Srtip intake threat #1574020
02/04/14 02:07 PM
02/04/14 02:07 PM
Canada
Dons Dart Offline OP
Canada
YEP i somehow strip most of the threads on my LD340 intake just 1 out of 4 holes that bolts my carb,i did find a longer bolt that caught some threads and is holding,but who knows how long it will last,so i may as well look into buying a Helicoil kit could someone tell me what size drill bit and coil to get thanks DON.Iam sure someone has been there done that.
Re: Srtip intake threat [Re: Dons Dart] #1574021
02/04/14 02:29 PM
02/04/14 02:29 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
http://www.amazon.com/Helicoil-5521-5-Co...#productDetails
You will need a Letter Q Drill bit
http://www.amazon.com/16-18-Coarse-HeliC...elicoil+5+16-18
This set has 3 different length inserts and everything you need to install them
Re: Srtip intake threat [Re: Moparlar] #1574022
02/04/14 02:44 PM
02/04/14 02:44 PM
Canada
Canada
Thanks, the guy at Parts Source was confused buy the Q BIT ? i have to drill out the hole first right than tap than install the coil right.
Re: Srtip intake threat [Re: Dons Dart] #1574023
02/04/14 03:22 PM
02/04/14 03:22 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
Yes you drill first then tap then put in the insert. A Letter Q Drill is 8.5 MM if that helps
Re: Srtip intake threat [Re: Moparlar] #1574024
02/04/14 03:50 PM
02/04/14 03:50 PM
Canada
Canada
Thank you much.
Re: Srtip intake threat [Re: Moparlar] #1574025
02/04/14 03:56 PM
02/04/14 03:56 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Probably won't find a Q bit at the local autoparts HomeDepot or Lowes store. Try a real hardware store or industrial supplier. Or just buy the kit that comes with the bit. Oh and 8.5 MM is less than .003" larger than a Q drill so it should work also. http://www.csgnetwork.com/drillsizeconvert.html
Re: Srtip intake threat [Re: GomangoCuda] #1574026
02/04/14 07:37 PM
02/04/14 07:37 PM
Canada
Canada
thanks.
Re: Srtip intake threat [Re: Dons Dart] #1574027
02/04/14 07:58 PM
02/04/14 07:58 PM
WI
Dcuda69 Online content
Dcuda69  Online Content
WI
thanks.
21/64" is .004" smaller and works. I've done it a number of times,especially on a low torque app like a carb mount flange
Re: Srtip intake threat [Re: Dons Dart] #1574028
02/04/14 10:13 PM
02/04/14 10:13 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I prefer studs instead of bolts. There might be some good theads in the bottom that the studs would grab onto.
Re: Srtip intake threat [Re: forphorty] #1574029
02/04/14 10:16 PM
02/04/14 10:16 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I always use studs even in a cast iron intake.
JB Rhinehart, Realist
A-Body's RULE!
Re: Srtip intake threat [Re: Moparlar] #1574030
02/05/14 11:01 AM
02/05/14 11:01 AM
scratchnfotraction Offline
I will make a note of that size. Q = 8.5 MM
what are the other 3? H,X,G ? -the chart shows them but I never know what they are and asking for them is a blank.
I keep this chart hanging in my shop. I can get the heli coil kits but rarly find the sales person knows what size bit or where to look.
I will looking for the 6.7 MM drill bit today for a 1/4-28 fine thred repair on the pinion yoke.
Re: Srtip intake threat [Re: scratchnfotraction] #1574031
02/05/14 11:55 AM
02/05/14 11:55 AM
Canada
Canada
Once i get the job done i will get those studs for-sure what do i ask for 5 1/6 studs? tell me something once the hole is tap,why could we use the new threads instead the coil? what length will i need as well i have a holley dont want to get 1 too short.
Re: Srtip intake threat [Re: Dons Dart] #1574032
02/05/14 01:14 PM
02/05/14 01:14 PM
on my LD4B intake I did that, I drilled/tapped to next size stud size and got studs that where larger on one end and normal carb stud size on the other.
or you can go to the next size bolt/stud... but you want to check carb flange to see if they will need inlarged.
for a long time on my LD4B the outer carb stud holes were striped and I used the inside holes to bolt the edelbrock carb on and even used a squarebore to spredbore adaptor in the inside holes on intake flange
Re: Srtip intake threat [Re: scratchnfotraction] #1574033
02/05/14 03:30 PM
02/05/14 03:30 PM
dogdays Offline
dogdays  Offline
You can do it even easier. None of this pi$$in& around with bit sizes.
BUY A HELICOIL KIT!
It has everything you need, the helicoils, the drillbit and the tap.
It'll cost you about $50, although I have bought for a lot less on the 'bay.
After you're done, you can buy more loose coils to do more holes.
R.
Re: Srtip intake threat [Re: dogdays] #1574034
02/05/14 07:54 PM
02/05/14 07:54 PM
BUY A HELICOIL KIT!
R.
I would agree...but you get what you can in a one horse town. not all kits come with the drill bit. not all places order kits in...just common sizes for the bulk racks. the pack of inserts are a varity of sizes with other only being in a common size.
I have been to 2 countys looking for the kit with a bit..no kit for a 1/4-28 to be had.. with or with out the drill bit.
so now I am looking around on the bay now. amozon may have something if I get that far into looking.
Re: Srtip intake threat [Re: scratchnfotraction] #1574035
02/06/14 12:52 PM
02/06/14 12:52 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
Check-out McMaster-Carr, they sell small orders to individuals
Re: Srtip intake threat [Re: 3ddart] #1574036
02/06/14 02:16 PM
02/06/14 02:16 PM
Canada
Canada
Were can i buy a decent set in Canada.
Re: Srtip intake threat [Re: Dons Dart] #1574037
02/06/14 02:28 PM
02/06/14 02:28 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Any decent parts store ie Carquest NAPA even Partsource if they don't have them in stock, can order the kit in.
Where are you located?
Kevin
Re: Srtip intake threat [Re: Twostick] #1574038
02/06/14 04:29 PM
02/06/14 04:29 PM
Canada
Canada
Twostick Belleville Canada
Re: Srtip intake threat [Re: Dons Dart] #1574039
02/06/14 05:20 PM
02/06/14 05:20 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Here's what you need. They sell just the coils too.
http://www.canadastoolcrib.com/cgi/CGP2S...691737592542421
CLA-DOR Industrial Supply Co. Ltd.
122 Parks Drive, Unit F, Belleville, Ontario
Canada K8N 4Z5
Phone: 613-969-6292 ~ Fax: 613-966-6963
Email: sales@clador.com
If you know Don Dulmage, he is in your area and might be able to help you out too and he is a MOPAR guy.
Kevin
