Re: 2000 durango heat issue
[Re: toplescuda]
#1571256
02/03/14 03:36 PM
02/03/14 03:36 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
May want to change the water pump. Even though not leaking. I have changed out several over the years due to no heat unless at speed it may get alittle warmer due to the impellar eroding to half of its original size & hardly pushing any antifreeze.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: duster2]
#1571258
02/04/14 02:32 PM
02/04/14 02:32 PM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Id say so cause i have to do mine every year it will put out some good heat after i do it thou
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#1571259
02/05/14 12:17 PM
02/05/14 12:17 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Wife has a 2000 Durango , also , and it take forever to get some good heat , unless it say 30 degrees or more outside. I have checked antifreeze and such , it blows air , just cool air. Temp gauge shows motor is warmed up.
Frank
thats cause it has air pocket in the heater system iv done mine i dont know how many times break the lines apart over pass valve cover take the driver side off the water pump nipple flush water through with a water hose and you will see its full of air
My 2003 does the same thing. It has rear heat and that is where the air bubbles up to. Since it is above the engine, it is hard to get rid of it. What he did was the fastest way to flush the bubble out. If you do that, make sure that you have a concentrated solution of antifreeze in the radiator and engine. To keep it from happening, NEVER let the coolant overflow tank go below the middle of the coolant dipstick. If it sucks air into the system, you will have to do it all over again. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
