Whats the secret to route turn sig wires through column #1570973
01/29/14 10:33 PM
01/29/14 10:33 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Don't want to cut the elec connectors off the end. NOS switch and wires. Tried pulling them through with safety wire and string. Didn't work. Anybody know??
Re: Whats the secret to route turn sig wires through column [Re: frank] #1570974
01/29/14 10:49 PM
01/29/14 10:49 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Don't know what you're working on but you may find a plastic or metal channel (U-shaped conduit) on the underside of the column that the wires run through. Remove it.
Once removed, bend the wires at the connector so that connector can be run up lengthwise through the collars of the upper column. It's a snug fit but it will go through there. Installation is the reverse.
In the image below the column is upside down. Screwdriver is pointing to one of the screws that hold (in this case, metal) the cover on.
Re: Whats the secret to route turn sig wires through column [Re: 70Duster440] #1570975
01/29/14 11:03 PM
01/29/14 11:03 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I just kind of snaked mine through. Twist a few up into the collar and pull
Re: Whats the secret to route turn sig wires through column [Re: GTX MATT] #1570976
01/29/14 11:57 PM
01/29/14 11:57 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Copy. I was able to get the trough cover off; I didn't realize it would come off. Easy with that cover off.
Re: Whats the secret to route turn sig wires through column [Re: frank] #1570977
01/30/14 12:41 AM
01/30/14 12:41 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Great!
Re: Whats the secret to route turn sig wires through column [Re: 70Duster440] #1570978
01/30/14 03:00 AM
01/30/14 03:00 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I had a real rough time running it on my Diplomat, but FINALLY got it thru. I was told tilt columns are harder to do than non-tilt. Seems like it would be the other way around since you can articulate the tilt column some, but I guess not. My Dip has a tilt column and I hope to never have to do that again. Getting ready to put a NOS one in my Aspen with a non-tilt. Hope it goes easier than the Dip.
Facts are stubborn things.
