Altered Wheelbase car: Torsion bars or straight axle? #1573426
02/03/14 02:46 AM
02/03/14 02:46 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
A couple of us are thinking about building one.
Which one drives better?
Do the A-100 axles have the right width or would a tubular axle from Speedway Motors make more sense?
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: GY3] #1573427
02/03/14 02:58 AM
02/03/14 02:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I built my brothers altered with a leading link straight
axle... it runs high 8s with a simple SBC in it...
drives great with 10* caster... I see your talking
altered wheelbase and not a altered... sorry but this
is what I built for him
EDIT
The stock axle in the D-series was really heavy...
you dont need anything like that in a race car
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: GY3] #1573428
02/03/14 06:57 AM
02/03/14 06:57 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Torsion bars reduce front end lift - kind of defeats the purpose of an AFX...
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: Moparmal] #1573429
02/03/14 01:01 PM
02/03/14 01:01 PM
OHIO
THE GLASS MAN Offline
OHIO
Let me know if you need any fiberglass parts. Here at Sled City Fiberglass, we make and sell all the parts for the AWB cars. Plymouth and Dodge.
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: THE GLASS MAN] #1573430
02/03/14 03:01 PM
02/03/14 03:01 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
The original Chryslers used torsion bars, special long ones, but you could move the rear torsion bar attach fitting forward and use standard length ones.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: Slingshot383] #1573431
02/03/14 03:34 PM
02/03/14 03:34 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
The original cars used torsion bars from the big Chryslers because they were much longer than the B body torsion bars. To my knowledge none of the true factory altered wheel base cars ever used Straight axles. I have seen several home made versions with the straight axles in it..
Old Geezer Racing
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: SCATPACK 1] #1573432
02/03/14 03:37 PM
02/03/14 03:37 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i heard some use light a-body bars for more action in the front...
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: savoy64] #1573433
02/03/14 07:42 PM
02/03/14 07:42 PM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
I moved the complete frontend inclusive the torision bars 4" forward.
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: GY3] #1573434
02/03/14 08:47 PM
02/03/14 08:47 PM
Az
Crizila Offline
Crizila  Offline
Az
Talked to a guy just this Saturday at the track - he was running a Dart with an I beam front end in the 9's. Said it handled great. Got most of his stuff from Speedway. Said it was considerably lighter than the torsion set up. Guess it depends on the look that you want.
Fastest 300
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: Crizila] #1573435
02/03/14 11:26 PM
02/03/14 11:26 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
All 11 factory car used torsion bars. there is bar out there that work I have a set 49" long. built one car flashback. will be building one this fall I post some pic. there some build on afxer.com. flashback has had the wheels 3'in the air no straight axl here 10.25 comp. 426 hemi on pump gas.
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: 1969gtx] #1573436
02/04/14 01:10 PM
02/04/14 01:10 PM
Az
Crizila Offline
Crizila  Offline
Az
I'm wichu on the torsion bars for the correct look if you are doing an altered WB car.
Fastest 300
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: Crizila] #1573437
02/04/14 03:32 PM
02/04/14 03:32 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I can't remember off the top of my head but I think its Mancini that sells the 10" longer torsion bars.
I'm in a slow process of building one however I am using the A-100 Van straight axle. It is a little wide but the few I have talked to about this said not to cut it down in width. Many have cut them down and had no issues. I'm using a pair of 4" Anson front runners and the total track width is actually 1" narrower running the skinny rims over the factory K frame front end and 7" wheels that had 3 1/2" b/s.
...FAFO...
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: skicker] #1573438
02/04/14 07:54 PM
02/04/14 07:54 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
This copy of the specs might help with building an AFX Altered.
This link will take you to the pdf file.
http://www.moparmax.com/features/2006/images/05-report/report.pdf
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: SNK-EYZ] #1573439
02/04/14 10:33 PM
02/04/14 10:33 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Yep, already seen that but thanks for posting it.
Leaning towards straight axle for simplicity.
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: GY3] #1573440
02/04/14 11:48 PM
02/04/14 11:48 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
There have been a few built recently.
I'd suggest that you research ALL parts involved. The straight axle swap I've seen requires building a steering system by welding some forged parts together. Let's just say those welds better be RIGHT!
There are aftermarket suspension parts as said, but ask them how to turn the steering wheel input into front wheel movement on your application and see what they say.
Also ask about shock mounts and brake kits, unless you are going to run without front brakes!
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: 1969gtx] #1573441
02/05/14 12:06 AM
02/05/14 12:06 AM
Moparmal Offline
Moparmal  Offline
Could have sworn Landy's Dodge ran an I beam front...so went and checked.....
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: Moparmal] #1573442
02/05/14 07:39 AM
02/05/14 07:39 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I could be wrong, but I believe Clay said his has a coil over shock set up on it.
I'm sure he'd be happy to talk about it if you want to.
I can pm you his contact info if you're interested.
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: RodStRace] #1573443
02/05/14 11:33 AM
02/05/14 11:33 AM
OHIO
OHIO
RodStRace says there has been a few made lately, and he is right. We have orders on the board for 4 complete fiberglass kits for the AWB cars right now and a guy in Mich. says he will be ordering enough to do 2 more. There is a lot of interest in these cars right now. Just as much now as back in 1965-66.
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: THE GLASS MAN] #1573444
02/05/14 03:50 PM
02/05/14 03:50 PM
Bristol, CT
RalphsRapidTrnst Offline
Bristol, CT
Maybe in 2015 or ?? we can organize a SuperCar Match Bash ShootOut.
A Collection Of All Things Chrysler
www.RalphsRapidTransit.com
Stock Appearing MuscleCar Racing
www.SuperCarRaces.com
Re: Altered Wheelbase car: Torsion bars or straight axle? [Re: RalphsRapidTrnst] #1573445
02/08/14 02:42 AM
02/08/14 02:42 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Can I play?? I promise to stay away from the wallz
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
