Re: Srtip intake threat
[Re: Moparlar]
#1574025
02/04/14 03:56 PM
02/04/14 03:56 PM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
Probably won't find a Q bit at the local autoparts HomeDepot or Lowes store. Try a real hardware store or industrial supplier. Or just buy the kit that comes with the bit. Oh and 8.5 MM is less than .003" larger than a Q drill so it should work also. http://www.csgnetwork.com/drillsizeconvert.html
[Re: GomangoCuda]
#1574026
02/04/14 07:37 PM
02/04/14 07:37 PM
Posts: 440 Canada
Dons Dart
Canada
thanks.
[Re: Dons Dart]
#1574027
02/04/14 07:58 PM
02/04/14 07:58 PM
Posts: 4,946 WI
Dcuda69
WI
thanks.
21/64" is .004" smaller and works. I've done it a number of times,especially on a low torque app like a carb mount flange
[Re: scratchnfotraction]
#1574031
02/05/14 11:55 AM
02/05/14 11:55 AM
Posts: 440 Canada
Dons Dart
Canada
Once i get the job done i will get those studs for-sure what do i ask for 5 1/6 studs? tell me something once the hole is tap,why could we use the new threads instead the coil? what length will i need as well i have a holley dont want to get 1 too short.
[Re: dogdays]
#1574034
02/05/14 07:54 PM
02/05/14 07:54 PM
Posts: 15,487 Florida
scratchnfotraction
You can do it even easier. None of this pi$$in& around with bit sizes. BUY A HELICOIL KIT!
It has everything you need, the helicoils, the drillbit and the tap.
It'll cost you about $50, although I have bought for a lot less on the 'bay.
After you're done, you can buy more loose coils to do more holes.
R.
I would agree...but you get what you can in a one horse town. not all kits come with the drill bit. not all places order kits in...just common sizes for the bulk racks. the pack of inserts are a varity of sizes with other only being in a common size.
I have been to 2 countys looking for the kit with a bit..no kit for a 1/4-28 to be had.. with or with out the drill bit.
so now I am looking around on the bay now. amozon may have something if I get that far into looking.
