Re: 39 DODGE CONV VIN#'S ???
[Re: RodStRace]
#157327
11/26/08 03:06 PM
11/26/08 03:06 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Rod, where is it on my 37 Plymouth truck?, there is a tag on the firewall below the column, anything stamped on the frame?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#157328
11/26/08 06:20 PM
11/26/08 06:20 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Just bring it by and I'll take care of it for you! ![](/ubbthreads/images/graemlins/biggrin.gif) I know that in the teens and 20s, the frames were worth more and had the numbers or they used the engine number, but by the 30s the vehicle number may be on the body somewhere. I just did a search, and found this http://www.ply33.com/misc/vinHope this helps, and if it doesn't I'll still take that sweet truck...er, I mean that hunk of junk with no number off your hands! ![](/ubbthreads/images/graemlins/laugh2.gif) I'm going to look thru the rest of that site.
[Re: RodStRace]
#157329
11/26/08 10:23 PM
11/26/08 10:23 PM
AZ_A12_BEE
Dreaming of the 808
Just bring it by and I'll take care of it for you! I know that in the teens and 20s, the frames were worth more and had the numbers or they used the engine number, but by the 30s the vehicle number may be on the body somewhere. I just did a search, and found this http://www.ply33.com/misc/vin
Hope this helps, and if it doesn't I'll still take that sweet truck...er, I mean that hunk of junk with no number off your hands! I'm going to look thru the rest of that site.
Great info according to this my truck was built in LA if I read the chart correctly, my vin is 9207738 ![](/ubbthreads/images/graemlins/thumbs.gif)
The story of it always being in Ca along with the Standard Oil tag along with a Ca build really puts the history together
Plymouth Serial Numbers Serial numbers are from [Chrysler 1973]. In parentheses below the 1928-29 “FedCo” numbers are the translated numeric strings. In the case of Canadian built cars the unknown letter “G” is left as a question mark.
Pre-WW2 vehicles with a model code ending in “X” were export models. The one exception is the 1933 PCXX (Standard 6) built for domestic US sale. The export version of the 1933 Standard 6 was the PCXXX.
The value in the “Total” column is the difference between the start and end numbers.
Year Cylinders Model Name Model Code Plant Start Serial Close Serial Total 1937 6 P3 P3X Detroit 1,184,001 1,237,460 53,460 Evansville 9,085,551 9,097,493 11,943 Los Angeles 3,101,401 3,105,159 3,759 Windsor 9,376,676 9,381,157 4,482 DeLuxe P4 P4X Detroit 10,101,001 10,468,044 367,044 Evansville 9,190,000 9,199,074 9,075 9,950,001 9,999,021 49,021 Los Angeles 3,162,501 3,205,879 43,379 Windsor 9,339,691 9,349,561 9,871 Commercial Car PT50 PT50X Detroit 8,850,101 8,861,664 11,564 Evansville 9,182,701 9,185,187 2,487 Los Angeles 9,206,601 9,208,113 1,513
37 Plymouth PU
[Re: leavitt4]
#157333
12/15/08 10:21 PM
12/15/08 10:21 PM
Posts: 1,039 Redwood City Ca.
B1arno
Redwood City Ca.
ok maybe im doin something wrong i just tryed lookin up my cars serial number to determine what it is for sure and i cant find my serial number in any of those charts the number is 4058296 if anyone can make sense of it that would be great thanks jason
My car wasn't on there either so I emailed Tod Fitch who owns the website at webmaster@ply33.com and gave him my serial #. He is the one that told me my serial # came up as a 34 Dodge.
