7 Dodge truck won't start. #1572971
02/02/14 03:21 PM
02/02/14 03:21 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
I have a 70 Dodge D 700 dump truck with a either a 360 motor or bigger. This truck ran and started fine before I let it sit for about 2 1/2 years of ever trying to start it. All I hear now when I try to start it is a click, click noise down either by the solonoid or in engine bay some where. I tried the old cross the solonoid with screwdriver trick but it did not engage the starter with key on. Just sparks flew. I banged on everything with hammer, starter and solonoid. Any ideas or just take out the starter and go from there?
This motor has the distributer in the front near the fan/water pump. What size motor would it be?
Wizard
Guns, God, and Country. U.S. Veteran
Re: 7 Dodge truck won't start. [Re: Wizard] #1572972
02/02/14 03:41 PM
02/02/14 03:41 PM
It'd be a big block & the only sizes available afaik would be a 383 or a 440. I dont think the 400 came out till 71 model year. Look at the smooth machined pad down by the dist for a stamped # as it might not have the original eng.
Re: 7 Dodge truck won't start. [Re: Wizard] #1572973
02/02/14 03:43 PM
02/02/14 03:43 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
361 most likely pull the plugs on her & break out the socket & breaker bar & see if she's stuck
If she is then mix up one part gasoline to 3 parts trans fluid & put it in the plug holes & start playing
Re: 7 Dodge truck won't start. [Re: BulletBob] #1572974
02/02/14 05:40 PM
02/02/14 05:40 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
When was the 413/426 weined out of production? Id try tuning the motor by hand/breakerbar first to see if its possibly seized. Also.you didn't mention if you used a Known good battery or had a charger/jump box on it?
Re: 7 Dodge truck won't start. [Re: 76dodgeboy] #1572975
02/02/14 06:37 PM
02/02/14 06:37 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
get a bigger
I am truckless..
Re: 7 Dodge truck won't start. [Re: Wizard] #1572976
02/02/14 08:33 PM
02/02/14 08:33 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Most likely a 361. With a 4 barrel it could be a 413.
Re: 7 Dodge truck won't start. [Re: NITROUSN] #1572977
02/02/14 09:15 PM
02/02/14 09:15 PM
ND
dodgedon Offline
dodgedon  Offline
ND
This is correct above... The only big Dodge engines available in a 700 series would be the 361 and the 413. They were used up to 75 for sure and maybe later in the larger D series trucks
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: 7 Dodge truck won't start. [Re: dodgedon] #1572978
02/02/14 10:05 PM
02/02/14 10:05 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Yes, it would be the 361 motor. It has a 2 barrel on it. Battery is in excellent condition. I use it every weekend for another truck and it is not week. Looks like I will try the breaker bar or drop the starter.
Thnks,
wizard
Re: 7 Dodge truck won't start. [Re: Wizard] #1572979
02/03/14 12:15 AM
02/03/14 12:15 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Even with a 2bbl it could still be a 413. As i understand it the industrial 413 could be had with a 2bbl intake.
The engine ID pad would let you know for sure.
Re: 7 Dodge truck won't start. [Re: hp383] #1572980
02/03/14 06:07 PM
02/03/14 06:07 PM
dogdays Offline
dogdays  Offline
A 361 is a B engine, a 413 is an RB. Those can be told apart by the Engine ID pad placement, if you scrape enough grease off the front of the engine.
R.
Re: 7 Dodge truck won't start. [Re: Wizard] #1572981
02/05/14 05:44 PM
02/05/14 05:44 PM
Milwaukee, WI
moparjimbo Offline
moparjimbo  Offline
Milwaukee, WI
Nowhere have you mentioned that you know the battery is actually good/fully charged?
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire
1973 Challenger - 572 Indy Hemi 860HP
1975 Trailduster Convertible, 440
1967 Plymouth Fury Police Pursuit 2DR 505 Stroker
2004 Neon SRT4 modded
www.milwaukeemopar.com
