WOO HOO! My Cummins swap is officially underway! #1572762
02/02/14 03:37 AM
02/02/14 03:37 AM
Pyeongtaek, South Korea
69HemiGTX Offline OP
First off, this isn't being done by me. I'm paying for it. Built vs. bought, yadda, yadda, yadda. I'm 8000 miles away and I want it done. So the hard part will be handled by someone who has already done it several times, and I can't complain about the price.
So here we go. I'm sure a lot of you know about my ugly dually. It's hideous, it has a gas guzzling 440 in it, and it's 2WD. Ugh... The guy doing the swap went to look at a truck for me, was told "I'm gonna fix it up someday," (how many times have we heard that?), and wound up finding a 91.5 donor on the scenic route home. Nice price, intercooled, 4X4, Getrag, dually, etc. SOLD! He's keeping the bale spike bed, but he's unsure about the bumper. It's beyond stout. The uprights are 0.120 wall 2X6 square tubing. I might use it. I don't know. Sorry y'all, I'm keeping the fender badges. I'm going to do all of the small detail crap, but he's doing the swap and 4X4 conversion. Thank you, tax return!
Here's Big Nasty:
OIF V and OEF X veteran and proud of it!
Re: WOO HOO! My Cummins swap is officially underway! [Re: 69HemiGTX] #1572763
02/02/14 03:38 AM
02/02/14 03:38 AM
Here's the donor:
If you look in the background, the Chevy C-10 is the exact color scheme I'm putting on my dually.
Re: WOO HOO! My Cummins swap is officially underway! [Re: 69HemiGTX] #1572764
02/02/14 03:39 AM
02/02/14 03:39 AM
Bumper:
Re: WOO HOO! My Cummins swap is officially underway! [Re: 69HemiGTX] #1572765
02/02/14 09:51 AM
02/02/14 09:51 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Score on the donor!
Re: WOO HOO! My Cummins swap is officially underway! [Re: 69HemiGTX] #1572766
02/02/14 01:37 PM
02/02/14 01:37 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Have him document the project and post pics!
Do you think you'll be able to use the intercooler with the original grill?
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: WOO HOO! My Cummins swap is officially underway! [Re: 3hundred] #1572767
02/02/14 01:42 PM
02/02/14 01:42 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Please let me know if you ever want to sell that bumper, I have been looking for a stout bumper for the front of my ramp truck. I gave one away on my 85 W300 wrecker I parted out before I bought my rampar...
JB Rhinehart, Realist
A-Body's RULE!
Re: WOO HOO! My Cummins swap is officially underway! [Re: 3hundred] #1572768
02/02/14 11:35 PM
02/02/14 11:35 PM
He's going to send me pics as he goes. I have no idea how thoroughly he will, though. As far as using the old the grille, he has a 78, and he said the turn signal housings interfere with the intercooler a little bit. For brevity, he's going to swap the whole intercooled core support into my truck. He won't cut any sheetmetal to try to mate the old with the new. I'll take care of that. I want my truck to look like a factory-delivered 78 with a Cummins, so all of the old stuff is staying. If that won't work, I'll use either the NOS 74-76 or 79-80 quad lamp grilles I have.
Rhino, if neither he nor I decide to use the bumper, I'll let you know. It's in Marlow, OK, though.
Re: WOO HOO! My Cummins swap is officially underway! [Re: 69HemiGTX] #1572769
02/03/14 02:20 AM
02/03/14 02:20 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
he will have to use the cummins core support for the radiator and the intercooler to fit----the grill headlight may have to hand fit..
Re: WOO HOO! My Cummins swap is officially underway! [Re: savoy64] #1572770
02/03/14 05:18 AM
02/03/14 05:18 AM
True. My plan is to use the intercooled core support, then swap the sheetmetal that mounts the headlight buckets between the two. It will have to be cut out of my 78 and welded into the 91. Several people have done it before. It will have the 91's grille until I do this, if it even has one at all.
Re: WOO HOO! My Cummins swap is officially underway! [Re: 3hundred] #1572771
02/03/14 04:21 PM
02/03/14 04:21 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
X2 I've got an 84 that I'd like to do the same to! (Except for the 4x4 part)
Re: WOO HOO! My Cummins swap is officially underway! [Re: Jwilli500] #1572772
09/20/14 12:03 AM
09/20/14 12:03 AM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
Any updates? I'd love to swap one into my '84 Crew!
Re: WOO HOO! My Cummins swap is officially underway! [Re: 300by500] #1572773
09/21/14 12:04 AM
09/21/14 12:04 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I've done the swap. I had an 84 Crew Cab single wheel one ton. You will have to use the core support from the 91.5 you got from the donor. I bought a brand new grill for the 92-93. I still have an NOS one in the box for a spare. I used the gauges and all the wiring from my donor 91.5. You have to move the wiring bulkhead over about 1" to put in the clutch master if I remember correctly. Other than that it is simple. Here is my one truck. It served me well for ten years. Sold it in 2012 when I bought a new one. The only bad part is the air conditioning is just not up to par for a big cab. Good luck. I sold mine for $6500.
Re: WOO HOO! My Cummins swap is officially underway! [Re: fastmark] #1572774
09/21/14 12:28 AM
09/21/14 12:28 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You don't Have to use the 91-93 setup. Fastback66 used a 79/80 setup. Had to cut the core support to clearance for stuff and the lower valance. I'd rather make the 70s grill work instead of using the 91-93 like everyone else seems to. Plus 91-93 is my least fave. Get a Rusty support to cut for mock up and a pattern. Could also try to modify the 91.5 to accept the early headlight buckets. Food for thought.
Re: WOO HOO! My Cummins swap is officially underway! [Re: 76dodgeboy] #1572775
09/21/14 01:02 AM
09/21/14 01:02 AM
Canada
demon Offline
demon  Offline
Canada
My buddies and I have built 3 of these cummins trucks. Yes the 78 grille will fit. On my own truck I used the 92 diesel rad support and swapped in the 72-76's headlight mount sections. I also had to swap in the 72-78 hood latch but you won't need to if you just use the 92 hood.
These swaps work really well. I've been driving mine for many years.
Re: WOO HOO! My Cummins swap is officially underway! [Re: demon] #1572776
09/21/14 06:55 AM
09/21/14 06:55 AM
My ecstasy at the beginning of this project has been replaced by a ho-hum feeling. It is moving forward, albeit at a snail's pace. Life got in the way a bit for the guy working on it. I'm patient, and I'm still overseas. I knew it would be a slow process, so I'm not too alarmed. A little anxious, though. At least he got the bale spike bed off the donor.
Re: WOO HOO! My Cummins swap is officially underway! [Re: fastmark] #1572777
09/21/14 01:26 PM
09/21/14 01:26 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
I remember that truck...that was a nice one!
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: WOO HOO! My Cummins swap is officially underway! [Re: dynotune440] #1572778
09/23/14 02:20 AM
09/23/14 02:20 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
For what its worth, I like the paint scheme on the truck currently. But I gravitate to the 70's 80's style paint jobs.
Even better would be the large, and heavy metalflake.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: WOO HOO! My Cummins swap is officially underway! [Re: hp383] #1572779
09/23/14 05:47 AM
09/23/14 05:47 AM
I don't mind some paint from that era. I was young and impressionable during that time. But I draw the line at what I consider to be um... feminine colors. This is metallic, but not with flakes like a bass boat.
Oh yeah, I just bought a Borgeson shaft from Ignoble in the classifieds. It was too good of a deal to pass up.
Re: WOO HOO! My Cummins swap is officially underway! [Re: 69HemiGTX] #1572780
03/05/15 03:35 AM
03/05/15 03:35 AM
Jees Louise! It's been a little over 13 months since I originally posted this thread. What's happened in that time? Not much. The guy doing the work got a divorce and had to move outside of town. The good news is that he now has several acres, a shop, and no close neighbors. The bad news is that his ex drug him through the ringer with back-n-forth court visits before they finally settled their differences. However, I have used the time to accumulate some good parts:
The Borgeson shaft mentioned above
A full set of custom Auto Meter gauges
A brand-new NV4500 with the 5th gear fix and cast iron tailhousing
An Advance Adapters swap kit
All new Anchor Industries engine and trans mount bushings
ARP flywheel bolts
And the Valair clutch and flywheel I just ordered this morning.
I know it's not a lot, but I'm on a budget, and at least I'm getting the transmission taken care of. He and I also agreed to swap diffs. He's looking for 4.10s, and my donor has them. Conversely, he has 3.54s under his dually crew cab, which I've been looking for. Can you say free gear swap?
BTW, he's keeping the bumper. Oh well, the uprights are in front of the turn signals in the grille, so he'll have to swap stuff around to use it. If you've read into what I've said so far, yes, he has a 78 crew cab dually, too, and it's the most recent Cummins 4x4 swap he's done. The more, the merrier! This one is his. It's actually an 84 cab, but all of the red and silver panels are from a 78. I had to remove some personal info from the pic, hence the gray rectangle.
Re: WOO HOO! My Cummins swap is officially underway! [Re: 69HemiGTX] #1572781
03/05/15 11:28 AM
03/05/15 11:28 AM
Guitar Jones Online laugh2
Did the steering shaft you got have the universal or rag joint on it? Some have had problems with the universal joint shaft separating.
http://www.dieseltruckresource.com/forum...y-alert-137320/
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
