Why do I have piston ring bits on my piston? #1571433
01/31/14 04:58 AM
01/31/14 04:58 AM
Gainesville,FL
goldmember Offline OP
Gainesville,FL
I was out of town a couple of weeks ago but a buddy wanted to hit the track. I gave his truck a quick tune up and wished him luck. He called me(yep I was freezing cold!!!) and he went a new best on motor, Picked up .3 and 4mph . I told him to watch out as the end often comes after a great pass. Then he calls to say something went wrong while purging before a real best pass. He takes the head off to find piston rings on top of a piston. Can you help diagnose this issue? Maybe thinking we could get another year out of a junkyard core engine caught up with us?
Re: Why do I have piston ring bits on my piston? [Re: goldmember] #1571434
01/31/14 05:07 AM
01/31/14 05:07 AM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
That looks like parts from the diff
Re: Why do I have piston ring bits on my piston? [Re: CRIKEY] #1571435
01/31/14 08:13 AM
01/31/14 08:13 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
That's why they call it the "BANG" button.
Re: Why do I have piston ring bits on my piston? [Re: goldmember] #1571436
01/31/14 12:03 PM
01/31/14 12:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Parts will fly back and forth from the blown piston
through the intake and land in MOST of the the other
bores(both sides of the block)... as to what went wrong
its hard to say with a single pic.. but that piston
let go... weak, lean, a weak valve spring... I dont know
Re: Why do I have piston ring bits on my piston? [Re: goldmember] #1571437
01/31/14 12:12 PM
01/31/14 12:12 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I'm thinking that a compression/leak-down test won't be required to find which hole is hurt.
Re: Why do I have piston ring bits on my piston? [Re: Duner] #1571438
01/31/14 12:20 PM
01/31/14 12:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... it might not show up
Re: Why do I have piston ring bits on my piston? [Re: goldmember] #1571439
01/31/14 12:43 PM
01/31/14 12:43 PM
Az
Crizila Offline
Crizila  Offline
Az
Plenty left in that motor. Remove the rod, duct tape up the journal ( and any holes in the block ), and let her rip.
Fastest 300
Re: Why do I have piston ring bits on my piston? [Re: Crizila] #1571440
01/31/14 12:47 PM
01/31/14 12:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It would be easier to cut the rod off and leave the big end on the crank lol.
68 Barracuda Formula S 340
Re: Why do I have piston ring bits on my piston? [Re: Bad340fish] #1571441
01/31/14 12:51 PM
01/31/14 12:51 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Looks like you got peanut butter in your chocolate man
Re: Why do I have piston ring bits on my piston? [Re: goldmember] #1571442
01/31/14 02:28 PM
01/31/14 02:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mr. Yuck.............calling Mr. Yuck.......... R U THERE? This is why my dumb azz stayz n/a................
Re: Why do I have piston ring bits on my piston? [Re: Thumperdart] #1571443
01/31/14 02:47 PM
01/31/14 02:47 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Come on now Thumper its a rarity when that happens but then again I can't afford RARITY.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Why do I have piston ring bits on my piston? [Re: goldmember] #1571444
01/31/14 03:25 PM
01/31/14 03:25 PM
Guitar Jones Offline
You touched it. Obviously it's your fault.
Re: Why do I have piston ring bits on my piston? [Re: pittsburghracer] #1571445
01/31/14 03:37 PM
01/31/14 03:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not for some guys around here.............they build a new motor, assume it`s tuned ok AND assume nos takes care of the rest. One maybe two good passes and BOOM..................
Re: Why do I have piston ring bits on my piston? [Re: goldmember] #1571446
01/31/14 05:34 PM
01/31/14 05:34 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Holy crap! I guess that is what people mean when they say forged pistons will take a beating versus hypers/cast shattering? I don't think I have ever seen a piston completely disappear like that in a thread here.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Why do I have piston ring bits on my piston? [Re: goldmember] #1571447
01/31/14 05:57 PM
01/31/14 05:57 PM
jax. fla.
70Dustmite440 Offline
jax. fla.
Yikes!
8sec. street car, been there done that. Quitting when your ahead isn't the same as quitting.
[img]https://scontent-atl.xx.fbcdn.net/hphoto...amp;oe=55DB3E4C[/img]
https://www.facebook.com/eric.norton.1048
R.I.P.UN.
Re: Why do I have piston ring bits on my piston? [Re: Michael Ecks] #1571448
01/31/14 06:21 PM
01/31/14 06:21 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Nitrous isn't mandatory for that to happen. It helps but it isn't mandatory...
Kevin
Re: Why do I have piston ring bits on my piston? [Re: Twostick] #1571449
01/31/14 06:26 PM
01/31/14 06:26 PM
Kevin
I can attest to that. Detonation is detonation regardless of why it's occurring.
Re: Why do I have piston ring bits on my piston? [Re: Guitar Jones] #1571450
01/31/14 08:14 PM
01/31/14 08:14 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
solder the piston back on the rod first,then install a fogger system to make up for the lower compression......................
SFI 25.5 depends,no leak,even at 213 mph....
Re: Why do I have piston ring bits on my piston? [Re: dakotawilly] #1571451
01/31/14 08:42 PM
01/31/14 08:42 PM
PA.
"Little"John
"Little"John
PA.
I'm thinking a turbo would be the way to go now that the compression is lower.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Why do I have piston ring bits on my piston? [Re: pittsburghracer] #1571452
01/31/14 09:06 PM
01/31/14 09:06 PM
dakotawilly Offline
dakotawilly  Offline
maybe add a lenco to get that extra rpm launch..............
