Narrowing a Dana 60 Rear Jig set up? #1574136
02/04/14 06:31 PM
02/04/14 06:31 PM
N.Y.
sixpacksteve Offline OP
N.Y.
i'm going to narrow a dana 60. what material can or should i use to make a jig for the rear?
Hell Hath No Fury Like Mine
Re: Narrowing a Dana 60 Rear Jig set up? [Re: sixpacksteve] #1574137
02/04/14 07:27 PM
02/04/14 07:27 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
e bay,you can buy everything except the cross bar for 124.99,search rear end narrowing jig................
SFI 25.5 depends,no leak,even at 213 mph....
Re: Narrowing a Dana 60 Rear Jig set up? [Re: dakotawilly] #1574138
02/04/14 07:46 PM
02/04/14 07:46 PM
N.Y.
N.Y.
awesome! thanks
Re: Narrowing a Dana 60 Rear Jig set up? [Re: sixpacksteve] #1574139
02/04/14 08:43 PM
02/04/14 08:43 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
http://www.ebay.com/itm/Rearend-Narrowin...=item4acbbef9f7
You'll likely spend another 40-70 on a 1.25" bar
Re: Narrowing a Dana 60 Rear Jig set up? [Re: RobX4406] #1574140
02/04/14 08:48 PM
02/04/14 08:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I spent more than that on mine... 1.250 ground bar
but 3 of use went into it together
Re: Narrowing a Dana 60 Rear Jig set up? [Re: sixpacksteve] #1574141
02/04/14 09:00 PM
02/04/14 09:00 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Here's a pic of my fixture I use for straightening after welding. It's a I beam below which you can't really see.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Narrowing a Dana 60 Rear Jig set up? [Re: MR_P_BODY] #1574142
02/04/14 09:46 PM
02/04/14 09:46 PM
RobX4406 Offline
RobX4406  Offline
Speedy Metals or B &I metals on ebay.
http://www.speedymetals.com/ps-38-96-18r125.aspx
http://www.speedymetals.com/s-101-turned-ground-polished.aspx
http://www.ebay.com/itm/1-1-4-Dia-Cold-F...=p2047675.l2557
Re: Narrowing a Dana 60 Rear Jig set up? [Re: RobX4406] #1574143
02/04/14 10:04 PM
02/04/14 10:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I know I could have bought a cheap bar but I wanted
a hardened bar ground to the spec... it was ground
already when I bought it..it doesnt move like cold
and mine is 60" long.. so far I've never needed more
than 48"
Re: Narrowing a Dana 60 Rear Jig set up? [Re: RobX4406] #1574144
02/06/14 06:28 PM
02/06/14 06:28 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Narrowing a Dana 60 Rear Jig set up? [Re: Polarapete] #1574145
02/06/14 06:59 PM
02/06/14 06:59 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I made mine to fit a piece of 1&5/8 moly roll cage tubing.
A ground bar is overkill to say the least.
Re: Narrowing a Dana 60 Rear Jig set up? [Re: FastmOp] #1574146
02/06/14 07:09 PM
02/06/14 07:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah it may be over kill but I know its straight...
plus it wasnt all that much price wise over cold stock...
I think it cost each of us $12 more than junk cold stock
which if you lean on it will move
Re: Narrowing a Dana 60 Rear Jig set up? [Re: MR_P_BODY] #1574147
02/06/14 07:14 PM
02/06/14 07:14 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I agree on flexing. Mine is not a ground bar but it is solid 1-1/2" round 4340 bar stock.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Narrowing a Dana 60 Rear Jig set up? [Re: 6PKRTSE] #1574148
02/06/14 08:15 PM
02/06/14 08:15 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Mine is a 1 3/8 monel-? stainless steel propeller shaft out of a boat, very smooth and straight, made the other pieces on the lathe from bar stock. got nothing but labor in it
Re: Narrowing a Dana 60 Rear Jig set up? [Re: cudaman1969] #1574149
02/07/14 12:19 AM
02/07/14 12:19 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
These guys will sell just the pucks you need for your particular rear end, you don't need to buy the whole kit, and its where I bought mine.
http://www.mittlerbros.com/mittler-bros/...wing-kit-9.html
