Page 2 of 3 1 2 3
Re: Chassis Guys, a little help please? [Re: CMcAllister] #1572335
02/04/14 05:22 PM
02/04/14 05:22 PM
Lebanon, OH
Brad4406 Offline OP
Brad4406  Offline OP
Lebanon, OH
Obviously I should have done more research before attempting a ladder bar/coil-over suspension.
How do I determine centerline of the vehicle? Once it's determined, how do I find center on the rear axle and how do I ensure the axle is centered in the vehicle? I know I can't use the pinion as it is offset to the passenger side. That's why I thought if I just hung plum bobs off the rear frame rails and measured the distance to the axle flanges and made sure it was the same distance on each side that the rear would be centered. I already triangulated the ladder bar crossmember before welding, ensured the ladder bar brackets are evenly spaced on the ladder bar crossmember, and ensured both ladder bars are adjusted the same.
Re: Chassis Guys, a little help please? [Re: Brad4406] #1572336
02/04/14 06:01 PM
02/04/14 06:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There is a couple of ways to find center line.. one
is to level the car and drop a plum bob from the front
K-member mounting holes(there are reference holes in
the frame rails also).. in the rear you might have
to use reference holes now since you most likely
dont have the front spring hangers anymore... once
you drop the points to the floor you can measure to
the center.. make sure you get a X measurement to see
if its not parallelogram'ed (one side forward of the other)...
once you see if its squared mark the frame/body for
a zero on both sides(those marks will be there for good)
and you can use them to align the diff
Re: Chassis Guys, a little help please? [Re: MR_P_BODY] #1572337
02/04/14 06:11 PM
02/04/14 06:11 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Something like this.
Back in the swing of things at Painless again! Great to be back!
Re: Chassis Guys, a little help please? [Re: BJS racing] #1572338
02/04/14 06:13 PM
02/04/14 06:13 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
And at the front
Re: Chassis Guys, a little help please? [Re: BJS racing] #1572339
02/04/14 06:22 PM
02/04/14 06:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If I'm working on a old body(other than my own... nevermind that)
I will get frame points and centerline points of each
wheel (spindle on the fronts and centerline of the axle
at the wheel mounting points) so I can see if the suspension
points are in the same relationship to the frame points
Re: Chassis Guys, a little help please? [Re: MR_P_BODY] #1572340
02/04/14 06:25 PM
02/04/14 06:25 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Probably should have used a different pic. that was when I was actually squaring up the rear housing off of center line and the perpindicular line. I think I have one from actually making the center line off of the 4 link bracket.
Re: Chassis Guys, a little help please? [Re: Brad4406] #1572341
02/05/14 02:22 AM
02/05/14 02:22 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Didn't mean to scare you...You can hang the rear in that way, then build the shocks and ladder bars around it. The string set up will help you find errors in any particular set up. It just takes time to set up. If you recheck all of your measurements and they are inside the 1/8 tolerance you are good to go. If not then I myself would lay it out on the floor and see whats amiss.
Re: Chassis Guys, a little help please? [Re: loaderpro] #1572342
02/05/14 02:11 PM
02/05/14 02:11 PM
Lebanon, OH
Brad4406 Offline OP
Brad4406  Offline OP
Lebanon, OH
You didn't scare me, I was just thinking that maybe this was a little above my skill level. However, I changed my mind this morning.
Re: Chassis Guys, a little help please? [Re: Brad4406] #1572343
02/05/14 02:12 PM
02/05/14 02:12 PM
Lebanon, OH
Brad4406 Offline OP
Brad4406  Offline OP
Lebanon, OH
I had an epiphany this morning. For some reason, even though I used the tape marked garage floor for lining up all measurements previously, for some reason on the rear axle I was trying to use the vehicle rather than the floor. I don't know what I was thinking.
Thank you all for your inputs and guidance.
Re: Chassis Guys, a little help please? [Re: Brad4406] #1572344
02/05/14 04:45 PM
02/05/14 04:45 PM
Detroit, Michigan
sbsatellite Offline
sbsatellite  Offline
Detroit, Michigan
So it is possible to level and find the center line and such with the rear axle and K member removed from the car? I was gonna try to tackle back halfing my car.
Re: Chassis Guys, a little help please? [Re: sbsatellite] #1572345
02/05/14 04:56 PM
02/05/14 04:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure it is... you dont need all that extra junk in
the way... just do a GOOD job leveling the car first...
I spend hours just setting the car up level and finding
the center line... the better you get it right in
the beginning the better the job turns out
EDIT
I have a jig that I set the cars on... I level the
jig when I roll it into the shop then I level the car
on the jig... I clamp the car in location using the
sill plate flanges so it cant move once its in location
Re: Chassis Guys, a little help please? [Re: MR_P_BODY] #1572346
02/05/14 05:56 PM
02/05/14 05:56 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
its easy to set the axle center line square to the main center line by using the 4 6 10 formula. like a framing square on the floor, the main line 6 feet, axle line 4 feet, end of the 4 foot mark back to the 6 foot mark is 10 feet, a triangle, when the measurements are on there marks its square. wish i could show a drawing to make clear. its amazing how easy the build goes with those lines and plum bob.
total brain fade here, the # are 6-8-10 not 4-6, getting old is !!!!!
Re: Chassis Guys, a little help please? [Re: cudaman1969] #1572347
02/05/14 11:08 PM
02/05/14 11:08 PM
Detroit, Michigan
sbsatellite Offline
sbsatellite  Offline
Detroit, Michigan
I wish you could show a picture too...
Re: Chassis Guys, a little help please? [Re: sbsatellite] #1572348
02/06/14 12:20 AM
02/06/14 12:20 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
One thing I haven't seen discused. Assuming the rear axle is 90* to the vehicle centerline. The axle not being centered in the car shouldn't bother anything. I know my 1/4 panels are slightly different side to side. I adjusted my track bar so that the fender gap is the same on both sides as the tire sidewall clearance is very tight. The axle is now closer to the left frame rail than the right by about 1/4". The car tracks straight, leaves straight, drives straight at the top end.
Doug
Re: Chassis Guys, a little help please? [Re: sbsatellite] #1572349
02/06/14 01:43 AM
02/06/14 01:43 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The numbers are 6-8-10 not thinking right, diagram i made
Re: Chassis Guys, a little help please? [Re: cudaman1969] #1572350
02/09/14 01:01 PM
02/09/14 01:01 PM
Lebanon, OH
Brad4406 Offline OP
Brad4406  Offline OP
Lebanon, OH
Well, after I replum bobbed, remarked the floor, and used the floor markings for all measurements this time, it turned out perfect; both sides are equal distance from the frame rails and both shocks are straight up and down. Everything is tacked and ready for final welds, which I'm about to do now.
Once again, thank you all for your help, guidance, and words of encouragement so I could get this done. I'll try to snap some pictures later today and post them.
Brad
Re: Chassis Guys, a little help please? [Re: Brad4406] #1572351
02/09/14 01:14 PM
02/09/14 01:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: Chassis Guys, a little help please? [Re: MR_P_BODY] #1572352
02/14/14 11:45 PM
02/14/14 11:45 PM
Lebanon, OH
Brad4406 Offline OP
Brad4406  Offline OP
Lebanon, OH
Well, I finally got some pics today. I think it turned out great!
Re: Chassis Guys, a little help please? [Re: Brad4406] #1572353
02/14/14 11:47 PM
02/14/14 11:47 PM
Lebanon, OH
Brad4406 Offline OP
Brad4406  Offline OP
Lebanon, OH
Check out Mr. Unbreakable. He's like, what's taking so long? Bring it!
Re: Chassis Guys, a little help please? [Re: Brad4406] #1572354
02/14/14 11:51 PM
02/14/14 11:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It helps to box in the back also(when you get to it)
looks good... sets nice
EDIT
I dont know if you will street drive it BUT a gusset
down on the right rear ladder bar mount will help
it a TON... it takes out the side ways flex the
diagonal link applies
Page 2 of 3 1 2 3
