2004 Dodge Ram 3500 duallie-4 wheel drive vibration. #1573449
02/03/14 02:51 AM
02/03/14 02:51 AM
Ohio
Hemi Joe Offline OP
Hemi Joe  Offline OP
Ohio
Love my truck but hate the vibration- I have all new tires, carefully balanced, and all new 4-wheel u-joints, new constant velocity joint, and just had the Dodge dealer do all new drive shaft u-joints,but still have my vibration.
Had new converted and flex plate installed and had the trans removed and looked at.
However, at 58 mph to about 68 mph I have a terrible vibration, especially under load or on a hill. I do not have it below 58 and over 68 mph. Now, when I touch the Tow Haul Button, The Vibration goes away, when I disengage it, it comes right back! ANY SUGGESTION ????? Thanks in advance HEMI JOE
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: Hemi Joe] #1573450
02/03/14 11:45 AM
02/03/14 11:45 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
does it change if you are towing a trailer?
you stated under load.... are you refering to, say, acceleration on a flat road? or do you have to be going up a grade.
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: J_BODY] #1573451
02/03/14 01:24 PM
02/03/14 01:24 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
There are fluid filled vibration balancers that cure that problem, I am considering buying some for my ramp truck. Here is one company that makes them.
http://www.balancemasters.com/
http://www.ebay.com/itm/Balance-Master-W...b27&vxp=mtr
JB Rhinehart, Realist
A-Body's RULE!
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: Rhinodart] #1573452
02/03/14 02:28 PM
02/03/14 02:28 PM
Ohio
Hemi Joe Offline OP
Hemi Joe  Offline OP
Ohio
Thanks for the reply- It looks like a great answer, but I still need to know the cause of the vibration. Thanks and be careful out their - HEMI JOE - Haulin Horse Power Transporters
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: J_BODY] #1573453
02/03/14 02:32 PM
02/03/14 02:32 PM
Ohio
Hemi Joe Offline OP
Hemi Joe  Offline OP
Ohio
Thanks for the reply. Yes it does do it on flat land somewhat, but it really vibrates on a hill. If I have my trailer on, I'am in Tow Haul mode, so I do not notice it as much. Thanks - HEMI JOE
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: Hemi Joe] #1573454
02/03/14 09:23 PM
02/03/14 09:23 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I would observe the rpm range that it is most noticeable. Then I would hold the brake and try to bring the rpms to that level and see if you can duplicate the problem. Bumping it in and out of the tow haul modes makes it seem more rpm related vs speed. Worth a try.
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: Hemi Joe] #1573455
02/03/14 11:48 PM
02/03/14 11:48 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Carrier bearing?
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: Michael] #1573456
02/04/14 02:39 AM
02/04/14 02:39 AM
Ohio
Hemi Joe Offline OP
Hemi Joe  Offline OP
Ohio
Hate to seem stupid, but what is a carrier bearing and where is it located and can I replace it without removing the trans? Thanks - HEMI JOE
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: Hemi Joe] #1573457
02/04/14 10:54 AM
02/04/14 10:54 AM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
If you have a 2 piece rear drive shaft, it's the block between the two hanging by 2 bolts from a crossmember. I replaced mine with a 1 piece aluminum drive shaft------smoothed it out.
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: Michael] #1573458
02/05/14 10:05 PM
02/05/14 10:05 PM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
Sounds like torque convertor shutter.My 10 Grand Cherokee does it at 40 mph,put in tow haul no shutter.Do not know if there is a way to flash computer to correct problem.
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: Geezer] #1573459
02/06/14 02:11 PM
02/06/14 02:11 PM
dogdays Offline
dogdays  Offline
My bet too, the torque converter clutch is shuddering. It's not engaging enough to prevent slipping.
The key is when you unlock the TC clutch with the "tow" switch, the problem goes away.
R.
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: dogdays] #1573460
02/08/14 12:39 PM
02/08/14 12:39 PM
Finland, Europe
Ck[FIN] Offline
Ck[FIN]  Offline
Finland, Europe
Cheap fix if thats the real problem. 2 of these and it should cure the problem
http://www.ebay.com/itm/DR-TRANNY-LUBEGARD-TRANSMISSION-INSTANT-SHUDDER-FIX-/150510836237
-1965 Valiant 9.03s 358cu.in R5P7-
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: Ck[FIN]] #1573461
02/08/14 01:21 PM
02/08/14 01:21 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I shudder to think of using it in a new trans...
A-Body's RULE!
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: Rhinodart] #1573462
02/08/14 04:51 PM
02/08/14 04:51 PM
dogdays Offline
dogdays  Offline
Think I'll go rent the movie, "Shutter Island".........
R.
Re: 2004 Dodge Ram 3500 duallie-4 wheel drive vibration. [Re: Hemi Joe] #1573463
02/17/14 03:17 PM
02/17/14 03:17 PM
Ohio
Hemi Joe Offline OP
Hemi Joe  Offline OP
Ohio
Thanks for all the ideas!!! I used the red stuff to fix the shutter and it seems to have helped some. It now appears that the vibration starts at a higher speed, like 65mph. Hopefully it will get better, or the carrier bearing is the next replacement.. THANKS AGAIN !!!! HEMI JOE
