39 DODGE CONV VIN#'S ??? #157325
11/26/08 01:33 PM
11/26/08 01:33 PM
Raleigh N.C
hemiparts Offline OP
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
Does anyone know where to find the chassis vin # on a 39 dodge conv?? I have a customer who bought one and the DMV is ginving him fits to match the vin number before they'll let him register it.
Re: 39 DODGE CONV VIN#'S ??? [Re: hemiparts] #157326
11/26/08 02:38 PM
11/26/08 02:38 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
a 40 is on the passenger door jamb.
The tags underhood are not the VIN, and there is no tag on the driver's side or on the dash area.
Re: 39 DODGE CONV VIN#'S ??? [Re: RodStRace] #157327
11/26/08 03:06 PM
11/26/08 03:06 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Rod, where is it on my 37 Plymouth truck?, there is a tag on the firewall below the column, anything stamped on the frame?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 39 DODGE CONV VIN#'S ??? [Re: AZ_A12_BEE] #157328
11/26/08 06:20 PM
11/26/08 06:20 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Just bring it by and I'll take care of it for you!
I know that in the teens and 20s, the frames were worth more and had the numbers or they used the engine number, but by the 30s the vehicle number may be on the body somewhere.
I just did a search, and found this
http://www.ply33.com/misc/vin
Hope this helps, and if it doesn't I'll still take that sweet truck...er, I mean that hunk of junk with no number off your hands!
I'm going to look thru the rest of that site.
Re: 39 DODGE CONV VIN#'S ??? [Re: RodStRace] #157329
11/26/08 10:23 PM
11/26/08 10:23 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Great info according to this my truck was built in LA if I read the chart correctly, my vin is 9207738
The story of it always being in Ca along with the Standard Oil tag along with a Ca build really puts the history together
Plymouth Serial Numbers
Serial numbers are from [Chrysler 1973]. In parentheses below the 1928-29 “FedCo” numbers are the translated numeric strings. In the case of Canadian built cars the unknown letter “G” is left as a question mark.
Pre-WW2 vehicles with a model code ending in “X” were export models. The one exception is the 1933 PCXX (Standard 6) built for domestic US sale. The export version of the 1933 Standard 6 was the PCXXX.
The value in the “Total” column is the difference between the start and end numbers.
Year Cylinders Model Name Model Code Plant Start Serial Close Serial Total
1937 6 P3
P3X Detroit 1,184,001 1,237,460 53,460
Evansville 9,085,551 9,097,493 11,943
Los Angeles 3,101,401 3,105,159 3,759
Windsor 9,376,676 9,381,157 4,482
DeLuxe P4
P4X Detroit 10,101,001 10,468,044 367,044
Evansville 9,190,000 9,199,074 9,075
9,950,001 9,999,021 49,021
Los Angeles 3,162,501 3,205,879 43,379
Windsor 9,339,691 9,349,561 9,871
Commercial Car PT50
PT50X Detroit 8,850,101 8,861,664 11,564
Evansville 9,182,701 9,185,187 2,487
Los Angeles 9,206,601 9,208,113 1,513
Re: 39 DODGE CONV VIN#'S ??? [Re: hemiparts] #157330
11/26/08 10:33 PM
11/26/08 10:33 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
We pulled a body off a 39 Plymouth sedan. There was a vin # painted on the top of the frame rail on the driver side about at the center x member. Don't know how you would ever see it if the body was still on the car, and it being painted was pretty dumb in my opinoin. This car was from CO and you could read the # pretty well. Gene
Re: 39 DODGE CONV VIN#'S ??? [Re: RodStRace] #157331
11/28/08 05:09 PM
11/28/08 05:09 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Well, thanks to this thread I have discovered that my 34 Plymouth coupe is actually a 34 Dodge coupe!
Arno
Re: 39 DODGE CONV VIN#'S ??? [Re: hemiparts] #157332
12/15/08 09:02 PM
12/15/08 09:02 PM
arizona
leavitt4 Offline
leavitt4  Offline
arizona
ok maybe im doin something wrong i just tryed lookin up my cars serial number to determine what it is for sure and i cant find my serial number in any of those charts the number is 4058296 if anyone can make sense of it that would be great thanks jason
Re: 39 DODGE CONV VIN#'S ??? [Re: leavitt4] #157333
12/15/08 10:21 PM
12/15/08 10:21 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
My car wasn't on there either so I emailed Tod Fitch who owns the website at
webmaster@ply33.com and gave him my serial #. He is the one that told me my serial # came up as a 34 Dodge.
