Altered Wheelbase car: Torsion bars or straight axle?
#1573426
02/03/14 02:46 AM
02/03/14 02:46 AM
Posts: 4,704 Wichita
GY3
Wichita
A couple of us are thinking about building one. Which one drives better? Do the A-100 axles have the right width or would a tubular axle from Speedway Motors make more sense? ![](/ubbthreads/images/graemlins/hammer.gif)
Re: Altered Wheelbase car: Torsion bars or straight axle?
[Re: GY3]
#1573428
02/03/14 06:57 AM
02/03/14 06:57 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Torsion bars reduce front end lift - kind of defeats the purpose of an AFX...
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
[Re: THE GLASS MAN]
#1573430
02/03/14 03:01 PM
02/03/14 03:01 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
The original Chryslers used torsion bars, special long ones, but you could move the rear torsion bar attach fitting forward and use standard length ones.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#1573431
02/03/14 03:34 PM
02/03/14 03:34 PM
Posts: 1,505 TN
SCATPACK 1
TN
The original cars used torsion bars from the big Chryslers because they were much longer than the B body torsion bars. To my knowledge none of the true factory altered wheel base cars ever used Straight axles. I have seen several home made versions with the straight axles in it..
Old Geezer Racing
[Re: savoy64]
#1573433
02/03/14 07:42 PM
02/03/14 07:42 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
I moved the complete frontend inclusive the torision bars 4" forward.
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
[Re: Crizila]
#1573435
02/03/14 11:26 PM
02/03/14 11:26 PM
Posts: 643 southern conn
1969gtx
southern conn
All 11 factory car used torsion bars. there is bar out there that work I have a set 49" long. built one car flashback. will be building one this fall I post some pic. there some build on afxer.com. flashback has had the wheels 3'in the air no straight axl here 10.25 comp. 426 hemi on pump gas.
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: Moparmal]
#1573442
02/05/14 07:39 AM
02/05/14 07:39 AM
Posts: 10,164 A Red State
SNK-EYZ
A Red State
I could be wrong, but I believe Clay said his has a coil over shock set up on it. I'm sure he'd be happy to talk about it if you want to. I can pm you his contact info if you're interested. ![](http://i471.photobucket.com/albums/rr72/SNK-EYZ/Image1.jpg)
[Re: RodStRace]
#1573443
02/05/14 11:33 AM
02/05/14 11:33 AM
Posts: 1,186 OHIO
THE GLASS MAN
OHIO
There have been a few built recently. I'd suggest that you research ALL parts involved. The straight axle swap I've seen requires building a steering system by welding some forged parts together. Let's just say those welds better be RIGHT! There are aftermarket suspension parts as said, but ask them how to turn the steering wheel input into front wheel movement on your application and see what they say.
Also ask about shock mounts and brake kits, unless you are going to run without front brakes!
RodStRace says there has been a few made lately, and he is right. We have orders on the board for 4 complete fiberglass kits for the AWB cars right now and a guy in Mich. says he will be ordering enough to do 2 more. There is a lot of interest in these cars right now. Just as much now as back in 1965-66. ![](/ubbthreads/images/graemlins/thumbs.gif)
