Re: Why do I have piston ring bits on my piston?
[Re: goldmember]
#1571436
01/31/14 12:03 PM
01/31/14 12:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Parts will fly back and forth from the blown piston through the intake and land in MOST of the the other bores(both sides of the block)... as to what went wrong its hard to say with a single pic.. but that piston let go... weak, lean, a weak valve spring... I dont know
[Re: Duner]
#1571438
01/31/14 12:20 PM
01/31/14 12:20 PM
MR_P_BODY
I'm thinking that a compression/leak-down test won't be required to find which hole is hurt.
LOL... it might not show up
[Re: Bad340fish]
#1571441
01/31/14 12:51 PM
01/31/14 12:51 PM
Posts: 5,166 CT
GTX MATT
CT
Looks like you got peanut butter in your chocolate man
[Re: goldmember]
#1571444
01/31/14 03:25 PM
01/31/14 03:25 PM
Posts: 20,659 in a cattle trailer down by th...
Guitar Jones
You touched it. Obviously it's your fault.
[Re: Michael Ecks]
#1571448
01/31/14 06:21 PM
01/31/14 06:21 PM
Posts: 6,568 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Holy crap! I guess that is what people mean when they say forged pistons will take a beating versus hypers/cast shattering? I don't think I have ever seen a piston completely disappear like that in a thread here.
Nitrous isn't mandatory for that to happen. It helps but it isn't mandatory...
Kevin
[Re: Twostick]
#1571449
01/31/14 06:26 PM
01/31/14 06:26 PM
Guitar Jones
Kevin
I can attest to that. Detonation is detonation regardless of why it's occurring.
[Re: Guitar Jones]
#1571450
01/31/14 08:14 PM
01/31/14 08:14 PM
Posts: 515 geezer acres rest home
dakotawilly
solder the piston back on the rod first,then install a fogger system to make up for the lower compression......................
SFI 25.5 depends,no leak,even at 213 mph....
