Have quite a few of the servo's that didn't work when I tried them. Never thought of taking them apart. You could get the cable as a service item . . . as for the rubber diaphram - if it does have a hole, then why not fix using a rubber patch ??? I am pretty sure most of the electrical stuff, held up well on the servo's, so it would probably be just the rubber diaphram issue ??? . . .
Mark
Re: cruise control servo diaphragm [Re: a12rag] #1574437
02/08/14 02:02 AM
02/08/14 02:02 AM
Valencia, España
Valencia, España
unfixable diaphragm
Re: cruise control servo diaphragm [Re: NachoRT74] #1574438
02/08/14 12:48 PM
02/08/14 12:48 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Sounds like a challenge.
If no one else is up for it, send me your bad ones and I will see what I can do.
I'm real good at taking things a-part.
Occasionally I can make a repair.
My thoughts are if it comes apart with out breaking the housing.
Then it should not be to bad to make a new diaphragm and get it back together.
It'll have to be tested st see if it it successful.
Re: cruise control servo diaphragm [Re: convx4] #1574439
02/08/14 01:33 PM
02/08/14 01:33 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I might have some at the old garage.I pulled a lot of stuff from my Imperials that I scraped.I have to wait for warmer weather though.I dont like going up in the attic till its warm.Rocky
Chrysler Firepower
Re: cruise control servo diaphragm [Re: convx4] #1574440
02/09/14 05:31 PM
02/09/14 05:31 PM
Valencia, España
Valencia, España
not mine, but here is how it looks dissasembled.
Re: cruise control servo diaphragm [Re: NachoRT74] #1574441
02/09/14 09:16 PM
02/09/14 09:16 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I think that if I had an old rubber diaphragm, I could make a simple mold. Then use a urethane rubber to make a new one. I guess that this would cost less than $200. So if you sold the new diaphragm for $25, You could be in business for years to come.
Re: cruise control servo diaphragm [Re: NachoRT74] #1574442
02/10/14 12:05 AM
02/10/14 12:05 AM
USA
rftroy Offline
rftroy  Offline
USA
So you don't make a wrong diagnosis, you can't test the diaphragm by putting vacuum on the tube. There is an internal vacuum release valve that prevents vacuum from building up until, 1. The electrical circuit is activated, and 2. The input rotational speed of the speedo cable is about 25 mph.
You could, conceivably, hook up the electricals, and rig some way to turn the speedo input, while applying vacuum. Just be careful that you don't rotate it too fast or you will grenade the insides. I've never needed to do this on the few that I have repaired, but I wouldn't recommend using a drill motor.
I have the factory speed control manual, which has pictures and gives a thorough description of operations, but it is a 21Meg zip file.
I will try and find the link from which I downloaded it and post it later.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: cruise control servo diaphragm [Re: rftroy] #1574443
02/10/14 12:23 AM
02/10/14 12:23 AM
USA
rftroy Offline
rftroy  Offline
USA
Found it!
http://www.imperialclub.com/Repair/Lit/Master/index.htm
Go most of the way down the page to 1972. It is the "Speed Control and Concealed Headlights" manual.
Some very cool stuff on this site.
Robert
