7 Dodge truck won't start.
#1572971
02/02/14 03:21 PM
02/02/14 03:21 PM
Posts: 658 Dillsburg, PA
Wizard
Dillsburg, PA
I have a 70 Dodge D 700 dump truck with a either a 360 motor or bigger. This truck ran and started fine before I let it sit for about 2 1/2 years of ever trying to start it. All I hear now when I try to start it is a click, click noise down either by the solonoid or in engine bay some where. I tried the old cross the solonoid with screwdriver trick but it did not engage the starter with key on. Just sparks flew. I banged on everything with hammer, starter and solonoid. Any ideas or just take out the starter and go from there?
This motor has the distributer in the front near the fan/water pump. What size motor would it be?
Wizard
Guns, God, and Country.
U.S. Veteran
Re: 7 Dodge truck won't start.
[Re: NITROUSN]
#1572977
02/02/14 09:15 PM
02/02/14 09:15 PM
Posts: 516 ND
dodgedon
ND
This is correct above... The only big Dodge engines available in a 700 series would be the 361 and the 413. They were used up to 75 for sure and maybe later in the larger D series trucks
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: dodgedon]
#1572978
02/02/14 10:05 PM
02/02/14 10:05 PM
Wizard
Dillsburg, PA
Yes, it would be the 361 motor. It has a 2 barrel on it. Battery is in excellent condition. I use it every weekend for another truck and it is not week. Looks like I will try the breaker bar or drop the starter.
Thnks,
wizard
U.S. Veteran
[Re: Wizard]
#1572981
02/05/14 05:44 PM
02/05/14 05:44 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
Nowhere have you mentioned that you know the battery is actually good/fully charged?
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
