Page 1 of 3 1 2 3
'69 440 Valve Cover marking - See Pic #1570832
01/29/14 09:19 PM
01/29/14 09:19 PM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
Any idea what this is supposed to be? My Charger didn't have it's build sheet and I thought there was supposed to be some correlation between the numbers on the sheet and on the Valve cover. Thanks for any input, Mike
Re: '69 440 Valve Cover marking - See Pic [Re: MCTPhoenix] #1570833
01/29/14 09:40 PM
01/29/14 09:40 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
One side was the last parts of the PN for the engine. The other side the transmission. Can't read those numbers too well though.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: '69 440 Valve Cover marking - See Pic [Re: MCTPhoenix] #1570834
01/29/14 11:59 PM
01/29/14 11:59 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Looks like a 916 which is a 69 440 375 w/auto and A/C. Engine color Orange.
Is that your setup???
Ron
Re: '69 440 Valve Cover marking - See Pic [Re: RJS] #1570835
01/30/14 01:33 AM
01/30/14 01:33 AM
Phoenix, AZ
Phoenix, AZ
Ron
Yeah Ron, that's it, THANKS. Where exactly does the 916 come from and what belongs on the other side valve cover? Mike
Re: '69 440 Valve Cover marking - See Pic [Re: MCTPhoenix] #1570836
01/30/14 02:18 AM
01/30/14 02:18 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
It is the last 3 digits of the p/n for that engine, with that marked on the passenger valve cover and a 093 marked on the drivers side cover they knew on the line to pull that motor and put it in a body that called for a 440 375 w/air and auto in 1969.
The trans p/n would be 2892093 hence the 093.
I don't know the full 7 digits for the engine p/n with the white book I have but it's last 3 digits is 916.
I believe these 3 digit codes would be found on the Broadcast sheet if you had one.
Ron
Re: '69 440 Valve Cover marking - See Pic [Re: RJS] #1570837
01/30/14 11:50 AM
01/30/14 11:50 AM
Would the engine number have been different if it did not have a/c yet still made for an auto trans? I can't see them making a specific motor just for an option like a/c.
Re: '69 440 Valve Cover marking - See Pic [Re: ] #1570838
01/30/14 02:05 PM
01/30/14 02:05 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Yep it would be a different # 69 440 375 auto no A/C is 917
From how it was explained to me (and again I don't claim to be correct on everything I spew) it was just a quick way for a line worker to pull the motor off the shelf.
Ron
Re: '69 440 Valve Cover marking - See Pic [Re: RJS] #1570839
01/30/14 04:54 PM
01/30/14 04:54 PM
Phoenix, AZ
Phoenix, AZ
Ron
OK, here's what's on the Driver's side valve cover on the front...
Re: '69 440 Valve Cover marking - See Pic [Re: RJS] #1570840
01/30/14 04:56 PM
01/30/14 04:56 PM
Phoenix, AZ
Phoenix, AZ
Ron
And here's what's on the Driver's side cover on the rear...
Re: '69 440 Valve Cover marking - See Pic [Re: MCTPhoenix] #1570841
01/30/14 05:37 PM
01/30/14 05:37 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Ron
Yes I've seen the 5 on many valve covers so my explanation is definitely flawed with the 093.
We need someone more knowledgeable to fix mt wrong answer.
Maybe the 5 is found on the Buildsheet is the best I came come up with.
I know I had an "0" on my 69 440 375 4speed driver side cover and I got that information from a reliable source at the time.
Ron
Re: '69 440 Valve Cover marking - See Pic [Re: RJS] #1570842
01/30/14 05:42 PM
01/30/14 05:42 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Ron
Ron, was the writing on the valve cover used in all the plants?
Ron
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: '69 440 Valve Cover marking - See Pic [Re: RJS] #1570843
01/30/14 05:42 PM
01/30/14 05:42 PM
Phoenix, AZ
Phoenix, AZ
Ron
My '70 440 4speed Charger has a "0" on the drivers side cover.
Re: '69 440 Valve Cover marking - See Pic [Re: ] #1570844
01/30/14 11:02 PM
01/30/14 11:02 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Yes. As A/C was considered part of the total engine assembly.
Remember, A/C cars could come with different items like carbs so you have to account for an A/C and non A/C assembly plus you have to account for the A/C with a manual or automatic transmission. (Disclaimer: Not speaking specifically about a 440 but in general and in context of the assembly numbering system)
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: '69 440 Valve Cover marking - See Pic [Re: 69CoronetRT] #1570845
01/31/14 12:23 AM
01/31/14 12:23 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Not sure about other motor/trans combination but my 69 Coronet 500 uses the 091 trans, book calls out 383 4 barrel with A/C
Re: '69 440 Valve Cover marking - See Pic [Re: 69CoronetRT] #1570846
01/31/14 12:30 AM
01/31/14 12:30 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I know you could get s 383 4 speed with air but was a 440 4 speed ever available with air conditioning?
Re: '69 440 Valve Cover marking - See Pic [Re: RoadRunnerJD] #1570847
01/31/14 12:34 AM
01/31/14 12:34 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
No,
Re: '69 440 Valve Cover marking - See Pic [Re: MCTPhoenix] #1570848
01/31/14 01:26 AM
01/31/14 01:26 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Good picture Mike......... Very wise of you to ask a question before stripping and repainting, without duplicating the ID...
Good job..
Troy
Houston Mopar Connection Club
Re: '69 440 Valve Cover marking - See Pic [Re: hemi68charger] #1570849
01/31/14 04:01 AM
01/31/14 04:01 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I always "assumed" the 5 was left over from the days (or related to) when the automatic sales code was 395 & 4-speeds were 393, but that doesn't explain the 0
Re: '69 440 Valve Cover marking - See Pic [Re: 6bblgt] #1570850
01/31/14 02:44 PM
01/31/14 02:44 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
The 3 digit engine number is the last 3 numbers of the part number for that Engine Assembly. On the other side....an automatic trans equipped car would get either a 5, a 25 or a 125 depending on year etc. This number is based on the Engineering number for the Kick-down linkage. That is why standard transmission cars have a "0" on the v/cover....no kick-down linkage. I have a bunch of pics of various cars...I'll look for them. I have not seen these numbers on some low-mile, original cars....it seems not all had these markings....they were probably identified by different means...such as paper tags etc.
Re: '69 440 Valve Cover marking - See Pic [Re: FJ5_Fish] #1570851
01/31/14 02:53 PM
01/31/14 02:53 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Found the pics from my Doc-Tona. 440 Auto. This one has a "5" for the auto trans...
Page 1 of 3 1 2 3
