Need Help. 1970 cuda horn #1570709
01/29/14 06:13 PM
01/29/14 06:13 PM
Canada
cuda499 Offline OP
cuda499  Offline OP
Canada
Looking for the little brass ring in a steering column that has horn wire attached to it. Also need the roller that touches this ring as you steer. Mine is shot and is causing my horn to work intermittently. Does anyone have access to these parts. Havent been able to find brass ring or roller. Parts are in a 1970 cuda
two five zero 575 93fourty
chad
Re: Need Help. 1970 cuda horn [Re: cuda499] #1570710
01/29/14 07:11 PM
01/29/14 07:11 PM
Chad welcome aboard!. I'd suggest putting a want ad in the appropriate "parts wanted" section here (on Moparts). That piece might even cross over to several body types which'll make it even easier for you to locate a good used one.
